What is This Rattle!? - TCCoA Forums
post #1 of 38 (permalink) Old 09-26-2011, 09:31 AM Thread Starter
N8tiveJuggalo17's Avatar
Hey All, I made a video of a mysterious rattle thats comming from the drivers side front end that i cant seem to pinpoint, It was there when i first bought the car & since then I replaced UCA,LCA, sway bar Endlink, Inner & Outer Tierod end. I drove on a gravel road so you can hear the noise contstant. It does it on regular roads too when i drive over deformities in the highway. Below is the video. Anyhelp would be great thanks.
Jeremy
---Jeremy
N8tiveJuggalo17 is offline
post #2 of 38 (permalink) Old 09-26-2011, 10:21 AM
renello79's Avatar
Did you consider strut mounts?
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #3 of 38 (permalink) Old 09-26-2011, 10:23 AM
Why? His car doesn't have any.
Upper shock mounts, OTOH ... are on their way to me from RockAuto so I can get rid of a similar clunking on my car. Along with lower spring seats for the front. And sway bar bushings and end links (the only things I HAVEN'T swapped out on the front of this car ... )
RalphP is offline
post #4 of 38 (permalink) Old 09-26-2011, 11:00 AM
renello79's Avatar
I have front struts and it's still a MN12 so am I missing something here????????
Phrum Steve
sold, sadly
post #5 of 38 (permalink) Old 09-26-2011, 01:35 PM
yes, they are called shocks.
post #6 of 38 (permalink) Old 09-26-2011, 02:18 PM Thread Starter
Yes i replaced tho's also when i replaced the other things. Any Idears? Im lost lol
---Jeremy
post #7 of 38 (permalink) Old 09-26-2011, 02:33 PM
The struts run from the lower control arm forward to the K-member.
The SHOCKS are mislabeled "struts" by most people.
If you have a strut mount, then you've not got a MN12/FN10 chassis.
RalphP is offline
post #8 of 38 (permalink) Old 09-26-2011, 02:56 PM
Yep, a coilover shock does not a strut make. It's just one part of MacPherson design and not the part that effects the actual articulation of the suspension components that makes a MacPherson strut unique.
post #9 of 38 (permalink) Old 09-26-2011, 04:52 PM
It is nice
sway bar rattling maybe?
91CougarLS is offline
post #10 of 38 (permalink) Old 09-26-2011, 04:55 PM Thread Starter
If it was the swaybar wouldnt it be hear on both sides? is sounds as if it is just in the driver side wheelwell :S
---Jeremy
post #11 of 38 (permalink) Old 09-26-2011, 05:00 PM
It is nice
probably just start tugging on things would be easiest to tell, check the dust shield maybe and plastic wheel well for loosness or something hitting, etc. hard to tell just from the sound alone... good luck
post #12 of 38 (permalink) Old 09-26-2011, 07:02 PM
renello79's Avatar
Sway bar links can go one at a time, I just did my driver side sway bar link upper control arm and passenger side inner tie rod end cause they were all bad
Phrum Steve
sold, sadly
post #13 of 38 (permalink) Old 09-26-2011, 08:49 PM
Depends. If it's, say, the swaybar bracket bushing, it'd only rattle on that side. Ditto if it's just one end link bad.
Those are easy enough to replace (and don't affect alignment!) I'd consider doing the whole set - both end links and both bracket bushings.
RalphP is offline
post #14 of 38 (permalink) Old 09-26-2011, 11:08 PM Thread Starter
Ill crawl around underthere tomaro and check the calipers & sway bar brackets, I replaced every suspension component on both side within the past year lol. Hopefully its just the bracket and i could just tighten it down right?
---Jeremy
post #15 of 38 (permalink) Old 09-26-2011, 11:23 PM
On Ruby Jean, the rear swaybar bracket BUSHINGS are rotting out (hey, it's 21 year old rubber back there!) Not sure about the front, but I'll be swapping those ALSO when I do the end links.
I've just got to decide if I want to swap the front spindles for the better brakes now, and do the end links - or do them twice (once now with the 1991 spindles, again when I change to the later model spindles.) Decisions, decisions.
RalphP is offline
post #16 of 38 (permalink) Old 09-27-2011, 12:03 AM
skorchmp's Avatar
Listened to the video several times, it almost sounds like the brake pad rattle I had at one point, but IIRC mine had a higher-pitched sound..
It's a long shot, (read: wild guess) but since you're going to be under the car, poke a finger up near the top of the brake caliper, and feel if the rattle clips are in the caliper. First T-bird I bought had new pads but the PO had left the clips out. Sounded like an aluminum extension ladder loosely strapped to the undercarriage, but did it on rough surfaces and bumps only. (And while researching what could be causing it, I stumbled across this neat website called TCCoA. You may have heard of it, lol. )
Madness does not always howl. Sometimes, it is the quiet voice at the end of the day saying, "Hey, is there room in your head for one more?" www.despair.com
skorchmp is offline
post #17 of 38 (permalink) Old 09-27-2011, 12:38 AM
Pretty simple if you have an upper control arm you have a shock....in this case it is a coil over shock.
post #18 of 38 (permalink) Old 09-27-2011, 10:13 AM Thread Starter
Might as well do it all at once, no need to do it twice. =)
Thats exactly what it sounds like too, When i get off work thats my purpose lol. Thats insane because i stumbled across that website and it is the best thing since individual cheese slices!
---Jeremy
post #19 of 38 (permalink) Old 09-27-2011, 10:22 AM
seawalkersee's Avatar
No sir. They are a modified strut. Kind of like the mustangs which are labeled from Ford as a modified mcphearson strut.
