18mm ratching wrench - TCCoA Forums
post #1 of 28 (permalink) Old 02-23-2011, 09:34 AM Thread Starter
is this the only tool that i would need other than a good socket set for the uca or is there more??? gonna replace both sides and lca too anything else??? not enuff money for the whole front end just uppers and lowers and maybe a couple of other things... hitting the bolts with pb once a week now for about a month, just waiting for the taxes to come in,,, im new to the whole suspension stuff, any good how to's with pics ????? been searching and searching and searching. reading and reading and reading, better to be knowledged about it b4 i begin right
rogggg1020 is offline
post #2 of 28 (permalink) Old 02-23-2011, 09:36 AM
Roadrunnner's Avatar
Balljoint seperater
Will
Roadrunnner is offline
post #3 of 28 (permalink) Old 02-23-2011, 09:46 AM
tbirdtess's Avatar
uppers
Hi
You shouldn't need a ball joint separator for the upper arm.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #4 of 28 (permalink) Old 02-23-2011, 09:48 AM Thread Starter
is that something i can rent or do i have to buy??
post #5 of 28 (permalink) Old 02-23-2011, 09:51 AM
Suggestion:
After you get the car up on the jack stands and get the tires off - take the calipers off the spindles and support them from the inner fender.
Next, take the lower shock mount bolt out.
Next - look at the top of the wheel well. There's three bolts up around the shock absorber top mount. Take those three loose, then pull the shock and spring out as one assembly.
It's a bit easier to get the UCA out and in without the spring in the way.
Be prepared - you may discover the tie rod ends, the strut rod bushings, and/or the sway bar end links and/or bushings to be shot. I'd grab the bushings (search here for the four part numbers, 2x each part # for a complete set) for the strut rod. Also, verify you can get the tie rod inner and outer ends, the sway bar end links, and the rack bellows in town in Moog or Motorcraft.
If any of the new fittings are greasable, I'd use a good quality moly based lubricant, instead of a pure lithium based lubricant. But that's me.
Next to last - Put the bolts in, snug them in, but don't tighten the ones for the control arms until you have the car on the ground.
LAST - GET THE CAR ALIGNED AFTERWARDS.
Yes, I capitalized that. I can NOT emphasize that enough!
RalphP is offline
post #6 of 28 (permalink) Old 02-23-2011, 10:07 AM
Another tool tip. Everyone needs a pair of the super jumbo sized channel-lock type pliers. I use mine all the time squeezing brake calipers, for plumbing, you name it.
Installing the new uca's, with these pliers you can easily squeeze the new ball joints right down into the proper position in the clasp knuckle (whatever it's called) without beating on it.
I didn't have too much problem getting the bolts in or out with the coil springs still in place either.
oldstick is offline
post #7 of 28 (permalink) Old 02-23-2011, 12:55 PM
V8ThunderCat's Avatar
All I needed was the wrench, a flat tip screwdriver to separate the end of the spindle the pinch bolt goes through, and some wire to hang the spindle from the fender with. I got a wrench kit that had 8 diffrent sizes on only 2 wrenches. Which helped because I think that the pinch bolt is a different size.
-Randy-
V8ThunderCat is offline
post #8 of 28 (permalink) Old 02-23-2011, 01:39 PM
MAMN12 Posse Member
JeffTBird93's Avatar
Patience, and lots of it. My lower control arms were a royal PITA to replace. I got the assembled Moog ones that already have everything in them. The inner bushing (control arm to frame) was so old and trashed that it had rusted itself to the camber bolt (or something similar to this, ie - it wouldn't come out). I couldn't hammer the camber bolt out due to not getting a good swing on the hammer. Ended up sawzall'ing the camber bolts out and replacing them as well.
~Jeff
*signed off
JeffTBird93 is offline
post #9 of 28 (permalink) Old 02-23-2011, 03:26 PM
*nod* Didn't say you couldn't, and I didn't remove them - but I DID loosen the top of the passenger side, and it made that side easier.
But if he's pulling the LCAs ANYWAY - pull those spring/shock combos and make it easier, why not?
RalphP is offline
post #10 of 28 (permalink) Old 02-23-2011, 03:31 PM
Umm, where did he say he was replacing the LCA's? I think he's only touching the UCA's. I too was able to get the bolt out with the springs in place but it took some wiggling.
-Randy-
post #11 of 28 (permalink) Old 02-23-2011, 03:59 PM
his second, and third sentence in his first post...
post #12 of 28 (permalink) Old 02-23-2011, 04:05 PM
Traveler's Avatar
LOL agreed! I have a drawer in my tool box specifically designated for "B.A.T" (Big Ass Tools!) My grandfather was a machinist in the navy, then operated his own manufacturing plant before retiring and doing a lot of his own work on his Motorhome. I inherited some huge tools!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #13 of 28 (permalink) Old 02-23-2011, 04:20 PM
RalphP is offline
post #14 of 28 (permalink) Old 02-23-2011, 07:25 PM Thread Starter
wow thanks alot ppl you dodnt know how much this means to me this helps out alot now any pics with labels to help me even more????
post #15 of 28 (permalink) Old 02-23-2011, 07:56 PM
Yeah, I just now noticed he mentioned the lowers also.
