Mounting Strut Rods & Bushings - TCCoA Forums
post #1 of 5 (permalink) Old 09-13-2010, 11:56 PM Thread Starter
bagged95's Avatar
I took my strut rods off a while ago and made some progress rebuilding the entire front end's suspension but like the scatter brain that i am i forgot to mark where it was mounted to the subframe to keep the wheels somewhat aligned until i can get around to having the car aligned.
So... i guess what im looking for is the measurement from the mounting point on the subframe and where it connects on the LCA so i can get them close.
bagged95 is offline
post #2 of 5 (permalink) Old 09-14-2010, 12:27 AM
Did you remove the nut on the backside of the crossmember side bushing? If not, you don't have to worry about it being too far out. It'll be close enough to drive to a shop.
post #3 of 5 (permalink) Old 09-14-2010, 12:40 AM Thread Starter
bagged95's Avatar
Yeah, removed everything, cleaned everything and painted everything.
bagged95 is offline
post #4 of 5 (permalink) Old 09-14-2010, 12:55 AM
On mine, from where the threads start, I count 4 threads before the nut.
post #5 of 5 (permalink) Old 09-14-2010, 02:57 PM
I did the same thing. You can sorta eyeball the alignment your self but it'll drive you nuts that the steering wheel is cock eyed. That's why the alignment from a pro is so worth it, man.
Philippe Mentor
Philippe Mentor is offline
