Lower control arm question....ball joint removal.... - TCCoA Forums
post #1 of 4 (permalink) Old 09-01-2010, 06:57 PM Thread Starter
AEDM8's Avatar
Im doing a suspension rebuild on the daily driver (97 Thunderbird). I cant for the life of me get that lower ball joint to drop out of the spindle. Im replacing the whole arm with a brand new lower control arm from MOOG. New bushing all around.
Do I need a press to get that pOS out?
Im using a tuning fork and a big hammer. That doesnt seem to be doing the trick.
Before I pull another muscle anyone have a tip for removal?
AEDM8 is offline
post #2 of 4 (permalink) Old 09-01-2010, 07:23 PM
drag-aholic
BAGGED89's Avatar
what about beating the spindle with a sledge hammer near the balljoint hole? Leave the nut on loose so what it pops it doesn't fall apart
i would think a pickle fork would get it, especially if you aren't worried about saving the balljoint
1989 LX Full Air Suspension
BAGGED89 is offline
post #3 of 4 (permalink) Old 09-01-2010, 07:29 PM
I am pretty sure I used the same tool for the LBJ to spindle, tie rod end to spindle, end links. I had zero luck with a pickle fork, only succeeded is destroying the boots. I also didn't have much luck with loosening the nut 3 or 4 turns and beating on it with a hammer, but I didn't try real hard because it was pretty much 2 seconds with the tie rod end tool.
4 or 5 bucks at harbor freight, used on three complete mn12 front end swaps/replacements, and still could be used again (but the pointed end is getting deformed).
Bangster is offline
post #4 of 4 (permalink) Old 09-01-2010, 07:29 PM Thread Starter
AEDM8's Avatar
OK got it.
Now....how about those control arm bushings up front. How do those come out? THe doughnut looking ones.
****and in case this is ever searched. I used leverage. Jacked the car up a little higher, slipped a bar over the fork, hammered it in as best I could and jumped on it. Worked great.
AEDM8 is offline
