aftermarket k member - TCCoA Forums
post #1 of 6 (permalink) Old 06-14-2011, 06:30 PM Thread Starter
tehsilver95lx's Avatar
i seen a red aftermarket k member on a photo album and cant figure out were and who makes them
Beater lx,current mods: cold air,drilled and slotted rotors,glass pack muffler. Scrapped
Teal terror 94...trans slip and a fram air hog filter!
94 Sc :Cobra R hood,96-97 Front lights,3.73 Trac Lok,1" Raised top,5% OD Blower Pulley,CAI,Removed resonator,Gutted cats,No mufflers. "It roams around in a open loop speed density tune. killing small children and raping helpless mothers at night."
....THAT DOES NOT MATTER!....
tehsilver95lx is offline
post #2 of 6 (permalink) Old 06-14-2011, 07:36 PM
AJE(junk) or custom
post #3 of 6 (permalink) Old 06-14-2011, 07:38 PM Thread Starter
oh,have you delt with the aje?
post #4 of 6 (permalink) Old 06-14-2011, 07:39 PM
Earl's Avatar
AJE tubular K-member http://forums.tccoa.com/showthread.p...tubular+member I don't know if they still make them, they are neat, but IIRC they use a proprietary UCA/LCA setup, which could be problematic if some sort of widely available repalcement ball joints cannot be used with them.
Earl is offline
post #5 of 6 (permalink) Old 06-14-2011, 07:43 PM
Seen em, read about their failures, and observed their production run band aids. They've bent LCAs under the car's weight, stripped the threads out from the rod ends and have broken welds at the joints. Not to mention the weight savings is minimal.
post #6 of 6 (permalink) Old 06-14-2011, 07:49 PM Thread Starter
hmmmmmmmm because i have a v6,and its a 95 i seen that the 3.8 wont make a difference and you said they had problems with the ball joints? damn....might as well make a custom :P
