Rag joint help on a Daily Driver.. asap help please - TCCoA Forums
post #1 of 31 (permalink) Old 04-17-2011, 09:19 PM Thread Starter
84cougarv8's Avatar
Exclamation Rag joint help on a Daily Driver.. asap help please
okay, so i have neglected to fix a power steering issue for almost a year and a few days ago i went to turn right and heard a snap then my wheel was able to freee spin... after further investigation the rag joint has come off of my rack... my knowledge of the steering is minimal so i figured id better ask for opnions on if its shot or not... is there supposed to be a bolt through it? or how is it held onto the rack? this is a DD so fast responces would be super helpful!!
~Kyle~
Birdless! Looking for another though! Never should have gotten rid of the 94!
84cougarv8 is offline
post #2 of 31 (permalink) Old 04-17-2011, 09:27 PM
Roadrunnner's Avatar
Pics would help. Can you tell if its broken where it mounts or the joint itself?
Will
Roadrunnner is offline
post #3 of 31 (permalink) Old 04-17-2011, 09:30 PM Thread Starter
84cougarv8's Avatar
i didnt take pics... should have though!! its stuck at work... i dont think its broken, it's jsut like it can loose or apart from the racks splines.... very odd just a big clunk and i looked at it and it was just chillin about an inch from the splines does a bolt hold it into the rack'ssplines?
~Kyle~
post #4 of 31 (permalink) Old 04-17-2011, 09:35 PM
It should be collapsible. So grab another bolt for the rag joint and try to pull it back out. Be sure to line up your steering wheel correctly first
Will
post #5 of 31 (permalink) Old 04-17-2011, 10:31 PM
Paddycake's Avatar
yes 2 bolts on rag. one holds it to the steeringwheel side one holds it to rack side.
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
post #6 of 31 (permalink) Old 04-17-2011, 11:24 PM
tbirdtess's Avatar
modded
Hi
Here is a picture of my modded steering shaft.
I hope you can see it.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #7 of 31 (permalink) Old 04-17-2011, 11:57 PM
What was blacked out?
Will
post #8 of 31 (permalink) Old 04-18-2011, 03:28 AM
EvilMooseofDoom's Avatar
That was a Government-redacted photograph. He had a classified ID number, and the name of the Grassy Knoll shooter printed on the crossmember, so of course they had to black it out.
Yes, I hate my Lincoln. Ask me about it sometime.
My Drivetribe garbage:
https://drivetribe.com/u/ivrqNaWFWj_...SaGpcKvLTz6v9w
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
EvilMooseofDoom is offline
post #9 of 31 (permalink) Old 04-18-2011, 06:12 AM
lol
Will
post #10 of 31 (permalink) Old 04-18-2011, 01:27 PM Thread Starter
84cougarv8's Avatar
So can anyne tell me an aprox. Size and if I need a nut or just a bolt? Gonna try to tet this goin again tonight
~Kyle~
post #11 of 31 (permalink) Old 04-18-2011, 01:32 PM
Make sure not to let the wheel spin. If you do there is a good chance you'll 'over-turn' the wheel and break the clock spring.
coolhandzep is offline
post #12 of 31 (permalink) Old 04-18-2011, 02:55 PM
While we're talking clock spring, is there a procedure on how to ensure the steering wheel is "centered" when installing a new rack?
Assume the wheel got turned by mistake while the rack was out... :-(
69 F100 LWB w/460 Engine
post #13 of 31 (permalink) Old 04-18-2011, 03:30 PM
There may be a method, but I am not aware of one.
If that happened to me, I would remove the clock spring and reassemble making sure it is centered.
Usually I tie the wheel to the seat frame with a strap or rope while it is 'free'.
post #14 of 31 (permalink) Old 04-18-2011, 07:30 PM
The clock spring assembly has directions printed in the plastic:
"Rotate ccw until tight, then about 2 3/4 turns cw till the marks on the case line up."
Theoretically, your steering wheel should be level there.
