steering issues - TCCoA Forums
post #1 of 1 (permalink) Old 12-28-2010, 07:29 PM Thread Starter
slick59's Avatar
steering issues
so my 94 xr7 all of the bushings and ball joints were changed on the front end, I got new tires and an alignment. Ever since, if I turn the wheel left it just stays left, wont pull itself back to center, Does it right too but not near as bad. Replaced the Rack and pinion with no help, had another place do another alignment with no real change. Changed brakes calipers brake lines and rotors, swapped tires from side to side. Still scratching my head
I can explain it to you, but I can't understand it for you
Tim
1994 Cougar 3.8L Supercharged
1990 Tbird Supercoupe
slick59 is offline
