Strut Rod Bushing E9SZ3A187A (Frame side) - TCCoA Forums
post #1 of 42 (permalink) Old 02-10-2011, 11:22 AM Thread Starter
BlueEyes's Avatar
A while back I had a front poly bushing kit put in from SCP and a few months later had a clunk and had them look at the front end. The strut rod bushings (frame side) weren't the culprit but at the time the mechanic said they fit funny and had some slack.
So I took it in a few days ago to have them replaced with what everyone is recommending, the Ford OEM bushings.
Strut Rod Bushing Kit Frame Side: E9SZ3A187A
The shop called me and said it would be a few days until they got them, they were being shipped from Texas because Ford (dont know what dealer but I'll ask him) told him this bushing part number is now discontinued.
can anyone verify that it has/has not been discontinued from Ford?
That would really suck if it was discontinued since it apparently is the only one that is correctly made.
-Kelly
Fuelly
BlueEyes is offline
post #2 of 42 (permalink) Old 02-10-2011, 12:20 PM
From what I understand, the kit has been discontinued but you can still get the individual pieces of the kit separately.
post #3 of 42 (permalink) Old 02-10-2011, 04:31 PM
96PRLBRD's Avatar
I ordered the bushing kit (2) from the dealer yesterday. I'm not sure if it was that part number, but I'll let you know when I pick them up...
--> My most recent pics <--
96PRLBRD is offline
post #4 of 42 (permalink) Old 02-10-2011, 07:52 PM Thread Starter
BlueEyes's Avatar
Yea let me know what the part number is. I got the part number here;
http://forums.tccoa.com/showthread.php?t=99795
It is possible its the kit with bushings and washers and maybe you can get the bushings without the washers, would be nice to know for sure how to order these and if the kit is discontinued what is the part number for the bushings?
-Kelly
Fuelly
BlueEyes is offline
post #5 of 42 (permalink) Old 02-10-2011, 08:15 PM
96PRLBRD's Avatar
Oh, by the way, I was quoted $113 for each kit (I ordered 2). CDN that is.
96PRLBRD is offline
post #6 of 42 (permalink) Old 02-11-2011, 12:29 PM Thread Starter
BlueEyes's Avatar
Woah, last I heard about a year ago they were $70 per kit from Ford so I'll see when I pick up my car today. He didn't tell me the price but the quote for parts & labor was $227 (both sides) a year ago when they first told me about the issue with the bushings.
I just wanted to find out for sure so the suspension bushings thread can be updated if things have changed.
I may fire off an email to Bill at SCP and let him know about the problem with the poly bushings, maybe he can have whoever is making them take another look and redesign them to fit correctly.
-Kelly
Fuelly
BlueEyes is offline
post #7 of 42 (permalink) Old 02-11-2011, 01:51 PM
96PRLBRD's Avatar
Indeed this is the parts I received today. They had no problem getting them here in two days.
Pricey?, yes. Still available new from Ford?, yes. Worth it, according to lots of stories?, yes.
96PRLBRD is offline
post #8 of 42 (permalink) Old 02-12-2011, 04:50 AM
Gabealicious's Avatar
The kits are no longer in production, according to Courtesy Ford in Portland, but there are sources. I am ordering the frame-side bushings from fordpartsgiant.com. Less than $40, including shipping. They also show the kit available. If the bushings alone aren't enough, I'll be ordering the kit. Hopefully I can avoid that; it's not cheap!
Gabealicious is offline
post #9 of 42 (permalink) Old 02-12-2011, 02:55 PM Thread Starter
BlueEyes's Avatar
Ok this is what I found out. I pulled out my old estimate and it was $227 for 2 kits, no labor.
Now they are quoting me around $124 per kit.
You could go with just the bushings if the shaft and washers are in good shape still. The issue with the aftermarket bushings is they are one piece pop-in bushings. The Ford kits are a 2 piece bushing with a steel sleeve that goes through the bushings and washers on either end. the aftermarket bushings don't have the steel sleeve so they aren't as sturdy and have a lot more give.
The brilliant service writer only ordered one kit for me thinking it was a kit for both sides and didn't bother checking with Ford or asking. So now I have to wait until I get back from Utah to have that done.
-Kelly
Fuelly
BlueEyes is offline
post #10 of 42 (permalink) Old 02-12-2011, 07:27 PM
96PRLBRD's Avatar
I paid $113 per side yesterday. And I know a guy in parts who as far as I could tell gave me a bit of a deal....
