Insolator Removal - TCCoA Forums
post #1 of 9 (permalink) Old 02-12-2011, 08:17 PM Thread Starter
Insolator Removal
I went to remove the insolater on a 1996 Tbird at the salvage yard. I didn't have the proper tools and was worried I damage it. Can anybody tell me how to approach? The salvage yard said they would not remove it.
Gerald Davis is offline
post #2 of 9 (permalink) Old 02-12-2011, 08:22 PM Thread Starter
Clarification
I'm replying to my own posting to clarify. I'm trying to remove the insolater or bushing in the subframe where it bolts to the frame.
post #3 of 9 (permalink) Old 02-12-2011, 08:24 PM
Can you tell us where on the car it is?
post #4 of 9 (permalink) Old 02-12-2011, 08:27 PM Thread Starter
Insolater Location
There are 4 insolaters/bushings that are on the four mounting points of the rear subframe where it bolts to the main frame. I need to replace one.
post #5 of 9 (permalink) Old 02-12-2011, 08:43 PM
I'm sure someone with experience will chime in. I hear they can be a real pain to get out.
post #6 of 9 (permalink) Old 02-12-2011, 09:02 PM
tbirdtess's Avatar
rear K?
Hi
Are you removing the rear K?
The front 2 bolts are the worst. The bolts can get stuck is the rubber bushings.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #7 of 9 (permalink) Old 02-12-2011, 09:39 PM Thread Starter
Already Removed
I've already dropped the subframe. It's hanging by the shock absorbers and setting on the exhaust.
post #8 of 9 (permalink) Old 02-12-2011, 09:48 PM
DLF
DLF's Avatar
The rubber mounts are pulled out of the bottom of the sub-frame.
HERE is a link to a pic of the Rotunda special tool that I use.
And HERE are some pics of the tool in use.
Before I got the tool I used to use a short piece of angle iron with a hole in it, sitting on a couple of sockets, to form a bridge. Then a piece of threaded rod and nuts to pull the mount out.
My Web Site
DLF is offline
post #9 of 9 (permalink) Old 02-12-2011, 10:07 PM
DLF
DLF's Avatar
FYI, The front and rear mounts are marked as such and are different from each other, so make sure you get the correct one to match the one that you need to replace.
My Web Site
DLF is offline
