rear control arm - TCCoA Forums
post #1 of 9 (permalink) Old 04-28-2011, 10:48 PM Thread Starter
NeedAbirdinVA's Avatar
Send a message via AIM to NeedAbirdinVA
rear control arm
So I have replaced everything on my front suspension.....I'm now looking at replacing everything in the rear but I can't find rear upper/lower control arms. I've looked at a few places...no luck. I know I can get away with just bushings in the rear but I'm trying to rebuild my '91 bird.(I'm going to do the same for my '89 SC) So where can I buy rear control arms? I plan on using rubber bushings and not the poly bushings from SC performance. Help? lol
Chris
'89 SC 5-speed SCP down tubes,muffler delete [email protected](sold) '94 Rose Mist Lincoln Mark VIII..Custom downtubes,muffler delete,gloss black cougar rims.(Now lives in my '91) '91 Thunderbird
V6 AKA The UnderBird.... cone filter, Custom down tubes to highflow cats,magnaflow muffler to turndowns in the middle of the car(LOUD), Vogtland 1.6 springs, poly bushings, '89 SC seats, '95 bird Sun visors, '95 bird radio, Chrome '97 sport rims with 255/55/16's... [email protected](mid 14's now)(skinnys,removed pass. seat,door panels and center console and advanced timing)
NeedAbirdinVA is offline
post #2 of 9 (permalink) Old 04-28-2011, 11:02 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
http://www.fordparts.com/Commerce/Ca...WLK+LH7viyyDAr
This should get you started. Just scroll down. These parts can get pricey quick. Good luck!
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #3 of 9 (permalink) Old 04-28-2011, 11:11 PM
LOLA's Avatar
Yep. when he sees what they cost he'll be keeping his old ones. $400 a piece for the lowers and $290 a piece for the uppers. Hell you can buy a whole MN12 for just what the control arms cost.
LOLA is offline
post #4 of 9 (permalink) Old 04-28-2011, 11:20 PM Thread Starter
Just saw the prices.... eh, gotta do what ya gotta do to have a nice running mn12 =) I'm replacing the rear along with an 8.8 with 3:73 gears. It's going to hurt the wallet and piss off the g/f but...well, eh. lol Thanks for the quick response guys..I'll be seeing some of you guys at Carlisle,PA !
post #5 of 9 (permalink) Old 04-28-2011, 11:45 PM
My suggestion, if you're paying that much?
Get the lower spring seats from DLF to fit your springs in a Mark VIII set of LCAs, pull the control arms from a Mark VIII in the wrecking yard, and rebush them.
Or get a set of TBird/Cougar control arms (hey, they're $12.50 each at the local pick/n/pull!) and rebuild those.
Grab the rear knuckles for disk brakes while you're at it, with the hubs, and redo the bearings. While you've got it apart.
That way, you can redo the bushings one a weekend or so, get everything ready, and swap it en masse.
RalphP is offline
post #6 of 9 (permalink) Old 04-29-2011, 12:14 AM
I can't see why you would need new control arms for the rear unless they're rusted beyond belief, bent or otherwise damaged in some way.
I'd just pull them off, give them a good cleaning and fresh paint, put in new bushings and call it a day.
post #7 of 9 (permalink) Old 04-29-2011, 08:37 AM
DLF
DLF's Avatar
Well, no one but me makes bushings for the Mark VIII LCA's.
OP, There's no reason to change out the LCA's and UCA's, just change the bushings.
All you're doing is wasting money.
My Web Site
DLF is offline
post #8 of 9 (permalink) Old 04-29-2011, 12:35 PM Thread Starter
Thanks for the advice guys, I'm just going to get the bushings then.
post #9 of 9 (permalink) Old 04-29-2011, 12:54 PM
You can get poly Cobra RLCA bushings to work in the Mark VIII LCA's
