Somethings clunking around back there. - TCCoA Forums
post #1 of 11 (permalink) Old 08-11-2010, 09:33 AM Thread Starter
Bigiron383's Avatar
I've got a noise coming from the rear of the vehicle. I sounds like something in the trunk. I've removed everything from the trunk and it's still there. I've also gotten underneath and pulled and prodded and found nothing loose.
Bigiron383 is offline
post #2 of 11 (permalink) Old 08-11-2010, 09:37 AM
My trunk lid hinge bolts worked their way loose and it was making noise, tightening them up solved that. Probably not your issue if you're getting a 'clunk' but it's worth checking.
post #3 of 11 (permalink) Old 08-11-2010, 12:32 PM
Rayo's Avatar
Check the Swaybar Endlinks..You might have broke one..or two..
Rayo...
1991 Ford Thunderbird Sport
Rayo is offline
post #4 of 11 (permalink) Old 08-11-2010, 06:41 PM
Yeah endlinks make a true clunk. Usually the bushings come out and they clunk and bend and break and such.
jjTbirdjj is offline
post #5 of 11 (permalink) Old 08-12-2010, 08:26 AM
sousa632's Avatar
A rubber mallet will help find where the clunk but I'll put money on the endlinks too. Mine was making a clunk as well and it ended up being the endlinks.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #6 of 11 (permalink) Old 08-12-2010, 08:32 AM
Mine were bad too. But since my rear sub-frame swap, that has gone away...
Speaking of which. I thought the Mark VIII rear sway bars were smaller than the Bird's, but mine feels noticeably stiffer in the back now with the Mark VIII rear sub-frame; maybe because it was an LSC it came out of?
~Rick
TCCoA Sig
post #7 of 11 (permalink) Old 08-12-2010, 06:48 PM
Not sure Ive been afraid of swapping mine since its a sport and I like the stiffness but if an LSC is stiffer I would be interested.
post #8 of 11 (permalink) Old 08-12-2010, 07:22 PM
I have no clue, but I will grab the micrometer at work and measure it tomorrow. You can measure yours too, and we'll compare who is bigger... Sorry, I couldn't resist.....
I believe yours is a .96" solid sway bar, but I'm not positive by any means. I'll let you know my LSC bar size tomorrow.....
Looking at the pictures of the two sub-frames here, they look the same size
http://forums.tccoa.com/showpost.php...2&postcount=38
I believe the biggest stock Ford bars you could get can be found on the 1989 SC and XR-7's: 1.2" solid front sway bar and 1.1" solid rear
~Rick
TCCoA Sig
post #9 of 11 (permalink) Old 08-22-2010, 09:23 AM
You ever measure it? I think the front sway on the sport is actually the same as stock just the rear is beefed up it is pretty thick lookin at it. My t-bird book says Sport package consists of 16 inch nine-spoke aluminum wheels wearing p225/60r16 touring tires, a larger rear stabilizer bar, larger front disc brake rotors, revised spring rates, revised front lower arm bushings, revised shock absorber valving and rear decklid spoiler with integral stop lamp. Gonna have to look into this some more
post #10 of 11 (permalink) Old 09-20-2010, 04:26 PM
ortbird's Avatar
Are the swaybar end links also (not the the sway bar itself) different on the Sports Package in anyway, or are they the same as the regular end links?
ortbird is offline
post #11 of 11 (permalink) Old 09-20-2010, 05:29 PM Thread Starter
Bigiron383's Avatar
Yes indeedy swaybar endlink. It didn't show while on the ground, but on a hoist with everything hanging, there it was.
