rebuilding Koni adjustables - TCCoA Forums
 1Likes
  • 1 Post By Chris_Murder
post #1 of 25 (permalink) Old 09-12-2011, 09:42 PM Thread Starter
Earl's Avatar
I think that when this car had cut springs on it, the Koni adjustable shocks on the front saw some serious abuse (because of the cut springs) When they are set to their softest setting, the front of the car really floats and bounces, like a car with bad/worn out shocks would do.
Set at half way, they are noticably stiffer, but there is still quite a bit of bounce to them.
All the way firm, they don't float so much, but they don't feel nearly as firm as they should.
I want to add a set of Koni shocks to the rear of the car, but new konis in the rear and old beat up konis in the front wouldn't be an ideal setup.
Should I just spring for a full brand new set and swap the new inserts out for the old in my front shock housings?
Earl is offline
post #2 of 25 (permalink) Old 09-12-2011, 09:48 PM
Can you even get them? I thought Koni quit making them, and the last ones in the USA were bought earlier this year.
If you can, then yep, go for a full brand new set. If all you can get is inserts, then that. If you can't get anything - well, I just got a pair of KYB GR-2 for my Cougar.
RalphP is offline
post #3 of 25 (permalink) Old 09-12-2011, 09:49 PM
The front inserts are discontinued, the only option is to rebuild them.
KYBs suck compared to konis SOFT setting
post #4 of 25 (permalink) Old 09-12-2011, 09:59 PM Thread Starter
Earl's Avatar
OK, so I can rebuild them? That's just as good I guess...are the rears still available?
hmmm Maybe Tokico blues with whatever those red lowering springs are that come with them are the way to go (who makes those anyway?)
Earl is offline
post #5 of 25 (permalink) Old 09-12-2011, 10:05 PM
Tokico
post #6 of 25 (permalink) Old 09-12-2011, 10:29 PM Thread Starter
Earl's Avatar
Tokico
I am really leaning toward running those all the way around.
Earl is offline
post #7 of 25 (permalink) Old 09-12-2011, 10:38 PM
The Great Obucina's Avatar
i bet those cut springs had a lot to do with it. run it with springs that dont suck and go from there.
"Booyah". Stu Scott.
The Great Obucina is offline
post #8 of 25 (permalink) Old 09-12-2011, 10:38 PM
The front tokico shocks are bouncy on the highway, that's my biggest dislike with them. Though I must say I like the linear rate springs a lot (though mine have a higher rate now that they're cut)
post #9 of 25 (permalink) Old 09-13-2011, 12:42 AM
Lol hey Earl I'll trade you my tokico blue front shocks for those worn out konis with their adjustment knobs if your ever interested
SILVRBRD likes this.
post #10 of 25 (permalink) Old 09-13-2011, 09:39 AM Thread Starter
Earl's Avatar
How do you like that setup front /rear?
Earl is offline
post #11 of 25 (permalink) Old 09-13-2011, 11:48 AM
smoothed and filled red pearl 94
94MN1246's Avatar
Send a message via AIM to 94MN1246
ive got the tokico blues front and rear on cut linear rate lowering springs and love it. no bounce whatsoever at high or low speed... however, anything more than a mild bump is almost jarring. theyve been on there probably 4 years and still feel great. id highly recommend the tokicos (though not over real shocks ie: konis)
-John
MAMN-12 Fringe Member
94MN1246 is offline
post #12 of 25 (permalink) Old 09-13-2011, 03:40 PM
I like it overall however I wish I could have afforded to hop onto the koni train before it left the station for good. Same with bilsteins. I wish I had konis all around for adjustability. For a spirited daily driver I love the tokico setup it works really well, firm but not overly harsh, however I drive my car like a maniac and I'd love to have adjustable shocks for future track events or if/when I branch off into autocross. I've even been looking at cobra convertible adjustable rear shocks and qa1's for the front. For now the tokicos meet and exceed my needs however they won't always.
post #13 of 25 (permalink) Old 09-13-2011, 03:44 PM
I shouldn't have said bouncy in regard to the front blues on mine but they are a bit floaty on bumps on expressways after ~70mph or so. They are pretty much the best shocks on the market for these now though. The rears I have no complaints about what so ever, in fact I planned to get the Koni front inserts when they were available and leave the rears as is.
post #14 of 25 (permalink) Old 09-13-2011, 10:03 PM
I have konis on all four corners on my dd and it rocks.
This car has the full JL bracing set, with racecougars RSTB.
With standard V8 33gg springs, it's a beast. I think sport springs might loosen fillings with these...
I had ordered a set for the car with the sport springs, but they cancelled on me.
Chris, you beat me to offering to buy the worn out ones, lol.
Earl, I'd get them rebuilt. Nothing else will feel like that, trust me.
The gabriel shocks I had were great for ~6 months, lol.
