Lower ball joint life expectancy - TCCoA Forums
post #1 of 8 (permalink) Old 09-21-2010, 09:20 PM Thread Starter
Do the lowers last a lot longer than the uppers?
I believe mine are originals and are still holding up. My car is closing in on 140k.
79 TBird 5.0 - wrecked - driven 3 months
79 Mustang Pace Car 4cyl Turbo - sold to collector - driven 1 1/2 years
89 Cougar 3.8 - head gasket @ 141k - driven 1 yr
90 Cougar 3.8 - needed complete front susp @ 159k - driven 4 years
93 Cougar 3.8 - leaky head gasket @ 127k, bad front susp - driven 3 years
95 TBird 4.6 - crashed at approx. 150k - SOLD to TCCOA member to be fixed.
sabarth is offline
post #2 of 8 (permalink) Old 09-21-2010, 10:40 PM
From what I've seen, yes. The boots on the uppers are the first to tear.
post #3 of 8 (permalink) Old 09-22-2010, 02:18 AM
V8ThunderCat's Avatar
I concur. While the boots on my uppers are almost totally trashed the lowers look perfect.
-Randy-
V8ThunderCat is offline
post #4 of 8 (permalink) Old 09-22-2010, 08:40 AM
Banned
91bluecoupe's Avatar
I put over 200K on my original lowers and even though the boots on the uppers were torn badly they did not show very much wear, I replaced them just because I replaced all the front suspension joints at the same time.
I have had MN12's for over 12 years now.
Cannot keep accurate track of miles now my odometer is broken(3rd one.) Just count the years now. LOL
91bluecoupe is offline
post #5 of 8 (permalink) Old 09-22-2010, 10:03 AM
My factory lowers were loose by about 140k, I replaced my uppers shortly thereafter. The uppers were not loose, just creaky. I saw a lot of mn12/fn10s flatbedded into our shop because of separated lowers with atleast one upper that was also on its way out.
coolhandzep is offline
post #6 of 8 (permalink) Old 09-23-2010, 12:09 PM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
Here's what happened to me. My car has 141,3xx miles, when I was driving down the freeway, and just randomly my passenger front side of the car sloped down, and I started to slow in speed. Thinking crap, flat tire now, I was able to pull over, but I was also slowing down at a very high rate, not like a regular tire blow. When I finally got out to investigate, my lower ball joint completely popped out of the LCA, and my tire was pushed as far back as it would go, with only the steering and upper control arm to hold it.
At 125K miles, I did some major work on it, replacing anything that looked old/ majorly used, including upper control arms, sway bar, ect.. but when I looked at the LCA, they looked in great shape, so I left them.
Freak accident to me... Who knows, I am known to have the bad luck follow me Yet your reference to seeing alot of that, I am not feeling so bad about it.
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #7 of 8 (permalink) Old 09-24-2010, 07:30 AM
Ebay suspension components have been known to fail after a year or so.
Dropping a ball joint at speed can be bad.
post #8 of 8 (permalink) Old 09-24-2010, 02:54 PM
twin turbo 281's Avatar
my lower pulled out of socket 180K in a parking lot
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
