Rear Upper Control Arm Bushing Install - TCCoA Forums
post #1 of 10 (permalink) Old 06-04-2011, 11:28 AM Thread Starter
chris g's Avatar
Send a message via Yahoo to chris g
Lightbulb Rear Upper Control Arm Bushing Install
well guys i'm doing my rear uppers this weekend and this is mainly for anyone who might have questions on it... the arm itself is easy to get out,, the bushings well i've searched and alot of people say to get them pressed in,,but this is how i did mine...took the arm off, drilled out the rubber inside material, then used a torch to heat up what was left so it was slippery enuff , then i took my trusty 3lb hammer knocked out the inner metal bushing till only the sleeve was left.. took a sawsall cut a slit in the outer metal sleeve and knocked it out with a screwdriver and said hammer.. hope this helps someone ......not sayin this is the right way just how i did it..
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #2 of 10 (permalink) Old 06-04-2011, 01:16 PM
I cut a piece of 1/4" steel, bent it into a C shape, and used it to hold the arm from collapsing as I pressed it out and in.
I hate using torches on suspension components.
post #3 of 10 (permalink) Old 06-05-2011, 08:14 AM Thread Starter
chris g's Avatar
yea,,, i know what u mean,, it turned out well though..
chris g is offline
post #4 of 10 (permalink) Old 06-05-2011, 11:28 AM
Usually I just heat the outside of the metal shell with a propane torch, the rubber burns itself out of the shell.
mercenvy is offline
post #5 of 10 (permalink) Old 05-20-2012, 01:16 PM
Based on the ideas of others, here is a full easy install for those who need it start to finish.
http://www.youtube.com/watch?v=x7rJ4tVNFPk
TwoTone Loser is offline
post #6 of 10 (permalink) Old 05-25-2012, 06:52 PM
Torinocator's Avatar
Awesome tutorial BTW.
Use a tool, don't be one...
-Mark
1997 Thunderbird LX 4.6L
1970 Torino GT 351C 4V
...................................GT
Torinocator is offline
post #7 of 10 (permalink) Old 05-26-2012, 11:23 AM
rbrown's Avatar
Ha I made my stuff too. Using exhaust pipe adapters.
I will have to go look at Quickset dead-bolts.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #8 of 10 (permalink) Old 05-26-2012, 01:44 PM
Quickset Deadbolt shroud. My hat's off to you!
I would NEVER have thought to try that!
(The guy who used various sockets, braces, and an air chisel to remove the old and install the new ... )
RalphP is offline
post #9 of 10 (permalink) Old 05-29-2012, 04:57 PM
Glad to help all. These suspensions are tricky, and anything else i do to it , I will make a video about it.
post #10 of 10 (permalink) Old 05-29-2012, 06:07 PM
I just did everything with a homemade press and a c-clamp. I've made do with washers and sockets another time, though!
~Rick
TCCoA Sig