I just happen to have one laying here beside the computer, lol. ( Thanks, Splattered!)
post #15 of 31 (permalink) Old 04-18-2011, 09:23 PM Thread Starter
84cougarv8's Avatar
upon further investigation i snapped it!! i feel special... thankfully my parts car's was not broken, i figure by the looks of it, it'll last about 6 months, so that will give me time to save up for the stainless steel one!! so i have a long week ahead of me!!!
~Kyle~
post #16 of 31 (permalink) Old 04-19-2011, 01:30 PM
90coug's Avatar
Nm..................
'95 SC
90coug is offline
post #17 of 31 (permalink) Old 04-19-2011, 01:36 PM
Anyone got a link to the stainless joint? Or is it the DLF piece?
post #18 of 31 (permalink) Old 04-19-2011, 01:49 PM
DLF makes a bolt on piece but it can be duplicated using a flaming river joint and a small length of modified shaft. DLF's part is a good price though
post #19 of 31 (permalink) Old 04-19-2011, 02:47 PM
huh huh huh (beavis and butthead laugh)....he said 'joint'....
post #20 of 31 (permalink) Old 04-19-2011, 04:24 PM
DLF
DLF's Avatar
Yup, anyone can do it, if you want to buy at least 18" of stainless DD shaft.
My Web Site
DLF is offline
post #21 of 31 (permalink) Old 04-19-2011, 08:52 PM
...DLF's part is a good price though
I looked into this recently; unless you're a machinist, and/or can get the right metal for free, it's much cheaper.
Steel Joint vs rubber and rivets; hmmm...
post #22 of 31 (permalink) Old 04-19-2011, 08:58 PM Thread Starter
84cougarv8's Avatar
the thing that worries me about this, is the joint won't be the weak link anymore so i wonder what would be..
~Kyle~
post #23 of 31 (permalink) Old 04-19-2011, 09:51 PM
DLF
DLF's Avatar
The same thing that always was, the break-away joint under the dash.
My Web Site
DLF is offline
post #24 of 31 (permalink) Old 04-19-2011, 11:40 PM Thread Starter
84cougarv8's Avatar
oh.. good deal well i will be orderin it soon
~Kyle~
post #25 of 31 (permalink) Old 04-21-2011, 05:48 PM
tbirdtess's Avatar
Hi
Well I don't have the part anymore!
I can post a newer picture.
351W 2bbl.
C-4 Auto
3.90 open rear
post #26 of 31 (permalink) Old 04-21-2011, 06:01 PM
Your welcome grog I used the flaming river joint because I had some serious clunking going on and didn't know where it was coming from so I figured being all original up front it was all going to get replaced and I replaced the rag joint. The shop that did the cutting and drilling of the bar said it was real tough stuff so you had better have some good tools to cut it. YOu get enough bar for like 4 peoples rag joint mods when you buy 18".
post #27 of 31 (permalink) Old 04-21-2011, 06:31 PM Thread Starter
84cougarv8's Avatar
OKAY! so i got the rack out fine and dandy.... i got the rag on the steering shaft... on the rack people on here are saying that the 90* fitting is a pain.... i understand now.... i ended up takin the thing off the first time and now i cannot get it to go back on for shat!... everything else is flowin except for the pump pulley itsself..... any advice while were on the topic
~Kyle~
post #28 of 31 (permalink) Old 04-21-2011, 06:41 PM
DLF
DLF's Avatar
Closer to 8, it only takes a bit more than 2" of DD shaft per joint.
My Web Site
DLF is offline
post #29 of 31 (permalink) Old 04-22-2011, 03:41 AM
Even better man what kinds of tools did you use to cut drill and dimple them. If I want to hot rod like the ole skooler got to start with some good tools. Let me know what is some good stuff to buy if you want to be able to handle materials like these shafts.
post #30 of 31 (permalink) Old 04-22-2011, 10:41 AM
DLF
DLF's Avatar
Nothing really special.
A quality back-frame hacksaw (I've got to get a metal-cutting bandsaw!).
A lathe to true the ends after cutting.
I made a jig to ensure that the hole/dimples are drilled in the correct place.
A good drill press and quality drill bits.
Cutting fluid (an absolute requirement when drilling SS).
And a bead blast cabinet to finish the job.
My Web Site
DLF is offline
