Front Spring And Shock Questions - TCCoA Forums
post #1 of 17 (permalink) Old 10-06-2010, 02:45 PM Thread Starter
J. Arkayman's Avatar
The front shocks need to be done on my 95 Cougar. The spring is looking pretty corroded. I may as well replace them while everythings apart.
So here's my question. What springs and shocks would you all recommend? I don't need anything special and don't want to lower it, but I would like something a little stiffer than the stock set up.
J. Arkayman is offline
post #3 of 17 (permalink) Old 10-06-2010, 02:56 PM Thread Starter
Originally Posted by JR Tigerstar View Post
SuperCoupe or Sport springs.
Will those lower the car?
post #5 of 17 (permalink) Old 10-06-2010, 03:05 PM Thread Starter
No, they should not,
as long as they are not modified or worn alot.
Cool. Thanks.
post #6 of 17 (permalink) Old 10-06-2010, 08:56 PM
+1 for SC/sport springs if you don't want it lowered. Also I have the tokicko blue shocks on my MarkVIII, and for a daily driver they are great, very predictible handling but still soft enough that you can drive the car every day without having to have a chiropractor on speed dial.
post #7 of 17 (permalink) Old 10-07-2010, 03:22 PM
That is what my "blues" do for my bird as well But some others flame them
post #8 of 17 (permalink) Old 10-07-2010, 03:51 PM
kpthefatty's Avatar
Where can you get the sport springs new?
kpthefatty is offline
post #9 of 17 (permalink) Old 10-07-2010, 04:54 PM
I don't think so new that is
post #10 of 17 (permalink) Old 10-07-2010, 05:20 PM
You can't get them new, and they would be too expensive new anyway. But 96/97 tbirds with the spring code JJJJ had the same springs as the SCs, so that would be the newest you could get.
post #11 of 17 (permalink) Old 10-08-2010, 05:59 AM Thread Starter
Would these work? It says they're for a mid 90's SC.
http://shop.advanceautoparts.com/web..._1409406202___
post #12 of 17 (permalink) Old 10-08-2010, 01:07 PM
svtfiend@yahoo.com's Avatar
plus one on the tokico blues! got mine off SHOX.com for less than 290 bucks. I have really been pushing these to the limits the last couple of cruises i've been on and cant tell you how happy and impressed i am with them. am using the stock SC springs. had it at triple digits and it felt nice and solid, hammers around corners great, and still feels good over harsh bumps. couldnt ask for more out a shock at that price!
1991 Super Coupe -
Performance=5.0 H.O. w/M5R2 5speed, 3.27 gears w/CF TracLoc,95 Cobra intake, 75mm Power throttle body, fenderwell CAI, C&L 73mm mass air w/24# injectors, FRPP E-Cam,Trickflow spring kit & Crane 1.7 roller rockers on stock E7s, MAC shorty headers, Flowmaster cat back w/hiflow cats, MSD plugs, coil, wires, electric cooling fan, 190lph Walbro fuel pump, BBK pulleys, and a B&M shifter. Drilled/slotted rotors, power brake conversion, Tokico Blues, Eibach springs, tons of poly, T4MO ecm
post #13 of 17 (permalink) Old 10-08-2010, 03:11 PM
kpthefatty's Avatar
I guess what i am looking for is a spring that will keep me at the same ride height but be stiffer than stock, but i hate putting used parts on my car. Is there any one who makes a spring to replace the sc springs?
post #14 of 17 (permalink) Old 10-08-2010, 10:24 PM
Yes there is; Duffy Floyd from SCCOA posted a link and specs for the springs.
post #15 of 17 (permalink) Old 10-08-2010, 11:41 PM
Rayo's Avatar
Go over to www.coilsprings.com ...They can make any spring you want..Should run about $300 for all 4..Good luck!
Rayo...
1991 Ford Thunderbird Sport
Rayo is offline
post #16 of 17 (permalink) Old 10-09-2010, 06:36 PM
If you want a set of JJJJ sport springs, I just removed a set (72Kmiles, excellent shape) from my son's car to install Tokico Lowering Kit. You can have all 4 springs (fronts and rears) if you want. Not sure what to ask, but compared to your link, I'd do 100.00 for the complete set. Send along a zip code to me and I will get shipping estimate. We should be able to work out something if you want them.....
delz05 is offline
post #17 of 17 (permalink) Old 10-10-2010, 08:30 AM Thread Starter
PM sent.
