I Hate this Noise But? - TCCoA Forums
post #1 of 11 (permalink) Old 08-20-2010, 07:34 PM Thread Starter
no1nosrob's Avatar
i have a noise coming from the back part of my 1993 Lincoln Mark Viii i just replace every bushing, and the shocks everything is tight and to spec. but when going down the road. sounds like aim bottoming out but aim not..
i have the spring conversions kit, and like i said everything is new
please help the tires are kinda old don't know if that make a difference
no1nosrob is offline
post #2 of 11 (permalink) Old 08-20-2010, 07:41 PM
Moderator & Teksid Whore
guitar maestro's Avatar
and this has what to do with the ford 4.6 modular engine?
guitar maestro is offline
post #3 of 11 (permalink) Old 08-20-2010, 08:11 PM
Wheel bearings can make all sorts of weird noises when they're on their last miles...
post #4 of 11 (permalink) Old 08-20-2010, 09:01 PM Thread Starter
no1nosrob's Avatar
ok is there an diagram of the rear hubs, or rear axles ? on this web site anywhere
post #5 of 11 (permalink) Old 08-20-2010, 09:01 PM Thread Starter
no1nosrob's Avatar
it just does
post #6 of 11 (permalink) Old 08-20-2010, 09:06 PM
Dunno. Remove the tire and brakes, remove the axle shaft retaining nut (36mm) and the three bolts holding the knuckle (be sure to support the LCA with a jack or something) on then get the bearings pressed at a shop. Save yourself big labor charges there. I bought a new bearing for the Cougar off RockAuto for like $35 and a local shop pressed the old one out and the new one in for me for $20.
post #7 of 11 (permalink) Old 08-20-2010, 11:01 PM Thread Starter
no1nosrob's Avatar
now if thats the problem(wheel bearing) should i just replace both side or just the bad side? and if aim on a newly built road, one that is as smooth as a baby ass, it doesn't make a noise? still wheel bearing
post #8 of 11 (permalink) Old 08-20-2010, 11:10 PM
DLF
DLF's Avatar
Mark VIII's are infamous for upper shock mount problems, have you checked/replaced them?
My Web Site
DLF is offline
post #9 of 11 (permalink) Old 08-21-2010, 12:40 AM Thread Starter
no1nosrob's Avatar
i have not replaced the "shock mount" but i have replaced the shock and bushings
post #10 of 11 (permalink) Old 08-21-2010, 12:53 AM Thread Starter
no1nosrob's Avatar
ok here is a question about my "4.6 modular engine" my i have done a major tune up on the engine but it still shakes little, but runs good and i am pulling about 310hp on dyno. so my question is should i worry about the shake(like is it normal)
post #11 of 11 (permalink) Old 08-21-2010, 11:50 AM Thread Starter
no1nosrob's Avatar
nope shock mounts good,
MY Favorite past cars
1993 Lincoln Mark VIII
1992 Ford SHO MTX
_
"If you cant beat him, then your not driving a V8"
