Noise - TCCoA Forums
post #1 of 4 (permalink) Old 07-03-2010, 11:16 AM Thread Starter
ortbird's Avatar
Question Noise
seems to be coming from rear wheel area - can only hear when I driving very slow...it's a rotational sound like DUG DUG DUG DUG DUG... low, but not too low not to hear...
what can it be?
ortbird is offline
post #2 of 4 (permalink) Old 07-03-2010, 12:09 PM
what can it be?
Something rotating at that speed.
Tires, bearings, CV joints - if it's at some rotational speed besides the tires, then possibly diff or rear U-joint.
Get someone to inch the car along and listen for it, and see if it's at the same speed as the tire rotation.
If it is, swap the tires front/back and see if it stays with the tires or with the car location (i.e., right rear or "that BFG I had on the right rear now on right front".)
RalphP is offline
post #3 of 4 (permalink) Old 07-03-2010, 12:26 PM
Old_Fashioned_Cat's Avatar
I just changed my brand new two front tires on my truck because they had flat spots in em. It was really noticable at slow speed but at faster it was a very light vibration, like the tire was slightly out of balance, I only noticed in the steering wheel.
Question: if it was a bearing, would it fade in and out (instead of a sharper rhythmic noise) as it came to the worn area?
Ryan
1997 Cougar XR7 30th Anniversary Edition
Stock 4.6, Tokico Blues, lowered 1.25", 2.5" high flow catback exhaust
2013 Escape (daily driver)
2.5L
Old_Fashioned_Cat is offline
post #4 of 4 (permalink) Old 07-04-2010, 01:59 PM Thread Starter
ortbird's Avatar
OK tested it a bit more...
Now I think it's NOT rotational, and seems more prominant when I am slowly turning right.
When I hit a bump or an uneven spot the noise is also there, even when driving straight. I tried to drive the right rear and left rear wheel over bumps, and it SEEMS like the noise is more when the RIGHT wheel drives over a bump, and not so much with the left wheel...That is when driving straight.
no apparent clunk noise on slow left turns...
It's a hollow sounding "dup" "dup" noise/clunk. definitely from the rear, and most prob. from rear right...
ortbird is offline
