control arm bolt? - TCCoA Forums
post #1 of 15 (permalink) Old 07-07-2010, 02:50 AM Thread Starter
thunderclaw's Avatar
Question control arm bolt?
does anybody know what size wrench or socket is needed to loosen the lower rear control arm nut?
(the aluminum looking one with a plastic cap located closest to the fuel tank)
trying to install a brace.
thunderclaw is offline
post #2 of 15 (permalink) Old 07-07-2010, 06:30 AM
GRNDPNDR's Avatar
I don't know off hand, but which brace you installing?
Rest In Peace Mom.
GRNDPNDR is offline
post #3 of 15 (permalink) Old 07-07-2010, 11:29 AM Thread Starter
im trying to adapt a kenny brown brace i bought cheap from a cobra irs:
http://www.fulltiltboogieracing.com/...ebrace1yn8.jpg
post #4 of 15 (permalink) Old 07-07-2010, 06:21 PM Thread Starter
i think ita 40mm wrench, but im not sure. not sure if its metric at all, since ford mixed standard and metric fasteners.
post #5 of 15 (permalink) Old 07-08-2010, 08:56 AM
tbirdtess's Avatar
Nut?
Hi
It's not sae. I use like a 1 1/2" or so, But don't fit correctly.
Make sure you take the load off the lower arms when removing the bolt.
Don't cross thread. as it has a fine thread.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #6 of 15 (permalink) Old 07-09-2010, 10:40 PM Thread Starter
Originally Posted by tbirdtess View Post
Hi
then i think its going to be metric. i bought a large socket 3/4" drive rachet set and sockets jump from 39mm to 41mm and the 41 fits loosely, 39mm dont even fit. wht ta hell! ibought it to loosen that nut and the socket that i need its the one thats missing!
post #7 of 15 (permalink) Old 07-09-2010, 10:50 PM
BACW. Big Azz Cresent Wrench.
RalphP is offline
post #8 of 15 (permalink) Old 07-09-2010, 11:08 PM
Let us know if it bolts up, I didn't think the cobra brace would work.
post #9 of 15 (permalink) Old 07-09-2010, 11:32 PM Thread Starter
have to bent the tabs a little, but it fits.
post #10 of 15 (permalink) Old 07-09-2010, 11:49 PM
Post many pics when done
I'm definitely picking one of these up if thats all there is to it
post #11 of 15 (permalink) Old 07-10-2010, 01:53 PM
tbirdtess's Avatar
1 5/8"
Yep same here. I use a 1 5/8" socket. socket is loose.
Used it last night. I needed to take off the drive shaft.
Paul
351W 2bbl.
C-4 Auto
3.90 open rear
post #12 of 15 (permalink) Old 07-11-2010, 01:03 PM Thread Starter
i installed it on my 95 tbird, but i took it off when i wreck it. had to elongate the holes and bent the tabs a little. and still have to tighten it hard so the tabs finish bending to the right angle, but it fits. i recommend you get the one made for the tbird. less hassle. i just went to the whole trouble of adapting it cause i got it for cheap. i'll post some pics when finished
post #13 of 15 (permalink) Old 07-11-2010, 07:20 PM
Well, anything to break the mn12 aftermarket monopoly is worth the effort for me plus I come across those braces alot locally.
post #14 of 15 (permalink) Old 07-11-2010, 08:51 PM Thread Starter
ok, then you might be interested on the irs cobra diff aluminum bushings those are a bolt-on and you wouldn't have to worry about them going out and creating slop in the suspension.
here's a pic of them:
[IMG][/IMG]
post #15 of 15 (permalink) Old 07-11-2010, 09:28 PM
Already got those
