What would be the cause of this? - TCCoA Forums
post #1 of 34 (permalink) Old 10-20-2011, 10:46 PM Thread Starter
Earl's Avatar
Recently, at highway speed (55-70 or so) I will get this strange side to side shimmy, it's like the car is floating left and right, almost feels like it wants to pull itself in one direction and then the other...could worn out shocks cause this? Everything is tight...alignment was done in june and I really don't drive the car long distances...so, not a lot of miles since the alignment...ball joints on both sides are a year old. Koni shocks are adjusted the same on both sides. Do tie rods fail? If so, do they show any symptoms beforehand?
Earl is offline
post #2 of 34 (permalink) Old 10-20-2011, 10:54 PM
Mgino96tbird46's Avatar
Sounds like tie rods to me. My gf's '95 BMW 318i was doing the same thing. The tie rods were on their way out and it was a matter of time till one let loose. It's a good thing I told her to have it fixed after I checked it out at first. Turns out I was right! Yes, tie rods can fail, thus causing a loss of steering ability.
Mgino96tbird46 is offline
post #3 of 34 (permalink) Old 10-20-2011, 11:09 PM
Roadrunnner's Avatar
Jack it up and shake down the front end. If you see movement in the tie rod their bad. If theyve never been done I gurantee you they are bad.
Will
Roadrunnner is offline
post #4 of 34 (permalink) Old 10-20-2011, 11:22 PM
The way I checked the tie rods was have someone or something hold one wheel and try to turn the other wheel (side to side). If there is any noticeable play and you see movement in the tie rods, then they'll likely need replacing.
post #5 of 34 (permalink) Old 10-20-2011, 11:28 PM Thread Starter
Earl's Avatar
And if a tie rod goes out, the car will pretty much steer itself hard left or hard right, right? Which is more likely to fail? Inner or outer? I know, I know...replace both...
Earl is offline
post #6 of 34 (permalink) Old 10-21-2011, 01:04 AM
I'd say "and the rack bellows", but both Duralast and Moog have failed on my car.
Which is a right royal pain, since you have to remove the outer tie rod from the inner to swap the bellows.
RalphP is offline
post #7 of 34 (permalink) Old 10-21-2011, 07:28 AM Thread Starter
Earl's Avatar
That's a new one for me what are the rack bellows?
Its been a while on these, can I change them in the driveway with hand tools? Any tips for not having dangerous alignment afterwards? I am trying to keep costs at parts and alignment only
Earl is offline
post #8 of 34 (permalink) Old 10-21-2011, 08:12 AM
the bellows are the rubber boots that collapse when sterring.
post #9 of 34 (permalink) Old 10-21-2011, 08:21 AM
The rubber bellows on the end of the racks. They cover the inside of the inner tie rods.
Well, !I! did. Didn't even need the fancy schemancy tie rod tool.
Best advice is to take the tie rods off as a single assembly, and put the two new ones together outside, keeping the same spacing from the inside shoulder to the outside post. With the slop, it'll be hard to match exactly, but you can get close enough you can drive (slowly and carefully!) to the alignment shop.
As another note, if you can afford the extra, Firestone DOES offer a lifetime 4 wheel alignment on our cars (locally it lists for $170 (!!!!!) ).
If you're just changing the outers - that's a waste of time, IMO, since you have to break those off to change the inners, but eh. With that, just break the nut free, spin the outer off the inner, verify the new outer is the same length from the shoulder (that the lock nut hits!) to the ball joint shaft is the same as the old one, put it on, and torque the castle nut to the right torque setting.
RalphP is offline
post #10 of 34 (permalink) Old 10-21-2011, 10:16 AM
Banned
91bluecoupe's Avatar
You guys have a lot of great ideas, but missed one important one.
It could be a steel belt starting to seperate inside of a tire.
I had it happen to me if you let it go long enough it will pull the tire apart.
Becarful driving high speeds until you figure it out.
91bluecoupe is offline
post #11 of 34 (permalink) Old 10-21-2011, 10:42 AM Thread Starter
Earl's Avatar
I am having the shop at work look into this and other issues, we will see...
Earl is offline
post #12 of 34 (permalink) Old 10-21-2011, 11:20 AM
Well, that shouldn't happen if you have decent tires on the car. 9.95/10, it's the tie rods.
post #13 of 34 (permalink) Old 10-21-2011, 01:56 PM
Banned
You can never know about a tire!
post #14 of 34 (permalink) Old 10-21-2011, 02:22 PM
1996Project-bird's Avatar
Tie rods are so easy to do. Take the inner off with the outer still attached, measure the length of the assembly and match the new inner and outer to that measurement. It will not be perfect and you will still need an alignment, but its closer that guessing it. I didn't need the tie rod tool either.
