Mustang II set-up? - TCCoA Forums
post #1 of 10 (permalink) Old 10-07-2010, 06:01 PM Thread Starter
thundersc's Avatar
Send a message via AIM to thundersc
Mustang II set-up?
Has anyone done a Mustang II setup on a t-bird? After market has the Mustang II setup with Big brakes and coilovers or airbags. I know some welding on front frame would be needed. What do you think?
Just think about the bigblock that would fit without shock towers in the way
thundersc is offline
post #2 of 10 (permalink) Old 10-07-2010, 09:09 PM
The big block fits without touching the shock towers, and there are several 460 powered MN12s to prove it. The MN12 suspension is a better design off the bat than the mustang 2, as well as having more adjustability. The shock towers are also integral to the front structure of the car, so if you remove those, you make the car even less rigid, which will hurt performance across the board. Basically there is no advantage to us to convert to the mustang 2 front suspension, and it would require a lot of fab work for no gain, only to find that the front end of your car is now all over the road because you have no structure left in it.
post #3 of 10 (permalink) Old 10-08-2010, 12:00 AM
Raptor22's Avatar
Yea, I agree with Mikey. There is no reason you would want to make that swap, the SLA independent front and rear suspension designs are superior to 95% of the cars on the road, including Mustang IIs.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #4 of 10 (permalink) Old 10-08-2010, 12:19 AM
The mustang II front suspension is independent SLA
post #5 of 10 (permalink) Old 10-08-2010, 11:37 AM
392Bird's Avatar
The Mustang II would be fine for a street/strip car that had some weight reduction done to it, and limited use on inner city chuck hole roads.
One that would be a better choice for most would be a sub frame from a Crown Vic.
The complete subframe is aluminum. I think they come from the 98-2002 CV and Mercs, but I am sure a CV guy could verify that
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #6 of 10 (permalink) Old 10-08-2010, 11:46 AM
Definitely not on 89-02. I believe they started with the aluminum subframe and R&P steering in 04 or 05.
post #7 of 10 (permalink) Old 10-08-2010, 11:55 AM
Originally Posted by 392Bird View Post
Is that a truck frame? If so, what year?
And yeah, the stock setups on the MN12/FN10's are better than many vehicles.
69 F100 LWB w/460 Engine
post #8 of 10 (permalink) Old 10-11-2010, 01:17 PM
fast Ed's Avatar
That front suspension is on 2003-up Crown Vic, Grand Marquis, and Town Car. Some early F-100 guys are using them I think.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #9 of 10 (permalink) Old 10-11-2010, 03:46 PM
Beat me to it, Ed. ^^this would be correct^^
FordMan77 is offline
post #10 of 10 (permalink) Old 10-12-2010, 06:26 AM
Thanks, but I was asking what year the steel truck frame was from.
F100 = 1953 through 1983 (I think) with many a frame change.
