95 Mark Spring Conversion done! Now ABS light solid... - TCCoA Forums
post #1 of 12 (permalink) Old 04-29-2011, 10:33 PM Thread Starter
Send a message via AIM to Kaiser
So I just complete a spring conversion on my Mark, and it's not falling down (yet). The problem is that my ABS light stays on solid now. The only wires I cut go to the ride height sensor (3 of them). What should I look at first? I'm thinking maybe I jarred something loose by mistake.
Kaiser is offline
post #2 of 12 (permalink) Old 04-29-2011, 10:51 PM
Pics of the cut wires? There's really nothing that can disable ABS in the wheelwells except the sensors.
post #3 of 12 (permalink) Old 04-29-2011, 11:13 PM Thread Starter
I'll try to get some pics tomorrow morning. That's what I was thinking, so I'm not sure if it's coincidence or maybe I really screwed something up.
Kaiser is offline
post #4 of 12 (permalink) Old 04-30-2011, 05:00 PM Thread Starter
Here are the wires I cut. This is the height position sensor for the air ride. I cut and taped all of these wires.
Kaiser is offline
post #5 of 12 (permalink) Old 04-30-2011, 05:20 PM
Not seeing the picture.
However if you check the sticky in the brake section for the procedure, you can get the codes from the ABS computer to tell you exactly what to look for. The ABS test plug is by the passenger headlight.
post #6 of 12 (permalink) Old 04-30-2011, 06:31 PM
DLF
DLF's Avatar
Why would you cut the wires? You could have just unplugged the sensors, and then sold them.
My Web Site
DLF is offline
post #7 of 12 (permalink) Old 04-30-2011, 06:36 PM Thread Starter
I wasn't really interested in selling any of this stuff. It's all so old I wouldn't feel comfortable with the integrity of the items.
Kaiser is offline
post #8 of 12 (permalink) Old 04-30-2011, 07:12 PM Thread Starter
I paper clipped the ABS test plug and got error 31. I'll have my dad help check the wiring when he comes here for my wedding. Thanks for the suggestions, guys.
Kaiser is offline
post #9 of 12 (permalink) Old 05-01-2011, 07:41 AM
Roadrunnner's Avatar
I understand not selling things you feel to be old or junk, but why cut the wires?
Will
Roadrunnner is offline
post #10 of 12 (permalink) Old 05-01-2011, 08:30 AM Thread Starter
I couldn't get the plugs out, and I was tired of dealing with it.
Kaiser is offline
post #11 of 12 (permalink) Old 05-01-2011, 01:57 PM
Code 31 is for LF wheel speed sensor open circuit. Check to make sure it is plugged in first, and if it is, replace the sensor. Sometimes when you take the suspension apart if you put too much tension on the ABS sensor wire, it can break inside and look fine, but won't work.
post #12 of 12 (permalink) Old 05-02-2011, 10:37 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Why did you cut all of those wires? You only have to cut one to get rid of the message in the info center. I think its green/black. I always just zip tie the factory connectors to the frame when I do coil conversions, this way the customer can always switch back later a little bit more easily.
-Rob
Rob is offline