1996Project-bird is offline
post #15 of 34 (permalink) Old 10-21-2011, 02:37 PM
Checked the tire pressure?
post #16 of 34 (permalink) Old 10-21-2011, 06:45 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
My rear upper control arm to knuckle bushings have small amounts of slack in them. You can check it by jacking up the rear and pulling in and out on the top of the tire. If it moves in and out, there are some bad bushings on the upper arm. DLF makes a nice set of these, although I havent gotten any yet It is almost like the rear tries to steer a little bit on some uneven surfaces on the road. You should also check the whole front end over. It could be much more than tie rods. If it's an outer tie rod, it takes very little time to change. The inners suck slightly more since you have to remove the outer tie rod, the bellows, and then the inner tie rod.
For the most part, you can count turns on the outer tie rod while holding the inner tie rod shaft. This will get you very close to where it should be, usually. Ralph said that the best thing to do is replace both the inner and outer. This would be good since you can lay them side by side on the ground and adjust them as close as you can.
I had a problem when I installed an outer tie rod on my Bird a few weeks ago using the turn-counting method. The alignment was off enough to get my attention. I used a tape measure to measure the front and rear of the tires and made turns on that tie rod until it was right. The wheel is perfectly straight now with no pull. I believe the problem occurs because some tie rods come with a skinnier jam nut than stock. I think I may have used the stock jam nut with a tie rod that came with a skinny nut and thats where the problems occured. Anyway, just some ideas.
-Rob
Rob is offline
post #17 of 34 (permalink) Old 10-22-2011, 01:30 AM
My Black Cougar was following every line in the pavement, and I finally traced it down to a small bit of play in an inner tie rod.
My guy called me, because it was well below the limit for replacement; he thought I was nuts.
I had him drive it, and he didn't call back.
When I picked it up, he said that because of the suspension mods, I could feel that ~1mm of play in that tie rod end.
I have bracing all around, sport shocks, and konis; seems like you have mods too.
I have replaced all of the bushings on this car, tho.
The bushings at the inner end of the upper control arm on the rear can also cause the 'tail wagging' feeling, as can the irs to body bushings.
Have the shop check the shocks individually; one being bad can cause all kinds of problems with handling, even on the rear.
post #18 of 34 (permalink) Old 10-24-2011, 09:20 PM Thread Starter
Earl's Avatar
Alright folks, well, today they looked at it at work. Here's the verdict so far...right rear wheel bearing is bad...mechanic working on it says this is the worst he has ever seen...I didn't take the car home tonight, potentially unsafe, etc. It was swinging back and fourth pretty heavilly just driving to work this morning. Pretty scary. Also, the inner tie rods are shot. Outers are fine. FYI outer tie rods are obsolete and "unavailable"
So far those are the only discoveries related to this issue. There might be more worn out stuff, hopefully not, but if so, $$$$$$$ it's getting fixed.
In other news, the non functional slow speed variable assist issue that has been present since before I owned the car will be repaired. At the moment the theory is that it's a bad EVO module. More will be known once the car is safe for road testing.
The non-op cruise control will also be repaired.
Jeez I should have my mark viii driveshaft installed while I'm out spending money.
Next up after this will be to get a new lower door hinge, striker, fix the crack in the door jamb
Then Tokico blues all around
Then paint the whole car.
Earl is offline
post #19 of 34 (permalink) Old 10-24-2011, 09:28 PM
Raptor22's Avatar
Wow awesome, im glad to hear you decided to keep her.
The way I see it, I've put so much money in my car its cheaper for me now to just keep it and make it better. I'm not getting rid of it.
[-----[ Conner ]-----] ASE P2 Automobile Parts Specialist - P4 General Motors Parts Consultant
The Blunderbird - 1989 Ford Thunderbird
3.8L V6 / M5R2 / 145,005 miles
Thunderbird SC Suspension Swap - Eibach Pro-Kit
JBL Premium Audio Swap - JL CP108 Subwoofer
Resonator Delete - Magnaflow DI/SO Muffler - Custom 2.5in Exhaust
Raptor22 is offline
post #20 of 34 (permalink) Old 10-24-2011, 09:35 PM Thread Starter
Earl's Avatar
Yeah...it's worth too little to walk away from I'll just save up some money and buy myself a Ranger as a second vehicle.