Look into the brake caliper/pad. Does anything change the noise? Like lightly touching the pedal? You most likely will not be able to pull on the end link and have it shake with the front up on the jackstand. That puts the front in a bind. You can try it on the grond and see what you have.
SWS
seawalkersee is offline
post #20 of 38 (permalink) Old 09-27-2011, 03:19 PM
But Ford labels these as coilover shocks, in fact there's not a single mention of macpherson to be found in one page of factory Ford sales or service literature.
The key word in "MacPherson strut" is strut...
A strut is a structural component designed to resist longitudinal compression. Struts provide outwards-facing support in their lengthwise direction, which can be used to keep two other components separate, performing the opposite function of a tie...
...An automotive suspension strut combines the primary function of a shock absorber (as a damper), with the ability to support sideways loads not along its axis of compression, somewhat similar to a sliding pillar suspension, thus eliminating the need for an upper suspension arm
...Again key word. Call it a "modified MacPherson coilover" if you wish but in terms of articulation the MN12 shocks do not function as a strut.
Mustangs use a what is called a modified MacPherson strut soley because the spring is under the LCAs, but they don't drop the "strut" monicker because they are still indeed struts.
post #21 of 38 (permalink) Old 09-27-2011, 04:53 PM
SWS
Not that it matters but I respectfully disagree. These are not any form of macpherson strut. They are coilover shocks. A strut would have a bearing on top and rotate and there would be no need for an upper control arm.
post #22 of 38 (permalink) Old 09-27-2011, 09:10 PM
Alan - I'm sorry, but my pedant has just kicked in.
Struts do NOT require a bearing on top and rotation. If they did, then how do our strut rods work? And what makes them "strut rods"? (Just to mull over a bit.)
A MacPHERSON strut does, ayep. Notice, two words there.
This is NOT to say the MN12 has a MacPherson strut front end. Matter of fact, AFAIK, the only thing MacPherson had anything to do with on my car is the rocker arm basic design ...
RalphP is offline
post #23 of 38 (permalink) Old 09-28-2011, 11:11 AM
CrystalPistol's Avatar
Thumbs up
To check for sway bar end link rattle, pull car on ramps, do not jack one side. You want to relax the bar, not load it with twist. Then simply "strike" the bar in an easy to reach portion with the palm of hand (or piece of wood). If the link or bushings are the reason for the rattle, you'll hear it then.
A "STRUT" as in "macpherson strut" serves as shock absorber and spring mount and axis upon which the front wheel spindle is steered left / right. It forms the third leg needed to locate the front wheel, the other two legs being the LCA (that incorporates a strut as part of it's makeup when the LCA itself has only one inner pivot point).
The "modified macpherson strut" used in FOX body T-Birds and Cougars and Mustangs and etc does not have a coil spring wound around it, the spring is elsewhere. It is a "STRUT" there as it forms that important third leg and the wheels are located and steered along it's axis. (My '1985 T-Bird's strut did not rotate inside a top bearing mounted to the fender well, the rotation for steering was allowed within the strut itself between the piston rod and lower body.)
MN12s have "coil over shock absorbers" up front. The spindle and wheel is located and steered upon axis located by unequal length control arms. The coil over shock unit only provides a means of mounting the spring upon the shock absorber which dampens the spring and suspension movements.
CrystalPistol is offline
post #24 of 38 (permalink) Old 09-29-2011, 01:08 AM
rbrown's Avatar
Funny how this comes up from time to time.
Ford has called it a Strut. Parts stores label it as such as well.
http://www.oreillyauto.com/site/c/de...0077&ppt=C0035
I know just because a website calls something a strut doesn't make it so. But go into your parts store and argue that one.
By design they are a cross between a strut and shock.
From the sound I would think you could really pin it down. With the tire in the air, a jack stand under the car, move the tire back and forth. I would almost lay money on inner tie rods.
rbrown is offline
post #25 of 38 (permalink) Old 09-29-2011, 01:23 AM
If the spring was located between the LCA and K member and the shock was in the same location would it still be called a strut by so many? No? I didn't think so.
The definition of coilover isn't "strut". It's not a cross, it's not a hybrid, it's not modified, it's just a coilover shock.
Parts stores are a lousy source of info and I haven't come across any REAL Ford literature that has the front shocks labeled as struts, and yes I've looked.
post #26 of 38 (permalink) Old 09-29-2011, 11:02 AM Thread Starter
Mmmm Hmm, Well i check out my calipers yesterday and tried to wiggle everything but nothing would budge. I tried to tighten down the swaybar brackets and their snug, i stuck my finger in the caliper to try to move something but no go on that either, Im stumped lol.
---Jeremy
post #27 of 38 (permalink) Old 09-29-2011, 11:12 AM
Roadrunnner's Avatar
Are the anti rattle clips on the calipers?
Will
Roadrunnner is offline
post #28 of 38 (permalink) Old 09-29-2011, 11:35 AM Thread Starter
Not sure what those look like
---Jeremy
post #29 of 38 (permalink) Old 09-29-2011, 08:19 PM
It is nice
http://www.autozone.com/autozone/par...ier=78231_0_0_
^^ usually the rubber pieces broken/missing will make more of a clunk than a rattle but check those also
post #30 of 38 (permalink) Old 09-29-2011, 09:16 PM
nall_one's Avatar
yeah those tin things in the pic are the rattle clips. one for each side, in a hole in the center of the caliper, the shoes are squeezed in against them. i don't think you can see them without the tire off.
only thinking about it because the one on my driver-side caliper poped out a little and was making a really annoying grinding noise against my rim on my way home one night, i just took it out, hasn't rattled at all yet. ill pop it back in next time i have the brakes apart :P
nall_one is offline
