rear suspension questions - TCCoA Forums
post #1 of 3 (permalink) Old 06-17-2011, 10:54 PM Thread Starter
chsplayer's Avatar
im sure this has already been covered but this is my question i have. i have to replace my brackets that connect to the frame and the rear suspension. the bushings that are on top where the bolt runs trough are completely gone. are these consider bushings or what i need to get them soon and dont know the correct name of the bushings in the rear end
chsplayer is offline
post #2 of 3 (permalink) Old 06-18-2011, 07:15 AM
DLF
DLF's Avatar
The stock sub-frame mounts consist of three part numbers, all of which are obsolete:
E9SZ-5D006-A (bushing front-2 required)
E9SZ-5D006-B (bushing rear-2 required)
E9SZ-5D001-A (upper retainer-4 required)
The bolts (N805747S100) are also obsolete.
The sub-frame brackets (E9SZ-5D022-A, E9SZ-5D022-B) are still available from Ford for ~$20 each.
If you need just one upper retainer, I'm pretty sure that I've got one in my garage.
See this post for another option:
http://forums.tccoa.com/showthread.php?t=128007
My Web Site
DLF is offline
post #3 of 3 (permalink) Old 06-18-2011, 09:13 AM
And, if my first visualization is correct (that you mean the upper control arm bushings), they're available in Moog and AC Delco. Moog # K8562, RockAuto has'em for $42.79 each.
Fordparts.COM doesn't list the Ford #, alas.
RalphP is offline