Earl is offline
post #21 of 34 (permalink) Old 10-24-2011, 09:37 PM
I wouldn't go so far as to say the outers are obsolete/ unavailable. Moog and Motorcraft still makes them, according to Rock Auto.
post #22 of 34 (permalink) Old 10-24-2011, 10:09 PM
Depends on brand, donnit?
Rockauto lists Motorcraft and Moog, http://www.rockauto.com/catalog/rafr...&parttype=7428 .
(Yes, it says 1991. Same parts for the whole MN12/FN10 series.)
Mgino96tbird46, I see great minds think alike
RalphP is offline
post #23 of 34 (permalink) Old 10-24-2011, 10:20 PM Thread Starter
Earl's Avatar
Well, yes, oem ford parts from the dealer...obsolete. There are a handfull of dealers that still have some in stock, as well as vintageparts has some, according to the locator. Moog and other aftermarket and rockauto are something else all together.
Do outer tie rods have zerk fittings, or is that an aftermarket thing? The ones currently on the car have them IIRC
Earl is offline
post #24 of 34 (permalink) Old 10-24-2011, 10:27 PM
Raptor22's Avatar
I cant remember if the Motorcraft ones I had did, I'm leaning towards no...
My Moog ones do, keeping them nice and greased.
Raptor22 is offline
post #25 of 34 (permalink) Old 10-25-2011, 06:25 AM
Rob
Rob's Avatar
I think it could go either way depending on who made the tie rods for motorcraft. I used to buy motorcraft upper control arms and some would have the zerk and other time they wouldnt.
-Rob
Rob is offline
post #26 of 34 (permalink) Old 10-25-2011, 02:06 PM
My factory ones had zerks
post #27 of 34 (permalink) Old 10-25-2011, 04:12 PM
Same here.
post #28 of 34 (permalink) Old 10-25-2011, 06:25 PM
Mine didn't. The Moog replacements do
RalphP is offline
post #29 of 34 (permalink) Old 10-25-2011, 09:22 PM Thread Starter
Earl's Avatar
Bad right rear wheel bearing, so bad it destroyed the hub. Bad inner tie rods. Bad pinion Seal, so all that is being fixed, mark hiking drive shaft takes care of the bad u joints plus whatever else it needs to be nice again.
Earl is offline
post #30 of 34 (permalink) Old 10-28-2011, 10:04 PM Thread Starter
Earl's Avatar
I got the car back today. Night and day differance. Thanks to the new mark viii aluminum one piece driveshaft, no more clunk shifting into D,R, etc. shifts seem a bit more positive, and it seems to get the power to the rear wheels a bit faster, which could just be my imagination...the car also seems a bit faster...which could be due to my lighter wallet
New hub and wheel bearing passenger rear, new inner tie rods up front. Car drives nice, tracks straight.
As for the power steering which has always been stiff at slow speed, and OK but somewhat stiff at higher speed. EVO module was bad. Mechanic suggested that if he unplug IIRC the actuator, it would go to full assist and stay that way under all circumstances...I said try it and I'll let you know. Jury is still out on that one. It's OK, feels great at slow speed, like it should, but at high speed, it is a bit sensative. I guess I could get used to it.
Cruise control works again. It was the brake travel deactivation switch. He found the same thing I found digging into it, broken wires inside the switch, the contacts do not touch, etc. Because the switch is no longer available, and nobody anywhere has one and there is no aftermarket switch, he said he could rig up a toggle switch on the dash. I said sure. Once that was said & done, he goes "hey the brake light switch also deactivates the cruise, so it will still operate as normal" And it does. But I can also deactivate it completely from a simple metal ON/OFF toggle switch on the dash. I like that. It's cool to flip the switch off and feel the gas pedal release.
Next up was the fact that my emergency brake has not been functional in quite a while. cable was as tight as possible, and was barely moving the pistons on the calipers. Apperantly there is some sort of worm gear deal on the rear calipers, and if it is not installed correctly, it will cause problems and break things. This is the issue. So, new rear calipers happen next week, and I will have an emergency brake again. At that point I can do the hand brake swap.
After this is all paid for, the door hinge will be REPLACED...not re-pinned. New striker, welded up metal around the striker.
And then the whole car will get a new paint job.
Earl is offline
