Mark 8 Bouncy Ride - TCCoA Forums
post #1 of 9 (permalink) Old 11-21-2010, 08:18 AM Thread Starter
Send a message via AIM to Kaiser
Mark 8 Bouncy Ride
My car just recently went from a wonderfully smooth ride to obnoxious bouncing on any bumps. Since it's air ride, I thought maybe a sway bar or similar piece could be broken or unhooked. I've also noticed, and am unsure if it's related, that the driver side of the car sits about 4 inches lower than the passenger side when the car is off. While running its level.
Kaiser is offline
post #2 of 9 (permalink) Old 11-21-2010, 08:55 AM
'94bird's Avatar
Is it still getting to normal ride height?
1994 Ford Thunderbird 4.6 SOHC........Air silencer delete, muffler delete (LOL), and smoked tails......SOLD!
Current: 1987 Lincoln Mark VII LSC 5.0 HO 3.27 gears
'94bird is offline
post #3 of 9 (permalink) Old 11-21-2010, 09:26 AM
Roadrunnner's Avatar
Could be over inflated bags.
Will
Roadrunnner is offline
post #4 of 9 (permalink) Old 11-21-2010, 09:53 AM Thread Starter
It airs up to ride height. And over inflated? Hmm. Anyone know the correct ride height? It does sit up high, but it always has.
Kaiser is offline
post #5 of 9 (permalink) Old 11-21-2010, 10:25 AM
driller's Avatar
Measuring from the bottom edge of the wheel to the wheel well lip...
24.5" front / 24.25" rear
+/- 1/4"
driller is offline
post #6 of 9 (permalink) Old 12-01-2010, 08:41 PM Thread Starter
No ride height problems. Any other suggestions?
Kaiser is offline
post #7 of 9 (permalink) Old 12-01-2010, 11:01 PM
dDUBb's Avatar
It sounds like you have a Leaking airbag. The problem with a leaking airbag is that it might appear to be "fine" and inflate while driving .. but every time you hit a bump, it compresses and forces air out of the "leaking area", usually where the rubber folds over itself. One air strut alone will not hold up the weight of the entire front end of the car. Check to see if the bags appear to be darker in color towards the bottom, this would indicate a Blown shock. If you do replace the air struts, be sure to replace them as a Pair.
dDUBb is offline
post #8 of 9 (permalink) Old 12-02-2010, 12:22 PM
A bouncy ride is usually typical of a shock problem. The front shock is integral to the air bag and there were differences between Gen I and Gen II with the Gen II’s being stiffer but having lighter materials for less unsprung weight. (I vaguely remember reading that somewhere, I think).
I think you have multiple problems, but the solution will be the same: new airbags (or spring conversion).
I'm in a situation where my LSC is bouncy, but everything else works perfectly....
69 F100 LWB w/460 Engine
post #9 of 9 (permalink) Old 12-03-2010, 12:19 PM Thread Starter
I'm considering a spring conversion, but I'm not sure I want to drop $500 into the car. :-/ Thanks for the help.
Kaiser is offline
