Alignment issues - TCCoA Forums
post #1 of 2 (permalink) Old 01-09-2011, 03:27 PM Thread Starter
ROLLINTHUNDER's Avatar
Alignment issues
Im no front end expert by any means. I swapped the entire front end out of a 97 mark 8 into my bird when i did the motor swap. I have the Eibach pro kit springs on. It has kicked the tires way out at the bottom unlike they were before the swap. An alignment shop should still be able to straighten that out right? Does anyone know what sway bar end links I would use with the mark 8/thunderbird set up? Thanks
ROLLINTHUNDER is offline
post #2 of 2 (permalink) Old 01-09-2011, 04:42 PM
If the shop knows what they're doing they can straighten it out!
Get a quality set of end links, Ford, TRW, Moog.