Hmmm... my strut rod to frame bushings actually look good. Should I leave them and save some cash or should I replace them? 80K miles on them... but they look excellent! There is no noise from the front end either.
Most of the other bushings are visibly shot (cracked, etc.) so I plan on replacing the rest, but these actually look good!
So how do these compare to the bushings you guys have? Do yours look worse?
96PRLBRD is offline
post #11 of 42 (permalink) Old 02-15-2011, 11:50 AM Thread Starter
BlueEyes's Avatar
I think they look fine and would just hold onto the new ones you got for now. One problem they have which happened to mine is power steering leaks dripped on the drivers side bushing and ate it away. It literally liquefied the bushing.
-Kelly
Fuelly
BlueEyes is offline
post #12 of 42 (permalink) Old 02-15-2011, 01:51 PM
96PRLBRD's Avatar
So I dismantled my car yesterday and it turns out there are some very tiny cracks in the rubber. Since I have the $226 bushing kits (2), I've decided to replace the bushings since I'm replacing every other bushing in the front end (aside from the sway bar bushings).
I got the rest of my bushings today from the dealer so I will start putting that side back together later today... wish me luck LOL
96PRLBRD is offline
post #13 of 42 (permalink) Old 02-16-2011, 06:16 PM
ok so assuming someone wanted to change all the strutrod bushings on a MN12 car and the kit isnt avaialble anymore
can someone list what parts are available, the cost and part number?
and are any aftermarket suspension parts proven to be durable for these cars, tempted to
buy stuff from SCP but dont want to put that parts on only to have to replace with OEM later
2nazty is offline
post #14 of 42 (permalink) Old 02-16-2011, 06:18 PM
You'll probably have to go to Ford and see exactly what parts you can get.
post #15 of 42 (permalink) Old 02-16-2011, 06:41 PM Thread Starter
BlueEyes's Avatar
This is the best suggestion I can think of.
Check and see if the bushings alone have separate part numbers. I just cant see having to replace the whole kit every time, the bushings and washers and the sleeve unless they were severely damaged. But some times that's just how they package them.
Check the new bushing and see if there is a number on it.
-Kelly
Fuelly
BlueEyes is offline
post #16 of 42 (permalink) Old 02-16-2011, 07:03 PM
96PRLBRD's Avatar
These kits are still available, I bought mine last Friday from the local dealer. Who keeps spreading that rumor that these kits are obsolete. They are not obsolete people!!
The bushings do have separate part numbers and AFAIK are available. My ferrules are rusted together so I bought the kit, I had no choice.
96PRLBRD is offline
post #17 of 42 (permalink) Old 02-16-2011, 07:12 PM
Well, I asked Jon (93lx) about this in the fall when the rumors started. He checked for me and said they are indeed discontinued. I just checked the Tasca Ford site for the number and it came back as obsolete.
The kits might be still out there, but I think once they're gone they're gone!
post #18 of 42 (permalink) Old 02-16-2011, 09:42 PM
96PRLBRD's Avatar
OK, well I suppose they could be discontinued. I'm merely sharing my very recent experience that leads me to think otherwise.....?! My dealer didn't say anything though about them being obsolete...
Fortunately I shouldn't need to replace the bushings again as long as I own the car. I think it's highly unlikely I'll still have it 15 years from now ;-)
96PRLBRD is offline
post #19 of 42 (permalink) Old 02-16-2011, 09:48 PM
So the kits are gone but the individual bushings are still available right? I was hearing the opposite initially.
post #20 of 42 (permalink) Old 02-17-2011, 05:54 AM
tbird_boi82's Avatar
Send a message via AIM to tbird_boi82 Send a message via Yahoo to tbird_boi82
I dont see the big fuss i use the moog kit and they work fine ,I get an occasional clunk but hell its a 14 yr old car im not expecting it to be quiet.If i had to choose any sound id like to go away would be my doors squeeking at every bump.
97 4.6L
tbird_boi82 is offline
post #21 of 42 (permalink) Old 02-17-2011, 01:12 PM
i just ordered the kit today for my driver side, it was $157.20(list price). I called the dealer and they were available from a couple places within the region. I tried to get shock bolts but they wanted just shy of $50 for a set of 4 with washers, and they only came in packs of 4.
