Pressure line elbow - TCCoA Forums
post #1 of 8 (permalink) Old 09-12-2010, 01:52 PM Thread Starter
Send a message via AIM to jmmctighe Send a message via Yahoo to jmmctighe
Pressure line elbow
OK, so after disconnecting the power steering lines on the XR7 I have the elbow out that connects the pressure line to the rack. I was assuming this was where my leak was coming from but in looking at it it doesn't look bad at all but I figure I'd replace it anyway since I don't want to do this job again. Anyone know where I can get one? PN is F1SZ-3A719-D but the Ford dealer no longer has them and a junk yard most likely trashed it when removing the rack.
John
jmmctighe is offline
post #2 of 8 (permalink) Old 09-12-2010, 02:49 PM
Nitemare's Avatar
Dealer only part. Try checking other dealers, I called one that was able to see others' inventory and found a part I needed that way.
Nitemare is offline
post #3 of 8 (permalink) Old 09-12-2010, 03:48 PM
Edelmann 39104 from rockauto.
post #4 of 8 (permalink) Old 09-12-2010, 04:24 PM Thread Starter
Thanks d0g but that part# is for the return line, the one I need is for the pressure line, has threaded fittings at both ends, the rack end has the line run through the threaded nut much like a metal fuel lines do.
post #5 of 8 (permalink) Old 09-13-2010, 09:44 AM
bagged95's Avatar
Go to the junk yards and get one.
most times ive ever seen a bird in the yard the rack was still installed and complete.
why do you feel you need a new one anyways? is it cracked or broken? if its leaking it could just most likely be the seals on either side of the elbow.
bagged95 is offline
post #6 of 8 (permalink) Old 09-13-2010, 12:09 PM Thread Starter
In all honestly, I don't know that is what was leaking as I couldn't see where the effing thing was leaking from with everything in place. The fluid was coming from above the rack, looked like within the crossmember but again I couldn't see. The elbow looks to be in good shape so maybe I'll just get the O-rings and replace those and see how it goes. I just didn't want to do the job twice if this is the failing part. Ford dealer in town wants $72 (said he could still order it) so for my time and the price of new O-rings and a new pressure line maybe I'll be OK reusing it. At least now I know how to get to it
post #7 of 8 (permalink) Old 09-13-2010, 01:45 PM
I had to think about it for a minute, but that part is available from ford.
post #8 of 8 (permalink) Old 09-13-2010, 02:04 PM
bagged95's Avatar
you can take a couple of bolts out of the crossmember that hold the PS lines and pull them down to take a better look to find your leak if you havent already.
bagged95 is offline
