difficulty of pulling control arms off a mark 8? - TCCoA Forums
post #1 of 10 (permalink) Old 11-16-2011, 11:41 PM Thread Starter
rednsilver94sc's Avatar
Send a message via AIM to rednsilver94sc
just curious at the difficulty of doing these
found several sets in the junkyards around here and wondered how long it would take to get them off
ive never messed with the air ride setup before as compared to the standard coil springs
most searches came up empty for what i was looking for
1995 Thunderbird 4.6 40th Anniversary Edition
1994 Thunderbird SC
1984 Corvette 383 Stroker
2008 Chevy Equinox AWD
2001 Excursion Limited 7.3
rednsilver94sc is offline
post #2 of 10 (permalink) Old 11-17-2011, 05:29 AM
Once you deflate the air bags, it's just like on a TBird.
The time will vary depending on the grunge level of the bolts and the tools you have (i.e., a northern car, like you'd see, and few of the proper tools == all day affair, down here with my balljoint splitter and an impact == all EIGHT control arms, all four spindles, and even the diff in under 4 hours ... )
The biggest difference you'll find is, once it's deflated, you're not worried about the spring pressure. I can work the rear bags out without removing the LCAs, for that matter. Can't get the rear springs out that way ...
Now, which control arms are you talking about?
RalphP is offline
post #3 of 10 (permalink) Old 11-17-2011, 06:42 AM Thread Starter
the aluminum rear control arm's that swap over to thunderbirds/cougars
and people also always ask for the diff's
1994 Thunderbird SC
post #4 of 10 (permalink) Old 11-17-2011, 11:52 AM
Traveler's Avatar
If you'd rather not have to pull a set of grungy control arms. I've got a set sitting in my garage complete with the aluminum spring adapters.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #5 of 10 (permalink) Old 11-17-2011, 09:10 PM
The BIGGEST problem I've found is finding a wrench to handle the 40mm nut on the front.
I use a pipe wrench (!!) for my take aparts.
I don't really recommend that, though ...
Second note: If it's air-bagged, release the air pressure BEFORE you start removing it (disconnect the air feed connector, the air will hiss right out and it becomes MUCH easier to remove.)
RalphP is offline
post #6 of 10 (permalink) Old 11-17-2011, 10:50 PM
I use a huge adjustable wrench to handle the 40 mm nut. Its best to jsut take the whole knuckle brake and both crontrl arms. Its just barely light enough to pick up for me anyway and set it on something that rolls. THis way you dont deal with the damn tamper bolts or wrestling the brakes apart on your car. It works like a complete unit this way. Its tricky to jack it up to the car but I did it with just a racing jack. You get the better halfshafts and both the lighter arms and disk brakes all win for the standard LX. Plus once these 2 units are out of the way the aluminum diff is cake to drop. Plus if its a 93 the 1 piece aluminum DS almost comes right out with a little lowering of the tank. DO do these things requires some handy tools the right sockets/breaker bars make it easy. Its easier with 2 people but I only had help on raising during install or dropping during removal. Getting just the LCA is the main reason people go for this mod but those tamper proofs can be impossible to get off in the yard if put in the same direction.
post #7 of 10 (permalink) Old 11-18-2011, 03:48 PM Thread Starter
splattered- i went today to look at a set i dont see the 40mm nuts? i saw 2 21mm bolts for the pivot bolts that secure the arm to the frame
18mm for the shock to arm
the upper arm- spindle bolt
2 lower arm to spindle bolts with the torx bit heads
sway bar link and the airbag
1994 Thunderbird SC
post #8 of 10 (permalink) Old 11-18-2011, 03:50 PM
Look at the nut on the FRONT side, attached to that bolt on the LCA/frame side.
NOT the one that does the toe adjust.
On the TBirds I've seen in the yard, one side is a more standard nut, the other the 40MM. On the Mark VIIIs, BOTH are the 40MM.
If yours aren't 40MM, then you got lucky
RalphP is offline
post #9 of 10 (permalink) Old 11-18-2011, 06:44 PM
Did you see the LCA to spindle bolts? If you didnt then you are missing the point of attack the inner control arm bolts. If you find the rear toe links the 40mm nuts are right next them. start looking at pictures on line of the IRS. If you are getting confused and cant mentally picture the IRS then this is a real complicated headache. But with some time spent on knowin what and where everytihg is it simply becomez an exercise in getting dirty. Its not hard but you need to be familiar with the parts. Youll need a huge adjustable wrench and a 22,20,24,19,17,18 mil stuff cant remember all the sizes. But I use a 2 foot breaker bar to get this stuff loose. You dont need super tools just a few.
post #10 of 10 (permalink) Old 11-27-2011, 10:56 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
When we did the coil swap on the Mark, the only thing that went wrong when taking off the aluminum arms was that the guy helping me tried to remove one of the LCA to knuckle bolts by using an impact on the torx head and holding the nut instead of holding the torx and turning the nut. He broke one of my favorite torx bits (I think it was a t-50). Ah, we had many good times together up until that day. Other than this, it was fairly straight forward. If you want to deflate the bags really fast, make sure the frame is supported with the tires off the ground and remove the air solenoid from the bag. Luckily his bags were already collapsed when we started this job. Good luck and keep us posted!
-Rob
Rob is offline
