Loose - TCCoA Forums
post #1 of 12 (permalink) Old 06-19-2011, 03:13 PM Thread Starter
tractorman1215's Avatar
Loose
My 95 ford thunderbird v8 front end is loose
i looked at it and the the top control arm busing was cracked and rotting away so from what i saw i need new bushings and proably ball joints
anyone have any suggestions on brands
thanks
Money invested 4,000+ in just repairs but its all worth it!
Dreams
5 speed swap, DOHC swap or PI, supercharger, true dual exhaust, wider tires, cowl hood. AND MUCH MORE!
tractorman1215 is offline
post #2 of 12 (permalink) Old 06-19-2011, 03:59 PM
thanks
Check the sticky at the top of this forum.
But to repeat, in case you have trouble finding it:
Motorcraft, Moog, or TRW for the upper control arms.
Ditto for the lower control arms.
Ford OEM only for the front strut rod bushing set.
Ford or Moog (or a few others) for the lower control arm strut rod bushings.
Tell the suspension forum to show ALL messages, and check out what the cheap eBay chinee crap does to your car.
RalphP is offline
post #3 of 12 (permalink) Old 06-19-2011, 05:08 PM
Another tip.
www.rockauto.com
And check the miscellaneous section for the 5% off code thread.
post #4 of 12 (permalink) Old 06-19-2011, 05:15 PM
Another tip.
www.rockauto.com
Naw, if the OP can't search - or even read the stickies - let'em pay that stupid tax
RalphP is offline
post #5 of 12 (permalink) Old 06-19-2011, 08:39 PM Thread Starter
Why....... I think i will get maybe orginal or the ones they sell at autozone
Dreams
post #6 of 12 (permalink) Old 06-19-2011, 08:42 PM Thread Starter
Ya but what about the ball joints
Dreams
post #7 of 12 (permalink) Old 06-19-2011, 08:44 PM
Didja read the sticky?
It's all explained, with part numbers, there.
Do some searching and you'll find out why to use ONLY the recommended parts.
RalphP is offline
post #8 of 12 (permalink) Old 06-19-2011, 08:45 PM Thread Starter
Do you know any place that sells full suspension kits that are good not the cheap sh**
Dreams
post #9 of 12 (permalink) Old 06-19-2011, 08:47 PM
Nope.
But to repeat what's been said before, the Moog #s for all but the strut rod to frame bushings are in the sticky, take those numbers and find them at RockAuto, order from RockAuto with the current discount code (again, search for that), and you've got your kit.
Pick up the rubber bushings for the strut rod to frame at Ford, using the #s given.
Be VERY careful to not damage the ferrules when you take the old strut rod to frame bushing set apart.
RalphP is offline
post #10 of 12 (permalink) Old 06-19-2011, 08:54 PM
Roadrunnner's Avatar
You give younger people everywhere a bad name. You have been told to SEARCH in every thread you created and you continue to ask the same question over and over. One last spoon feeding junior. The ball joints are made into the control arms as in they come with it. Replace as a pair ie upper on left means replace upper on right also. With me so far? Now if you had searched you wouldve found out the reason why everyone has told you to buy quality goods. Cheap crap or no name crap is junk and doesnt hold up. At least glance at the stickies
Will
Roadrunnner is offline
post #11 of 12 (permalink) Old 06-19-2011, 11:56 PM
1996Project-bird's Avatar
From one "young" guy to another, I know it's easy to buy the cheaper stuff, but if you look at what you're paying for, it's actually cheaper to buy good stuff once rather than cheap stuff twice or 3 times. I've been lucky enough to have this site and this group of people to guide me and many others in the right direction. Just know that many have forgotten more than you or I know on the subject. Trust a lot of the advice on this site, most of it is very good.
1996Project-bird is offline
post #12 of 12 (permalink) Old 06-20-2011, 01:54 PM Thread Starter
Yes i read them okay i posted those things before i read them and how can i give teens a bad name everywhere im only one person and actually im nicer and more respectful then 95% of the teenage population. I just like to ask questions i know its bad habbit and im trying to work on it i just finished reading sticky and thank you guys for the advice. Also for your information im an Technical High School Student and im in automotive technology so i know how to work on suspension and what the parts are so no need for explaing it to me i got it
Dreams
