Odd clunk (video) - TCCoA Forums
post #1 of 23 (permalink) Old 07-06-2010, 10:42 AM Thread Starter
Send a message via AIM to Kaiser
Odd clunk (video)
I've had this odd clunking sound for a while now. I have had UCA's and LCA's on the both sides replaced. The right side was Ford, the left was Moog. I think the clunk is coming from the driver's side, but I'm not 100%. The recording was taken on my phone (sorry) while it was laying in the floorboard under my feet. The recording is a little muffled, so the real sound is a little more like a rattle. Any ideas?
http://www.youtube.com/watch?v=frgU5YvNDYc
Kaiser is offline
post #2 of 23 (permalink) Old 07-06-2010, 12:15 PM
Sway bar in links in good shape
post #3 of 23 (permalink) Old 07-06-2010, 01:13 PM
+1 Rear sway bar links. Mine sounded similar...
~Rick
TCCoA Sig
post #4 of 23 (permalink) Old 07-06-2010, 01:27 PM
ehh, sounds like a bunch crap rolling around..
post #5 of 23 (permalink) Old 07-06-2010, 02:54 PM
95xbird's Avatar
How do you guys determine the Sway bar links without the car actually being driven???
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #6 of 23 (permalink) Old 07-06-2010, 02:56 PM
its called an imagination!
post #7 of 23 (permalink) Old 07-06-2010, 02:58 PM
95xbird's Avatar
I suppose. Unless its just a recording of the noise with a still shot of the car in it.
EDIT: Should have actually read the post from the OP. oh well.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #8 of 23 (permalink) Old 07-06-2010, 03:11 PM
Rayo's Avatar
Sounds like a broken rear sway bar link..could be either side...
Rayo...
1991 Ford Thunderbird Sport
Rayo is offline
post #9 of 23 (permalink) Old 07-06-2010, 05:42 PM
EIT: Should have actually read the post from the OP. oh well.
Yes, I did ASSUME (I know what it spells) it was just a still he put on the post, but the recording was done with the car moving. Didn't he say he had the phone on the floor recording?
~Rick
TCCoA Sig
post #10 of 23 (permalink) Old 07-06-2010, 05:42 PM
95xbird's Avatar
Read the Edit.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #11 of 23 (permalink) Old 07-06-2010, 05:45 PM
Read the Edit.
Oh, I see. So again I was supposed to ASSUME that you meant with this comment what the OP meant (he didn't really state he was moving, so you ASSUMED too).
I'm just saying
~Rick
TCCoA Sig
post #12 of 23 (permalink) Old 07-06-2010, 05:48 PM
95xbird's Avatar
I'm just saying
ok are you gonna follow me around the boards? Take your instigating bullsh!t somewhere else gramps
Its slow, Really.
LS1 KILLER
95xbird is offline
post #13 of 23 (permalink) Old 07-06-2010, 06:05 PM
Exclamation
I'm hope you're just messin' around, cause I wasn't trying to offend you in the least. Maybe you should go get you some.....
~Rick
TCCoA Sig
post #14 of 23 (permalink) Old 07-06-2010, 06:28 PM
95xbird's Avatar
Giving your track record regarding what I post, Yeah. And at least mine is still working.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #15 of 23 (permalink) Old 07-06-2010, 06:48 PM
sousa632's Avatar
GETTING BACK ON TOPIC.............
It definately sounds like a endlink. You just need to determine wether the sound is coming from the front or rear. From the vid it sounds like the rear ones. I replaced both fromt and rear at different times chasing down that clunk. Do yourself a favor though and get a GOOD set of links. I bought Raybestos ones from Rockauto and 3 months/1K miles later they are still good where the others lasted me maybe 1 month before making noise again.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #16 of 23 (permalink) Old 07-06-2010, 10:54 PM
That's an ugly rumor. And those little blue pills I take are for my sinuses!
~Rick
TCCoA Sig
post #17 of 23 (permalink) Old 07-07-2010, 08:14 AM
95xbird's Avatar
To the OP, bad front links I always found to be more of a rattle. Rears were a hard clunk. Either way its still hard to diagnose through a video of sound. Do what I did. By all 4 links as preventive maintenance. They are fairly inexpensive and you'll be happy to know all the links are completely out of question. Good luck.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #18 of 23 (permalink) Old 07-07-2010, 08:15 AM
you know, if you are afraid to spend the money, then just unhook or remove all 4 links, and see if the noise goes away.
post #19 of 23 (permalink) Old 07-07-2010, 08:20 AM
95xbird's Avatar
Yeah that'll definitely be a good way to find out. Hopefully he wouldn't drive it like that tho. I drove JustinH's vortech bird with no links front or rear and oh man I was getting sea sickness in the turns.
Its slow, Really.
LS1 KILLER
95xbird is offline
post #20 of 23 (permalink) Old 07-07-2010, 08:22 AM
try driving the 73 bird...or my 98 lesabre....ugh, no handling FTW!
My 95 is okay....I only run a rear sway bar...no front. I also run skinnies up front with no pwer on the power rack......
post #21 of 23 (permalink) Old 07-07-2010, 08:37 AM
GRNDPNDR's Avatar
sway bar links aren't structural, he could drive it but I'd be slow going around corners.
Anyway I promise you 100% this is your sway bar links, not sure which ones but I'd bet 90% it's the front. They rattle over every pebble or grain of sand on the road.
To check, turn your wheels so you can reach in, grab the end link and try and shake it. it shouldn't move around in the joint itself.
you can also pull down on the sway bar where it's under the rad, pull it up and down hard and it will rock the car, you may also hear a little bit of the rattling as the sway bar is being jerked up and down.
it's your end links plain and simple, end of story.
Rest In Peace Mom.
GRNDPNDR is offline
post #22 of 23 (permalink) Old 07-09-2010, 12:38 AM Thread Starter
Thanks for the help, guys. I was so worried it was a bad ball joint or something since I didn't replace one of them with a Ford part... I'll replace my other link and let ya know!
Kaiser is offline
post #23 of 23 (permalink) Old 08-28-2010, 03:58 PM Thread Starter
All better. Driver's side end link on the front. It's nice and quiet now.
Kaiser is offline