I bought a set of OEM sport shocks (NOS) to go with my sport springs, since koni has abandoned us.
If I can't deal with those, I'll buy a set of koni racing inserts, and adapt.
post #15 of 25 (permalink) Old 09-14-2011, 01:28 AM
Even though my tokico rear shocks are noticeably firm I'm thinking about upgrading to 03/04 cobra IRS tokico D series adjustables for better adjustability at the track. Muhahaha!
post #16 of 25 (permalink) Old 09-14-2011, 09:22 AM
I will be running non IRS Mustang rear shocks in my car. Koni Adjustable Yellows.
Why?
Its lighter, and lower than most cars on here.
Will update on how they are once the car is back together.
post #17 of 25 (permalink) Old 09-14-2011, 02:38 PM
As far as I can tell the most platform specific part of those inserts physically are the way the shaft mounts to the shock mount/spring perch.
I'm thinking lately about making a pair of plates with a spherical bearing sandwiched in the center (same as what CC plates for strut cars use) to take a different insert and go in place of the stock shock/spring mount. Bonus would be the plates could be machined for aftermarket coilover mounts
post #18 of 25 (permalink) Old 09-15-2011, 07:41 PM
That's a great idea.
The hole in the existing mount is too small, as you've also noticed.
I'm wondering if I couldn't make a mount similar to the stock one, possibly recycling some parts, that would have the larger sleeve with a metal disc attached to keep it from going thru the mount; all encased in silicone rubber. (There are a lot of rtv rubber types out there...)
Making it fit aftermarket springs is a plus for sure.
It could even look similar to the stock one, if you wanted.
With our suspension, I don't think there's anything to be gained by having it adjustable; I need to look around sccoa.
For the lower, I think I have a set of shocks that will hold the inserts; I'll thread a cap to hold it in place, lol. I'm adding adjustable perches for sure.
For what the inserts cost, I could have a holder fabbed and x-rayed, lol.
The bottom adjustment for the double adjustable inserts is a problem on our cars...
post #19 of 25 (permalink) Old 09-28-2011, 04:29 PM
CrystalPistol's Avatar
Anyone who would trade well used Konis for even brand new Tokicos is "just not right" in the head.
I had adjustable Konis on my '85 T-bird since 1986 and I sold it in 2009 to make room, it had over 145K. Friend bought it, now it's up over 170K. I used the Konis on a medium setting Frt and Rear, the fronts were easiest to adjust with a knob. The rears you had to loosen and conmpress and twist a click.
I'm still not sure if it's the car I miss .... or my Konis? Damn fine shock, even with miles and years on them. If not broken or bent, they are likely better than anything you'll put on in their place.
JMHO. I too would trade some new Tokico Blues for them.
CrystalPistol is offline
post #20 of 25 (permalink) Old 09-28-2011, 06:46 PM Thread Starter
Earl's Avatar
Right or wrong...in the head...I would trade these straight across for a brand new (all four) set of tokico blues with the lowering springs they come with.
Earl is offline
post #21 of 25 (permalink) Old 09-28-2011, 07:21 PM
Black_Cat's Avatar
Knowing they don't make the KONI's anymore almost makes me want to take them off my cougar and put on some garbage shocks till Race days My KONI's have maybe 10 miles on them lol.
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
2008 BMW 535i Premium Sport Package
Black_Cat is offline
post #22 of 25 (permalink) Old 09-28-2011, 08:34 PM Thread Starter
Earl's Avatar
Or I would trade them for just the Tokico Blues, and keep my jjjj springs .... so long as they where new, unused
Earl is offline
post #23 of 25 (permalink) Old 09-29-2011, 12:28 AM
Well .... I hope you know I was joshin' about the "not right in the head" deal.
I just can't imagine KONIs being that wore out. At 140+K if I cranked mine down it was damn stiff and that Tbird just had std V8 springs. When we first got the car new even it "floated".
If I was close and had a set of Tokico Blues laying around, I'ld likely make you happy, then I'ld take those Konis and something better for the rear and my extra JJJJ springs and put all that on my '95. I might would even repaint those Konis.
I have Tokico Blues on my '92 Sport with the slightly cut stock Sport springs, they ain't bad but most of the stiffness is iin the springs and roll bars. Mine did not come with "lowering springs"?
You leave the offer out there, someone is gonna bite.
Later ........
post #24 of 25 (permalink) Old 09-29-2011, 12:42 AM
rbrown's Avatar
Hmmmmmm. Thinking.
Don't I owe you some pics of seats too.
(Still cannot move the darn car)
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #25 of 25 (permalink) Old 09-29-2011, 07:31 AM Thread Starter
Earl's Avatar
L
Originally Posted by rbrown View Post
Hmmmmmm. Thinking.
Oh yeah pics of seats would be great
Earl is offline
