Rear Sway Bar End-links (Sport) - TCCoA Forums
post #1 of 8 (permalink) Old 10-02-2010, 12:30 PM Thread Starter
ortbird's Avatar
Where can I find the part number for this?
Are the end links on Sport package different from the regular ones? (I assume yes, but wanted to be sure.)
...I need to get mine replaced and will probably do it at an indie shop, I need to tell them to make sure they order the correct part for the sports model.
Thanks I.A.
ortbird is offline
post #2 of 8 (permalink) Old 10-02-2010, 02:35 PM
According to the parts listing on RockAuto it does not appear the sway bar endlinks differ (front or rear) between sport or standard suspension.
post #3 of 8 (permalink) Old 10-02-2010, 07:46 PM
Banned
91bluecoupe's Avatar
I just did mine last week and the books showed them the same.
91bluecoupe is offline
post #4 of 8 (permalink) Old 10-02-2010, 07:58 PM
Just did mine today..same for all models.
delz05 is offline
post #5 of 8 (permalink) Old 10-03-2010, 10:50 AM Thread Starter
ortbird's Avatar
Thanks guys. Have to get my bird winter-safe/ready....
several things to get fixed: Loose heat shield, Sway bar end links (rear), some good winter tires...
ortbird is offline
post #6 of 8 (permalink) Old 10-25-2010, 04:56 PM
CrystalPistol's Avatar
Mine are same, noticed a knocking noise the other day in the rear of my '95. Back up on ramp, look see, no bushing on left side.
Remove both, bushing was age hardened and broken on right side too. I pressed in new bushings cut from some black heater hose .... used vice, worked great.
Maybe last a year, maybe 3 .... and then I can do it again?
Later ....
CrystalPistol is offline
post #7 of 8 (permalink) Old 10-25-2010, 05:49 PM
Remove both, bushing broken it hardened on right side too. I pressed in new bushings cut from some black heater hose .... used vice, worked great.
Later ....
LOL! Great idea! I just bought new ones, but I didn't think to just push in new bushings! Great idea, again!
~Rick
TCCoA Sig
post #8 of 8 (permalink) Old 10-25-2010, 09:48 PM
Thumbs up
.... maybe it'll help someone.
