rear LCA inner bushings - TCCoA Forums
post #1 of 48 (permalink) Old 02-23-2011, 02:48 PM Thread Starter
Traveler's Avatar
Is there a specific tool or method for removing the Inner Bushings on the rear lower control arms? A friend of mine is having a hard time getting it done.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #2 of 48 (permalink) Old 02-23-2011, 03:40 PM
jtsmith's Avatar
Subscribing
[urlhttp://www.explorerforum.com/forums/index.php?threads/bettys-i-want-to-be-a-mule-progress-log-thread.329322/]My Ride[/url]
Others linked in signature there.
jtsmith is offline
post #3 of 48 (permalink) Old 02-23-2011, 03:45 PM Thread Starter
Traveler's Avatar
hehe... That would be the friend.. Any luck yet Jon?
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 48 (permalink) Old 02-23-2011, 03:45 PM
DLF
DLF's Avatar
You can either use a press (which is the easy way)...
...or walk a drill around the rubber to remove the center of the bushing and then use a reciprocating saw to cut a lengthwise slit in the bearing shell, which makes it pretty much fall out.
My Web Site
DLF is offline
post #5 of 48 (permalink) Old 02-23-2011, 03:52 PM
jtsmith's Avatar
Press is a given
I have the press and bushing backers. The problem is the bushing flange is larger diameter than the LCA housing. I cannot place a backer for the bushing to press through.
jtsmith is offline
post #6 of 48 (permalink) Old 02-23-2011, 03:53 PM
jtsmith's Avatar
Notice how large the flange to the left is.
jtsmith is offline
post #7 of 48 (permalink) Old 02-23-2011, 03:53 PM
DLF
DLF's Avatar
Originally Posted by jtsmith View Post
Press is a given
Cut a bit of the bushing flange off on two sides.....
My Web Site
DLF is offline
post #8 of 48 (permalink) Old 02-23-2011, 04:00 PM
jtsmith's Avatar
Well, If Mike doesn't mind I was going to try an Air hammer with a flat chisel on the flange-hoping to go from side to side and knock it out. The fear was dinging them up to bad to use as is if the bushings will not budge.
If the chisel doesn't walk them out I guess it would at least bend the flange down so it could ba hacked off easier. I guess I just needed someone elses permission to break out the barbaric forces.
I'll take the plasma cutter to em if you all say it is the thing to do.
jtsmith is offline
post #9 of 48 (permalink) Old 02-23-2011, 04:02 PM Thread Starter
Traveler's Avatar
LOL Break out the barbaric forces Jon...
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #10 of 48 (permalink) Old 02-24-2011, 07:14 PM
This is how I took mine out; it mangles them, but they come right out.
The key is to use the air hammer to put three divots in the metal, pointing inward to the center, first.
Then, go around with the air hammer on the flange; if you start cutting the metal, drop the air pressure.
The first one took a few hours, using several methods; the other 3 came out in a flash.
They will not be reusable, and I have a Tennessee car; YMMV depending on corrosion.
Good luck; you need a fairly special jig to get them out with a press.
post #11 of 48 (permalink) Old 02-24-2011, 10:10 PM
This is how my old ones came out and they had no rust. They had to be mangled.
post #12 of 48 (permalink) Old 02-24-2011, 10:14 PM
Time for Mark VIII LCA's, bushings are cake on those.
post #13 of 48 (permalink) Old 02-24-2011, 10:20 PM
DLF
DLF's Avatar
Except that, other than me , no one makes replacement LCA bushings for the Mark VIII LCA's.
My Web Site
DLF is offline
post #14 of 48 (permalink) Old 02-24-2011, 10:24 PM
Just how fast do those mark bushings go bad?
post #15 of 48 (permalink) Old 02-25-2011, 01:28 AM Thread Starter
Traveler's Avatar
Actually I have Mark VIII lowers on my car now. But the car just isn't sitting the same. It is riding higher in the back since I put them in. Looks like the rear is stock height, and the front is lowered. Waited for the springs to settle, the spring isolators to settle, etc. But its still high in the back. So goin back to the stock arms. Jon is taking the bushings out and powdercoating them for me beforehand.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 48 (permalink) Old 02-25-2011, 01:54 AM
DLF
DLF's Avatar
That doesn't make sense to me. In order to get the same ride height on a T-Bird with Mark VIII LCA's you need to use a perch with around a 3/8" base.
