Rack. - TCCoA Forums
post #1 of 8 (permalink) Old 08-21-2010, 11:18 PM Thread Starter
tbirdtess's Avatar
Rack.
Hello
What are the symptoms of a bad Rack?
Bad power steer pump?
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 8 (permalink) Old 08-22-2010, 12:37 AM
A bad rack can suddenly "come off track" internally and be cocked to one side, a bad pump will wine, howl, shreak, or bind and seize. A bad rack can also leak internally and bleed fluid into the boots causing them to swell and leak fluid.
post #3 of 8 (permalink) Old 08-22-2010, 11:56 AM Thread Starter
tbirdtess's Avatar
Squeak
Hi
the pump had a squeak when I turned the wheel.
Had high - low spots. then lost all power steering at the end.
I just replaced the front K Had trouble getting the steering shaft together.
could the rack suck air?
The pump was run with low fluid when first restarted the car, adding water.
351W 2bbl.
C-4 Auto
3.90 open rear
post #4 of 8 (permalink) Old 08-22-2010, 07:24 PM
the rack can suck air, but to bleed the system all that needs to be done is the wheel needs to be turned lock to lock which will cause the air to rise up in the reservoir. If the pump was run low enough it could have caused it to burn up.
post #5 of 8 (permalink) Old 08-22-2010, 07:40 PM
thunderclaw's Avatar
Originally Posted by tbirdtess View Post
Hello
what's yours doing?
thunderclaw is offline
post #6 of 8 (permalink) Old 08-23-2010, 07:13 PM Thread Starter
tbirdtess's Avatar
Power steer pump?
Hi
Can the pumps be rebuilt?
How do you check if A pump is good?
351W 2bbl.
C-4 Auto
3.90 open rear
post #7 of 8 (permalink) Old 08-26-2010, 11:23 PM
Hi
u can if u have ur own machine shop.
they sell rebuilt units at a more affordable price.
a bad pump would make a loud noise when u make turns. probably foam up the steering fluid.
post #8 of 8 (permalink) Old 08-27-2010, 07:58 PM Thread Starter
tbirdtess's Avatar
rack
hi
well the rack is dripping. have to change it in the morning.
351W 2bbl.
C-4 Auto
3.90 open rear
