Got an alignment today, I'm told the adjustment is at its end - TCCoA Forums
post #1 of 6 (permalink) Old 10-05-2011, 01:37 AM Thread Starter
Cougar Pilot
BlackCat94's Avatar
Apparently the tie-rods are screwed all the way in?
I installed them myself from RockAuto (Moog) and they figured that I used the wrong parts, I would be surprised though. I asked what the solution to this was, I was told that they can always pull them off and cut them down.
I'm thinking there's a setting they missed or something else. I was told it's aligned for now but there's no more adjustment for the future.
Any ideas?
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #2 of 6 (permalink) Old 10-05-2011, 01:52 AM
I don't see how that would be possible unless it was the wrong parts but i'm no alignment guy so I could be wrong.
97 lx under construction
cordb is offline
post #3 of 6 (permalink) Old 10-05-2011, 08:28 AM
Some rebuilt racks have come with Mustang inner tie rods, that are longer than the MN12 ones, yielding this exact same situation.
Wouldn't surprise me if that was the situation.
RalphP is offline
post #4 of 6 (permalink) Old 10-05-2011, 09:15 AM
pettyfog's Avatar
And cutting them off is the easy, cheap and obvious fix.
Before you take it in next time, borrow a small angle grinder {though any driveway mechanic should already have one - VERY HANDY} buy a cutting disc for it.
Spray paint the thread/ lock nut area, unscrew the outers and cut about an inch off each side. You are removing threads you never will use.
pettyfog is offline
post #5 of 6 (permalink) Old 10-05-2011, 11:05 AM Thread Starter
Cougar Pilot
BlackCat94's Avatar
I replaced the rack at the same time, that explanation makes plenty of sense!
Thank you guys!
post #6 of 6 (permalink) Old 10-31-2011, 05:16 AM
I had the same problem when I changed my rack, I ended up using Mustang tie rod ends in lieu of cutting the t bird ones.
skootboy is offline