Do you have a spring perch in your Mark VIII LCA's now?
If not, it's going to ride even higher with the stock LCA's.
My Web Site
DLF is offline
post #17 of 48 (permalink) Old 02-25-2011, 01:57 AM Thread Starter
Traveler's Avatar
Yep, got the perches and the LCA's in one purchase. They are good quality no complaints there. But the car just hasn't looked the same since I put them in.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #18 of 48 (permalink) Old 02-25-2011, 02:02 AM
DLF
DLF's Avatar
Which perches do you have? The aluminum ones with angled base or some of my UHMW perches? How thick is the base?
My Web Site
DLF is offline
post #19 of 48 (permalink) Old 02-25-2011, 02:03 AM
The poly isolators are said to sit higher than the rubber ones as well.
post #20 of 48 (permalink) Old 02-25-2011, 02:06 AM
DLF
DLF's Avatar
They do, which is why I dropped the thickness of the base on the perches I make from 1/2" to 3/8".
My Web Site
DLF is offline
post #21 of 48 (permalink) Old 02-25-2011, 02:15 AM Thread Starter
Traveler's Avatar
They are the aluminum ones with angled base. I did put poly isolators in at the same time. But have since removed them and replaced them with good condition rubber ones in an attempt to get the car to sit lower.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #22 of 48 (permalink) Old 02-25-2011, 02:21 AM Thread Starter
Traveler's Avatar
I even put the car on ramps, and loosened the inner control arm bolts to make sure the car wasn't being supported by torque on the bushings.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #23 of 48 (permalink) Old 02-25-2011, 02:24 AM
DLF
DLF's Avatar
Well, I didn't like those very much on my car, which is why I started making UHMW perches.
The orientation of the aluminum perches makes quite a difference in the ride height. As I recall, when I put them in, I had the thinner part of the base towards the center of the car, but I'm not entirely sure that I remember correctly.
It's a shame that you're putting the heavy cast iron LCA's back on, when all that you really needed was a decent set of perches.
My Web Site
DLF is offline
post #24 of 48 (permalink) Old 02-25-2011, 02:46 AM Thread Starter
Traveler's Avatar
Yea, I have the thinner part near the center of the car.
The weight doesn't make that big a difference to me. I'm not a professional racer, (drag or autocross). Just liked the idea of the non corrosive aluminum arms. The powdercoated steel arms will look good and won't corrode as badly as the exposed metal would. Besides, I already own the steel arms, and can't afford the UHMW perches. (well... can't justify it anyway)
I was thinking that if the aluminum perches were "offset" so the spring sat closer to the outboard of the control arm, that might help lower the car some. But that would require extensive remachining of the perch.. and as I said, I'm a poor man.
edit: Then again... if putting the original arms that the car came with back on doesn't lower the car to where it was... I'll be very put out! LOL
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #25 of 48 (permalink) Old 02-26-2011, 12:11 PM
You could cut the rear springs to even it out.
If you screw up, stock rear springs are cheap...
post #26 of 48 (permalink) Old 02-26-2011, 12:14 PM Thread Starter
Traveler's Avatar
I've thought of that, but I don't have stock rear springs. I have Eibachs. I'd hate to cut into a set of Eibachs.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #27 of 48 (permalink) Old 02-26-2011, 01:48 PM
I'm with you. I've never heard of them being too tall. Weird.
Somethings too thick, that's for sure.
Others are running eibach springs on mark lca's; anyone else had this issue?
post #28 of 48 (permalink) Old 02-26-2011, 04:23 PM
DLF
DLF's Avatar
I took a look at a set of Mark VIII LCA's today, and I think that the thinner part of the angled base should go towards the outside of the car, not the inside.
My Web Site
DLF is offline
post #29 of 48 (permalink) Old 03-11-2011, 10:06 PM
jtsmith's Avatar
Hey Mike!!!
jtsmith is offline
post #30 of 48 (permalink) Old 03-11-2011, 10:53 PM
Hey Mike!!!
So '91s had aluminum lowers? Or are those just powdercoated that color?
