91 Sport Springs - TCCoA Forums
post #1 of 3 (permalink) Old 10-30-2010, 09:51 AM Thread Starter
91 Sport Springs
Tried search and I'm still not clear. I'm wondering if 91 Sport springs are the same as 96-97 Sport/ SC springs. I have a 91 Sport and a 89 Cougar XR7 and the Cougar seems stiffer.
black V8 is offline
post #2 of 3 (permalink) Old 10-30-2010, 11:48 AM
Rayo's Avatar
According to the MN12 Tech articles The only Thunderbird's and Cougar's that got the stiffer springs were the 89-92 XR7,and the 89-95 SC..The only exception being the 97 Thunderbird Sport that also came with these stiffer springs...
However I have a 91 Sport also,and pulled the tag off one of the front springs..The tag says (JVC 61.1/7356)..There is conflicting information,but in my honest opinion..Check your springs and look for the tag..
fosc-ja (fronts)
Should have a Spring Tag of "JVC" and the "B" Pillar Tag should be "J". English Load Rate (Lbs. Lb./in.) 1654 349-403, English Wire Diameter = 0.594-0.659
fosc-ja (rears)
Should have a Spring Tag of "NUD" and the "B" Pillar Tag should be "J". English Load Rate (Lbs. Lb./in.) 1672 509-637, English Wire Diameter = 0.612-0.708
These are in fact the same springs used on the 89-92 XR7 and the 89-95 SC..Look for the tags on your springs..Good luck!
Rayo...
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 3 (permalink) Old 10-30-2010, 01:25 PM
89-92 XR7 All 93's used the standard V6 or V8 springs