94 thunderbird 03 4r70w/mach1stall/jmod
kev93z is offline
post #22 of 42 (permalink) Old 02-17-2011, 01:23 PM
If you had proper rubber bushings you wouldn't have any clunk. Thermoplastic is the last material that should be used for the SR bushings, none of the flexibility of rubber and doesn't even share one benefit of poly (not that there's any in this case)
post #23 of 42 (permalink) Old 02-17-2011, 02:33 PM Thread Starter
BlueEyes's Avatar
Yes apparently there are still some sets around the country and most dealerships/parts places will check each others databases to find out who has them, and yes they are spendy.
I have to agree with XR7-4.6, and a clunk may not be the only side effect, its also possible to have vibration from ill fitting SR bushings. Personally I would rather spend the money and get the Ford ones, my original ones lasted 200k+ miles so I'm sure this second set will outlast me and/or the car. I am just hoping that the bushings will still be available and the hardware can be had from a junkyard.
The only reason I brought this up in the first place was so that if the bushings are still being made and not the kit that we could get a part number for the bushings if possible.
Speaking of door squeaks, Splattered and I put VBlok damping from CAE on my doors and under the sail panels in the rear quarter panels and the sound difference is amazing. In the back he put it on the panels that hold the speaker and inside as well so that part is double coated. The stereo sound is 1000% better already with very little distortion and echo now. Even with the stereo off and the windows rolled up there is a huge difference in road noise.
Next were going to do the trunk which should be another huge improvement for the subs and eventually do the whole inside but for the trunk and inside I'm just going to use Dynamat, it's a lot easier to work with and it will all be covered with carpet so it doesn't need to be as form fitted.
-Kelly
Fuelly
BlueEyes is offline
post #24 of 42 (permalink) Old 02-18-2011, 08:29 AM
PART NO: LIST PRICE:
E9SZ3A140A $12.38 front bushing at arm
E9SZ3A140B $12.50 rear bushing at arm
E9SZ3B271A $12.82 front bushing at frame
F7SZ3A225AA $6.41 rear bushing at frame
Mad1stGen is offline
post #25 of 42 (permalink) Old 02-18-2011, 09:09 AM Thread Starter
BlueEyes's Avatar
woot thank you.
-Kelly
Fuelly
BlueEyes is offline
post #26 of 42 (permalink) Old 02-19-2011, 04:32 AM
mh68's Avatar
I just ordered the lower shock bolts for $20 for a pack of 4 from my local ford dealer today. They'll be here tuesday.
Mike
mh68 is offline
post #27 of 42 (permalink) Old 02-21-2011, 05:50 PM
I just heard from Jason:
Hi,
The E9SZ-3A187-B is discontinued they are a few scattered out there at other dealers.The ferrules are obsolete also.I can get the 3a187 kit but the mark up on it probably would be high.
So, if you're thinking of replacing everything on the frame side and you can find the kits, you shouldn't wait!
post #28 of 42 (permalink) Old 02-21-2011, 07:12 PM Thread Starter
BlueEyes's Avatar
Hmmm... now I'm thinking I'll have mine replaced and order a spare set. If I never use them at least i can hold onto them and help out a friend some day when they can no longer be found.
-Kelly
Fuelly
BlueEyes is offline
post #29 of 42 (permalink) Old 02-21-2011, 07:23 PM
The_coop_08's Avatar
Send a message via AIM to The_coop_08
He is right, I just bought 2 sets of bushings (frame side and LCA side for 2 birds) about 2 months ago. Went in the other day to get rotors for my buddies ranger, and i asked if they could order washers for the bushings. They told me they were obsolete and all the other strut rod hardware was obsolete....even the bushings that i just bought
Silver 96 T-bird
Major Mods: Stage II PI head swap w/Stage II cams, Kooks headers, 2.5" exhaust with borla xr1, 9.5" Converter 3800 stall, Aluminum rear 3:73 gears, lots of suspension and bolt ons. 13" Cobra brakes, ss lines, lowered 1.6" on staggered saleens
Tim Barth tuned at MPH 274rwhp/298rwtq on 93
Compiling parts for Vortech build
95 SC 5 speed: bone stock for now
The_coop_08 is offline
post #30 of 42 (permalink) Old 04-24-2011, 06:53 PM
crash00527's Avatar
Send a message via AIM to crash00527
do we need 2 for each side on the frame side? i forgot.. i know i changed the ones for all the LCA's on both sides.
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
