front suspension noise - TCCoA Forums
post #1 of 3 (permalink) Old 08-06-2011, 02:11 PM Thread Starter
Question front suspension noise
hi, looking for some help, with a squeaking noise on front end of my t-bird. have replaced almost entire front end with new parts.uca,lca,ball joints,inner,outer tie rods, struts,rack pinion, all bushing,end links etc. have grease every thing that has a fitting. squeaking noise is constant, never stops. and the squeaking noise was there before , i started to repair the front end. any ideas of were to look first, or what to check. thanks.
nc96t-bird is offline
post #2 of 3 (permalink) Old 08-06-2011, 02:18 PM
pettyfog's Avatar
heh.. you must have just missed it
Try this:
http://forums.tccoa.com/showthread.p...77#post1386577
I sure learned something
While I have your attention, Right after never overlube, ...never assume jointed parts have enough grease in them even if new.
pettyfog is offline
post #3 of 3 (permalink) Old 08-06-2011, 03:29 PM Thread Starter
hi, thanks for the info. i read that thread also. i have read about 100 different threads about the front end issues/problems. before i decided to post. i also forgot to mention that i replaced the sway bar bushing with engergy suspension bushing with greaseable fitting. thanks