Haven't messed with those yet, but I figure you are going to need a lot more than an 18mm wrench in that case.
Lot's of B.A.N.s down there (Big Arse Nuts).
oldstick is offline
post #16 of 28 (permalink) Old 02-23-2011, 07:58 PM
Ah, I read the 1st sentence and then blah blah.
-Randy-
post #17 of 28 (permalink) Old 02-24-2011, 05:25 AM
Don't forget to remove the pinch nut and bolt completely. I felt so stupid after cussing and beating on the old one the first time. I only removed it because I was preparing to split the old control arm off. After I pulled the bolt and nut completely out the wheel assembly fell out on its own.
I'll be in there doing lowers very soon as the bushings are gone now.
Tom Gibson
1996 T Bird Pacific Green Metallic, gray cloth interior,3.8 motor.
I hate deer need parts..
My Jeeps are my hobbies; 77 Honcho,81 J20
HOOT is offline
post #18 of 28 (permalink) Old 02-24-2011, 09:08 AM
Yeah, I am stupid also. Didn't pick up on the fact the bolt fits through the big groove on the ball joint stud for a while.
oldstick is offline
post #19 of 28 (permalink) Old 02-24-2011, 07:08 PM
This is not that hard; southern cars rock! No rust.
You will need an alignment when you get done.
A two jaw and three jaw puller makes this really easy; advanced will rent you a set.
You are replacing upper and lower, so start with the bottom.
After you get the lower arm off, all the other sh*t just falls off when you unbolt it.
I wire the calipers to the top of the shock, since everything else is coming out.
You don't have to unbolt the calipers to do the top, but the bottom arm requires it. Just don't yank the brake line apart is the important part.
I put the front on stands; whenever you are working with a sway bar, you need both wheels off the ground the same, lol.
Putting a puller on the bottom ball joint is a lot better than using a pickle fork and a hammer, believe me.
You also need it to yank apart the swaybar endlinks, if you are replacing those. If you have a constant rattle, that's it.
You'll love the way it feels with all new stuff. TN roads are smooth; at least my end of the state, anyway.
My 96 suspension has been completely rebuilt, and I just added koni shocks, bracing, and a new exhaust; My commute rocks.
Grog6 is online now
post #20 of 28 (permalink) Old 02-25-2011, 01:02 AM
I didn't touch my calipers when I did mine. I did however have to unbolt the tie rod end from the spindle. That made it very easy to unbolt (or in this case is it un-nut?) the strut rod.
-Randy-
post #21 of 28 (permalink) Old 02-25-2011, 08:15 PM
Must not be anywhere near Memphis. Took our first trip up there recently and alignment shops must be like gold mines around that city.
oldstick is offline
post #22 of 28 (permalink) Old 02-25-2011, 08:28 PM
Why is it better? Ive done plenty of ball joints with my fork and never had a problem. One or two hits and its good.Most of the time its older cars and Im in the rust belt.
Will
post #23 of 28 (permalink) Old 02-26-2011, 12:36 AM
CrystalPistol's Avatar
Is that what it was?
CrystalPistol is offline
post #24 of 28 (permalink) Old 02-26-2011, 02:20 AM
Raptor22's Avatar
Originally Posted by RalphP View Post
Suggestion:
When I did mine last year I rebuilt my entire subframe on a bench, thats really easy...
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #25 of 28 (permalink) Old 02-26-2011, 12:08 PM
I couldn't get one out with a pickle fork at all.
Finally, it pulled the balljoint thru the hole, and the entire knuckle ended up on my bench getting pounded on with a hammer, to get the balljoint out of the knuckle. (insert much cursing here )
Bought a small 2 jaw puller, and they pop right out. The same one also fits the swaybar endlinks in the front.
Grog6 is online now
post #26 of 28 (permalink) Old 02-26-2011, 12:44 PM
I'm glad that I bought one of these even though I didn't end up using it for the tie rod ends. I did end up needing it for the sway bar links when I dug back into the suspension to replace the sway bar bushings. It also came in handy on some other bolt you probably wouldn't consider using it on but it really did the job. I just cannot remember what that bolt was. I did need it though when I went to do the lower control arms. The driver's side ball joint came out fairly easily with a 6 pound hammer but I needed the puller on the other side. I'm glad I had bought it for $16 rather than renting it.
-Randy-
post #27 of 28 (permalink) Old 02-26-2011, 04:33 PM
Raptor22's Avatar
Ive found those 2 jaw pullers are awesome, except that they tend to fly off at a high rate of speed when it finally gives way...
Raptor22 is offline
post #28 of 28 (permalink) Old 02-26-2011, 06:55 PM Thread Starter
thanks everybody for the info now time to get some labeled diagrams so i can picture all this out in my head....that hurts....lol
