Alignment questions - TCCoA Forums
post #1 of 10 (permalink) Old 07-24-2010, 09:56 AM Thread Starter
1996Project-bird's Avatar
Alignment questions
Yesterday I replaced my inner and outer tie rods with moog parts and while I was under the car, I just could help but notice that the boots on my sway bar end links were completely shot, torn up and everything, and my upper ball joint is the same. Would it be better to replace these before an alignment, or does it not really matter either way?
1996Project-bird is offline
post #2 of 10 (permalink) Old 07-24-2010, 10:07 AM
Buckcreekbilly's Avatar
Do it all and then get alignment, otherwise you'll be getting 2 alignments.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #3 of 10 (permalink) Old 07-24-2010, 10:10 AM Thread Starter
Thats exactly what I needed to know. Thanks!
post #4 of 10 (permalink) Old 07-25-2010, 10:43 AM
There are alignment specs in the tech articles; print and take them to the guy that does your alignment. It will make a difference.
Also, make sure you have the full weight of the car on the wheels when you torque the pivot bolts; otherwise, the bushings will be bound up, and it will handle like crap!
post #5 of 10 (permalink) Old 07-26-2010, 10:18 AM Thread Starter
What is the difference between the alignment that a shop would normally do as compared to the specs from the articles?
post #6 of 10 (permalink) Old 07-26-2010, 06:02 PM
Dusty's Avatar
I plan on doing innter tie rods this weekend with Moogs.
Any bewares?
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #7 of 10 (permalink) Old 07-26-2010, 11:20 PM Thread Starter
The boot was a PITA to get off. There is a big clamp more towards the rack that holds the boot on and i just cut mine off because i could not figure it out. I'm not sure if you are looking to reuse the outers but i didnt so i smacked them off with a hammer. Other than that, just have a big adjustable wrench and you should be fine. It was my first time doing this too and I had it done in about 2.5 hours.
post #8 of 10 (permalink) Old 07-27-2010, 04:50 AM
Dusty's Avatar
I was thinking of reusing the outers, so I will try a puller to get them out without tearing them up.
The rivet came out without much trouble? I looks pretty straight forward.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #9 of 10 (permalink) Old 07-27-2010, 07:33 AM
Turns out, if you have a BFW, you can pop that rivet off easily by merely levering the inner tie rod.
The Moogs I used, used Loctite(tm) to lock to the rack.
RalphP is offline
post #10 of 10 (permalink) Old 07-27-2010, 07:45 AM
"Normal" alignments list a range for each setting and most alignment shops will simply put the adjustment somewhere in that range and call it good.
The specs in the article are at the outer edges of those ranges and are for optimal handling.
They are still with factory ranges, just a more accurate setting leaning towards handling.
69 F100 LWB w/460 Engine
