suspension 101- vogtland's - TCCoA Forums
post #1 of 27 (permalink) Old 07-23-2011, 02:58 PM Thread Starter
thunderclaw's Avatar
i have a set of 1.6" drop vogtland springs i just installed on the the rear. it came to my attention -lookin at tunk monkey's gallery- that he installed the spring with where the coils are closer together up. since mine had no instructions i instaled them with coils closer together down.
did i installed backward?
will this affect ride quality?
any info greatly appreated
thunderclaw is offline
post #2 of 27 (permalink) Old 07-23-2011, 03:10 PM
It is nice
Yea, that is backwards. I thought I had done the same thing when I installed mine because I was hearing unusual sounds but they were in correctly when i re-checked was just settling and dust shield bent I think don't remember. I'm pretty sure the diamater of the top and bottom of the spring were the same just by eyeballing them if I remember right, the isolators on both sides are the same; so the isolators most likely wouldn't get damaged with an upside down spring. On a different note, I have no idea what problems having the spring upside down would cause with how it rides or sits though, but you should just flip them the right way to make sure.
91CougarLS is offline
post #3 of 27 (permalink) Old 07-23-2011, 03:37 PM
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
I have been told it doesnt matter as long as they are the same diameter on top and bottom. I dont see where it would make much difference but I have been wrong before.
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
post #4 of 27 (permalink) Old 07-23-2011, 03:56 PM
Post or PM me a much larger picture of your avatar Thunderclaw and I'll tell you the right answer.
post #5 of 27 (permalink) Old 07-24-2011, 10:38 AM
Originally Posted by thunderclaw View Post
i have a set of 1.6" drop Vogtland springs I just installed on the the rear. It came to my attention -lookin at tunk monkey's gallery- that he installed the spring with where the coils are closer together up. since mine had no instructions i instaled them with coils closer together down.
LOL Thanks for the Avatar info.
Yea, they're backwards. 91CougarLS could tell you for certain. He has run his in both orientations.
No, I don't think it will affect ride quality. They'll compress the same weather they're right side up or upside down.
The front ones are flattened on top so it's easy to tell which end is up on them.
The back ones should be printed with Vogtland and the part number. Put this side up. Like so ...
post #6 of 27 (permalink) Old 07-25-2011, 12:21 PM
It is nice
pm sent LoadedButane, I had mine the correct way always; I thought I didn't when I heard noises but it was not related.
post #7 of 27 (permalink) Old 07-25-2011, 02:09 PM
fenix's Avatar
Did you use the stock shocks or they are the sport ones??
PACO.
I wish I can have enough time and money to work on my thunder.
“The phoenix hope, can wing her way through the desert skies, and still defying fortune's spite; revive from ashes and rise.”
fenix is offline
post #8 of 27 (permalink) Old 07-25-2011, 10:29 PM Thread Starter
not sure who you were askin, but i used koni yellows in the front and tokico blues in the back for now.
post #9 of 27 (permalink) Old 07-28-2011, 11:34 AM
I got paranoid after reading this thread and had to look at mine............I put them on right!
post #10 of 27 (permalink) Old 07-28-2011, 11:51 AM
fenix's Avatar
I see in one of the trunk monkey pics have a front spring with a black shock I was wondering what kind is it ???
PACO.
fenix is offline
post #11 of 27 (permalink) Old 07-28-2011, 12:20 PM
Go to his signature and click on "HERE"
post #12 of 27 (permalink) Old 07-28-2011, 04:18 PM
fenix's Avatar
I check it already thanks a lot rodeo joe!!!
PACO.
fenix is offline
post #13 of 27 (permalink) Old 09-14-2011, 09:22 PM
fenix's Avatar
I have my vogtland springs and tokicos for my front suspension I was wondering if I have to take apart the old strut apart to take the top mate strut they look ok kind dry but not tear o rip or if is better to get new ones and which are the best Monroe ,moog ,o kyb????
PACO.
fenix is offline
post #14 of 27 (permalink) Old 09-14-2011, 10:31 PM
Replace the tops! The old one's aren't worth saving and it's more trouble than it's worth to swap them.
It's not a STRUT!
Do MN12's have Shocks or Struts?
Our cars have SHOCKS.
The difference is subtle, but I'll explain it the way I understand it.
Struts are typically if not always an integral part of the suspension. Meaning they not only support weight, but control both castor and camber. A car that uses struts will have a lower control arm with a ball joint at the spindle mount. But at the top of the spindle mount there will be two bolts that attach firmly to the bottom of the strut. The top of the strut then mounts inside the strut tower. By moving that top mounting point forward, backward, inward and outward, you can alter the castor and camber to adjust the car to your particular needs.
Our cars on the other hand have a SLA (Short/Long Arm) front suspension. There is a lower and an upper control arm with a ball joint on each for the spindle. The shock then simply mounts to the lower control arm and the top of the shock tower.
