bushings - TCCoA Forums
post #1 of 10 (permalink) Old 06-15-2011, 11:54 AM Thread Starter
tehsilver95lx's Avatar
bushings
im torn on doing the ones that need to be replaced,or just doing the whole front end with this kit http://supercoupeperformance.com/par...spx?partId=241 has anybody used it with success?
Beater lx,current mods: cold air,drilled and slotted rotors,glass pack muffler. Scrapped
Teal terror 94...trans slip and a fram air hog filter!
94 Sc :Cobra R hood,96-97 Front lights,3.73 Trac Lok,1" Raised top,5% OD Blower Pulley,CAI,Removed resonator,Gutted cats,No mufflers. "It roams around in a open loop speed density tune. killing small children and raping helpless mothers at night."
....THAT DOES NOT MATTER!....
tehsilver95lx is offline
post #2 of 10 (permalink) Old 06-15-2011, 11:59 AM
I'm a firm believer in "while I'm there", so I would suggest doing as much as possible while you have the front end disassembled.
But just my .02 (and sometimes doing the "while I'm there" can lead to weeks of downtime... )
69 F100 LWB w/460 Engine
post #3 of 10 (permalink) Old 06-15-2011, 12:16 PM Thread Starter
thanks,i have a full shop at my disposal...will this be hard?
post #4 of 10 (permalink) Old 06-15-2011, 05:56 PM
Not really. Rusty bolts can be a PITA.
post #5 of 10 (permalink) Old 06-15-2011, 06:14 PM
Don't bother with poly bushings, especially on the strut rods. It's well documented that the only acceptable replacements are Ford OEM.
post #6 of 10 (permalink) Old 06-15-2011, 06:15 PM
My thoughts on this kit:
Includes:
  • Tie Rod Boots - You don't need them
  • Front & Rear Strut Rod bushings (new ferrules & 7/8" washers included) - Don't cheap out on these. Use OEM Ford only.
  • Front Sway Bar bushings 1 1/16" - You don't need to replace them and certainly don't use poly. They'll squeak like crazy. Get OEM rubber bushings if you're gonna replace them.
  • Rack & Pinion bushings (5/8" washers included) - You don't need them. I still have the original Rack & Pinion bushings on my car.
  • Lower Control Arm bushings - Don't waste your time replacing the bushings. If your going to do anything replace the whole LCA at once. If your LCA is in good shape then you certainly don't need to replace just the bushings.
  • Upper Control Arm bushings - Ditto
  • Shock Bump Stop bushings - I think he's referring to the rear shocks. You shouldn't need to replace these bushings just replace them when you replace the shocks. New shocks should come with a set of bushings.
  • Installation instructions - For what their worth ...
See this thread for part numbers and other members thoughts on the various parts.
My recommendation is to just replace the ones that need to be replaced.
post #7 of 10 (permalink) Old 06-15-2011, 10:43 PM
BlueEyes's Avatar
I have to agree with Trunk Monkey, I bought that kit about 5 years ago and still have half of the bushings, the ones I did put on the car have since been replaced by ball joints going out.
-Kelly
Fuelly
BlueEyes is offline
post #8 of 10 (permalink) Old 06-15-2011, 10:45 PM
Agreed but I have no noise whatsoever with my poly sway bar bushings, 2 years and 2-1/2 winters and all
post #9 of 10 (permalink) Old 06-16-2011, 10:35 AM
BlueEyes's Avatar
I've had poly sway bar bushings on the front for about 4-5 years and they've never made a sound, I have the ES grease-able ones though.
The rear ones I hear every once in awhile but only when it's cold and moving slow like over a speed bump where it moves the bar a lot.
-Kelly
Fuelly
BlueEyes is offline
post #10 of 10 (permalink) Old 06-16-2011, 11:36 AM
91bluecoupe's Avatar
I have ES Poly bushings also and no squeaks. But they are the greaseable ones.
91bluecoupe is offline
