Always check your Moog boxes from Rock Auto - TCCoA Forums
post #1 of 9 (permalink) Old 04-12-2011, 09:06 PM Thread Starter
LOLA's Avatar
I believe I've seen this mentioned here before but thought I'd bring it up again.
I ordered left & right lower control arms from Rock Auto last week and got them Sat. I'm heading down to a friends place tomorrow to do the whole front suspension. I decided I's better check the boxes. Both Moog boxes but one was a Moog with a greaseable ball joint and the other one a TRW with a sealed ball joint.
The Moog uses a castle nut with cotter pin and the TRW uses a lock nut.
Quite honestly the TRW looks like a better LCA than the Moog. Well at least I got a left & a right. I could have ended up with two lefts or two rights.
LOLA is offline
post #2 of 9 (permalink) Old 04-12-2011, 09:52 PM
Could you post some pics?
~Rick
TCCoA Sig
post #3 of 9 (permalink) Old 04-12-2011, 10:25 PM
I got a right lower last week. moog box was opened previously. Had a TRW arm with the lock nut that I couldn't get on so I went back to the OE lock nut. I think the TRW nut was crushed too much.
BLOWN38 is offline
post #4 of 9 (permalink) Old 04-13-2011, 05:48 AM
I have the exact same situation with the pair I ordered for my Mark VIII a few months ago.
I'm just not going to worry about it and install them as is.
69 F100 LWB w/460 Engine
post #5 of 9 (permalink) Old 04-13-2011, 06:17 AM Thread Starter
LOLA's Avatar
That's what I'm doing.
LOLA is offline
post #6 of 9 (permalink) Old 04-13-2011, 06:47 AM
One thing I do like about the Moog lowers is the castle nut vs. the lock nut that comes with the TRWs. I find it much easier to get the nut on and torqued down when the ball joint isn't spinning in the spindle with the nut as I try to tighten it. On a side note, the way I found to get the lock nuts on is to use a C-clamp to compress the ball joint into the spindle then heat the spindle up real well with a torch, obviously being careful to avoid the ball joint. Once it cools I use a little WD-40 on the lock nut as it goes on with an impact.
post #7 of 9 (permalink) Old 04-13-2011, 10:28 AM
T6Rocket's Avatar
I got two sets of Moog UCA's from Amazon at the same time, came in 3 different shipments, Amazonian style! One set was really thick steel, and the other was thinner like stock.
The boxes were labeled a little different, but I think they both said "Federal Mogul".
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #8 of 9 (permalink) Old 04-13-2011, 11:30 AM
my dormans were a "matched" pair.
post #9 of 9 (permalink) Old 04-13-2011, 11:49 AM
rmfk13's Avatar
Federal Mogul makes Moog IIRC
Rob
rmfk13 is offline