Because our cars are of a unibody design, there is some inherent flex between the tops of the shock towers. The STB locks the tops of towers together to help make sure everything stays parallel. Hopefully this clears up some misconceptions.
Author: Sir William
post #15 of 27 (permalink) Old 09-14-2011, 11:36 PM
fenix's Avatar
Yes I read that before I forget about the shocks and struts I just go by the name they have listed in the orealys auto parts catalog now by other side wich ones are better from my last statement????
PACO.
fenix is offline
post #16 of 27 (permalink) Old 09-14-2011, 11:54 PM
All.
None.
Something different.
What kind of driving and what kind of ride do you want?
The best ride for firmness and control may not be the best ride for "Yah, I make that trip across Death Valley twice a week" softness and float
Give some parameters, and you can get some answers.
HOWEVER - I'd opt for Tokiko adjustable so you can dial in what you want.
Or KYB adjustables.
Now, me? I just ordered a pair of KYB GR-2s for the front, and have a pair of ACDelcos for the back (don't ask. Or do. Answer is "Hell, they're good and they're cheap and I don't motorcross, autocross, quarter mile, or roundy round - and have you SEEN what passes for streets around here nowadays?" )
RalphP is offline
post #17 of 27 (permalink) Old 09-15-2011, 06:13 AM
fenix's Avatar
Well I just want a good suspension for a daily driving and good handling when is required I start upgrading suspension and brakes because maybe later like a lot ppl around upgrade engine and trans but first what is first.
I have the blue tokicos and 1.6 vogtland springs already and planning to get the bilsteins for the rear ( of course when my paycheck letme do it) I don't know if that combo is good for my aplication .
PACO.
fenix is offline
post #18 of 27 (permalink) Old 09-15-2011, 09:34 AM
IMHO It'll be fine for daily driving and good handling just keep some tires on the car that have a decent amount of sidewall to provide some cushioning. I didn't notice enough of a difference to make the car undesirable for daily driving until I put the 18's on with 40 and 45 side walls. Now I feel every pebble in the road. Ideal for road feel not so much for daily driving.
Get the OEM tops they should still be available. You'll really be pleased with the Bilsteins.
post #19 of 27 (permalink) Old 09-15-2011, 09:45 AM
Mgino96tbird46's Avatar
Get the OEM tops
What are you referring to when you say this? I couldn't understand what is going on here in the last few posts.
Mgino96tbird46 is offline
post #20 of 27 (permalink) Old 09-15-2011, 10:40 AM
fenix's Avatar
I have a 17 bullit wheels from a 05 stang as soon I have my front suspension ready I'm goin to go to the rear and do the hub swap redrilling my rear hubs here were I work have a machine shop and they goin to do it for me for free(thats great cuz every rear hub is around 150) and upgrade to cobra calipers front and rear I'm goin to try to make a treat about it of my whole upgrade with pics as soon I have everything.
PACO.
fenix is offline
post #21 of 27 (permalink) Old 09-15-2011, 10:49 AM
fenix's Avatar
T.M. is referring to the top shock mounts the ones hold the front spring and the shock together.
And I call to various ford dealers and they say don't have it in production no more.
PACO.
fenix is offline
post #22 of 27 (permalink) Old 09-15-2011, 01:44 PM
Yah, I ordered KYB tops for Ruby Jean. $35 each at RockAuto.
NLA from Ford.
RalphP is offline
post #23 of 27 (permalink) Old 09-15-2011, 02:02 PM
fenix's Avatar
Yes i was thinking about kyb the best choice thanks Ralph!!
Who's ruby jean???
PACO.
fenix is offline
post #24 of 27 (permalink) Old 09-15-2011, 03:21 PM
Who's ruby jean???
LOL
Ruby Jean is the name of his car. Ralph's one of those people who names their vehicles ...
post #25 of 27 (permalink) Old 09-15-2011, 03:26 PM
fenix's Avatar
Yeah that was what I thinking lol actually I name mine fenix as the bird who reborn from the ashes cuz if you see how it was when I get thatch car in my hands was a real and I'm not kidding a real mess.
PACO.
fenix is offline
post #26 of 27 (permalink) Old 09-15-2011, 07:48 PM
Who's ruby jean???
Almost as Trunk Monkey says - actually, Ruby was named by my wife
It seems to fit. She's a Southern Lady ... every screw and nut on her takes a minimum of effort to crank loose, unlike those Northern cars that take a cutting torch for almost anything.
RalphP is offline
post #27 of 27 (permalink) Old 09-16-2011, 12:10 AM
fenix's Avatar
That's cool man I wish my wife was like that but mine is from the north and I'm agree sometime I just want trow the towel away. LOL
PACO.
fenix is offline
