QA-1 owners - TCCoA Forums
post #1 of 14 (permalink) Old 12-29-2010, 12:42 AM Thread Starter
Kelsey Smith's Avatar
Send a message via MSN to Kelsey Smith
QA-1 owners
I'm looking for info on going to a QA-1 setup, but can't seem to find much with a search (Hey, at least I tried). How much did they cost? How do they perform through the twisties? What kinds of adjustments are there? What did it take to install them? And so on...
Thanks in advance
"WHAT CONE?!?!
1997 T-Bird Sport, 'Interceptor' (12 ESP 2008-2012)- CAI, 2.25 duals, Flowmaster 40 series, Clear corners, BBK 70mm Throttle Body, TrickFlow upper intake, PI Intake, BBK adjustable fuel pressure regulator, LE stripes, Bullitt-style gauge faces. 18x9 wheels, Sniper tuned, 3,620 pounds
1991 Ford F250 - Air restrictor delete. Cat delete.
1991 T-Bird 'Interceptor II' (12 CP 2013-) - Race-prep, Full custom "interior", Carb'd 302, Trick Flow twisted wedge heads, stage 1 cam, Custom Koni coil-overs front, Koni yellows rear, Cobra front brakes, fuel cell, 18X9 wheels, 275/30 Hoosier A6, 4.11 T-Lok. 3000 pounds
2004 Toyota Solara SE - V6, Sport package, Muffler delete, 17X7 wheels, 235/50 Conti ExtremeContact DWS
Kelsey Smith is offline
post #2 of 14 (permalink) Old 12-29-2010, 04:15 AM
Thanks in advance
_95badbird has them in the front. I was considering using a set of cobra adjustables by kyb for the rear. Has anyone else done that?
post #3 of 14 (permalink) Old 12-29-2010, 09:12 AM
For the short time I ran them, they worked great. I use them for drag racing though.
They are 12 way adjustable, 90/10 valving(can be changed), fixed compression, I run 325 lb springs(will be going lower soon).....
They ran me right around 650 or so for the front set.
That was 500 or 550 for the shocks
60 or 70 for the springs
and another 40 or 50 for the adjusting wrenches, and I opted for the torrington bearings to make adjustments easier.
out back I will be running Koni adjustables.....
I believe another member by the name of mercutio runs them too.
But he does run autocross type events....let me see if I can find him for ya.
oh, installation was a breeze....easier than the stock settup(cause you don't need a spring comporessor)
and 1 big thing for me, it dropped roughly 20 lbs off the front.
post number 8 says he runs them too...mercutio
http://forums.tccoa.com/showthread.p...441#post949441
post #4 of 14 (permalink) Old 12-29-2010, 01:22 PM
He's since modified a set of Mustang coilovers to work. From what I've read QA-1's suck for autoX.
post #5 of 14 (permalink) Old 12-29-2010, 01:29 PM
hmmm, that i did not hear about....he hasn't logged in tccoa in about 2 years...
I wonder which ones he used.....as doing the mod your self does not seam to hard.....hmmm, this gives me an idea..
post #6 of 14 (permalink) Old 12-29-2010, 01:38 PM
http://www.sccoa.com/forums/showthread.php?t=103543
You even posted in that thread lol
post #7 of 14 (permalink) Old 12-29-2010, 01:40 PM
damn....lol
I guess I did......I forgot......i post too much.
post #8 of 14 (permalink) Old 12-29-2010, 02:17 PM
I would but this is XR7-4.6's Forum. I don't have access to edit it.
We'll leave him a nice mess to clean up.
gotcha....I guess yall don't have global admin rights?
that sucks..
post #9 of 14 (permalink) Old 12-29-2010, 02:19 PM
ugh lol
post #10 of 14 (permalink) Old 12-29-2010, 02:21 PM
that sucks..
Not global but Guitar Maestro did give me some of the most active forums including:
Video/Images, Miscellaneous and most of the marketplace forums.
I've got enough to keep me busy.
post #11 of 14 (permalink) Old 12-29-2010, 02:22 PM
ugh lol
what?
post #12 of 14 (permalink) Old 12-29-2010, 02:23 PM
Nothin... now lol
post #13 of 14 (permalink) Old 12-29-2010, 06:58 PM Thread Starter
Thanks a bunch for posting that link. Good and informative. Thanks again
"WHAT CONE?!?!
post #14 of 14 (permalink) Old 01-09-2011, 12:26 PM
I like this!
The set of konis I'm working up for the red car will go this way, I think.
I'm going to make a set of steel lower perches, so that I can use the stock springs; I don't like the upper perch shown for the smaller springs.
I want adjustable sport springs; they're just a little too stiff...
