Rack Play - TCCoA Forums
post #1 of 4 (permalink) Old 03-14-2011, 05:55 PM Thread Starter
Bay_Bird93's Avatar
Rack Play
Yesterday, I replaced my inner/outer tie rods and lower control arms with motorcraft and moog parts. Went to get it aligned at work and noticed the new passenger side inner tie rod had some play. Double checked to make sure it was nice a tight, and found that the play is actually in the rack which attaches to the inner tie rod. Is my rack bad or is there a worn bushing or something causing this?
'97 Lincoln Mark Viii LSC - Stock
'93 Ford Thunderbird - Splitport & M5r2
'64 Chevrolet Impala SS - Stock
Bay_Bird93 is offline
post #2 of 4 (permalink) Old 03-14-2011, 07:27 PM
Sounds like it's time to replace the rack.
post #3 of 4 (permalink) Old 03-14-2011, 07:40 PM
slick59's Avatar
pita to rebuild the rack anyhow, just replace it. get a whole new unit with new inner tie rods.
I can explain it to you, but I can't understand it for you
Tim
1994 Cougar 3.8L Supercharged
1990 Tbird Supercoupe
slick59 is offline
post #4 of 4 (permalink) Old 03-18-2011, 06:47 PM Thread Starter
Bay_Bird93's Avatar
Well that sucks. Ill just roll with it until the motor is out and put in a new rack then.
