1 3/8 Sway Bar - Crack in Fire wall - TCCoA Forums
post #1 of 3 (permalink) Old 10-14-2010, 12:21 PM Thread Starter
This question has probably been discussed several times before on this forum. I just did not found the discussions and solutions.
I have lowered my 94-Tbird 1,5" with Vogtland springs and there are also Koni adjustable shocks. This summer I had original sway bar in front and Addco 1 3/8 in rear. I had the rear Koni on max soft and the front Koni on 3/4 hard. Functioned relatively good, not absolutely perfect, but ok. The problems vere when there were turns with some defect in the road and I had a speed over 75 - 80 mph, otherwise ok. This winter I will change to a Addco 1 3/8 also in front.
I have seen in some questions discussed on this forum that the fire wall can crack with that stiff sway bar. What should I do to prevent it from cracking? The most easy is of course to just stay with original sway bar, but I will do the change. I will make the Strut Tower Brace. I will also make the Lower Engine Cradle Brace.
Is there anything else that I should or can do? I better do it before cracking because it is much more work to do after the cracking.
Regards
Berth
Berth is offline
post #2 of 3 (permalink) Old 10-14-2010, 01:58 PM
tbirdtess's Avatar
crack
Hello
Don't think stock stuff won't crack the firewall.
I have a 96, 3.8 auto. has the crack in the firewall.
Both those braces are a good idea.
My 90 has as seperation in the trany tunnel. Not the car's fault
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 3 (permalink) Old 10-14-2010, 08:10 PM
95_SilverBird's Avatar
I think the Koni and lower springs will crack the firewall more than the bars... I'm one of the guys that had the firewall split and I have stock bars.
Eibach 1.5" Lower Springs, Koni Adjustable Shocks, SCP IRS Brace, SCP Lower Engine Cradle Brace, Mark VIII LCAs
Chuck's Poly Motor Mounts, 13" PBR Front and Cobra rear brakes, 245-45-18 ADR Kasai Wheels, RichardM Intake Tube
Super Coupe leather seats and console, Pioneer Head, Audison Amps, Boston SL Components, 10" Boston G5 subs, Reverse Glow EL Gauges, Super Coupe Ground Effects, '96 Hood and Headlights, Custom paint: Tungsten Silver, PI Intake, 4000 stall
95_SilverBird is offline
