car pulls to the right when steping on brakes - TCCoA Forums
post #1 of 17 (permalink) Old 03-14-2012, 10:06 AM Thread Starter
On Probation
blown96bird's Avatar
I have replaced the lower control arm, upper control arm rotors, pads, calipers. what can it be?
blown96bird is offline
post #2 of 17 (permalink) Old 03-14-2012, 10:34 AM
With front calipers/pads properly replaced & bled, I would be looking at the rear brakes.
Maybe your driver's rear isn't working or the passenger rear is grabbing/dragging.
Also, when is the last time you had a good 4-Wheel alignment?
~Rick
TCCoA Sig
post #3 of 17 (permalink) Old 03-14-2012, 10:47 AM
cobra R Thunderbird's Avatar
Could be a bad front wheel hub as well...
How to check: jack car up, grab the spindle w/ your hand, spin wheel, if u feel a bad vibration= bad hub.. Will cause pulling on braking
2001 GT BULLITT #00762 stock
post #4 of 17 (permalink) Old 03-14-2012, 11:23 AM
I didn't think of the hub - very true! I once had a Camaro that the wheel bearings went bad in a front wheel - pulled like the dickens to one side!
~Rick
TCCoA Sig
post #5 of 17 (permalink) Old 03-14-2012, 12:04 PM
I'll bet you $20 its the strut rod bushings. When they go bad, the car will drive normal, but when you hit the brakes, the wheel gets pulled back which changes the alignment angles and causes a pull. When you let go of the brake, the wheel goes back to the normal position and the car drives straight again. A simple test is with the car in park sitting on the ground, push on the front wheels to try to roll them backwards or forwards. If the wheel moves at all without the car moving, the strut rod bushings are bad and need to be replaced.
post #6 of 17 (permalink) Old 03-14-2012, 12:09 PM
daveb42099's Avatar
The calipers thats what caused my car to pull or the perporsioning valve if it dont have abs i replaced everything to do with brake pull when my car did it
daveb42099 is offline
post #7 of 17 (permalink) Old 03-14-2012, 01:00 PM
I'm with Mike, if the strut rod bushings are worn the steering geometry will change and cause steering pull. When you hit the brakes the wheel will move backwards relative to the car, causing toe in on that side generating a pull in the opposite direction. So definitely check that out.
Now, having said that, it's also worth investigating the rears as well. I had a steering pull some years back which ended up being seized pins in one of the rear calipers.
post #8 of 17 (permalink) Old 03-14-2012, 02:11 PM
Strut rod bushings
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #9 of 17 (permalink) Old 03-14-2012, 04:35 PM
+1 - another part that could be bad. I changed them on an Explorer once that you could literally put your foot on top of the tire and roll the tire back and forth like 4 inches while the rest of the truck sits still.
~Rick
TCCoA Sig
post #10 of 17 (permalink) Old 03-14-2012, 07:11 PM
sousa632's Avatar
I'll agree with the strut rod bushings!
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #11 of 17 (permalink) Old 03-14-2012, 07:45 PM
nall_one's Avatar
oh yeah, strut rod bushings do that most definitely... mine are shot on the right side of the car, and when i brake it pulls to the right pretty good, the strut arm also rattles like crazy. pop a prybar in between the strut arm and the tierod or something and try to move it up and down, i bet it will move around a good 1/4" like mine dose XD.
their like $12 a piece and come in bags of two, so you might as well do both sides like i plan to this weekend.
check the sticky here in the suspension forum for details, it has part numbers from ford. stay AWAY from the Moog ones or anything else really... moog makes some decent stuff for the most part, but those plastic 'problem solver' bushings are RUBBISH...
nall_one is offline
post #12 of 17 (permalink) Old 03-14-2012, 07:52 PM
Warning, the grammar nazi part of me drives this from me... I'll probably get flamed for saying it. lol Educational only, no flaming intended.
Their = possession of they (it's their money)
They're = they are (they're talking nonsense)
There = location (go over there by the wall)
So, it should be "They're like $12 a piece"...
I'll get off my soap box now.
post #13 of 17 (permalink) Old 03-14-2012, 09:50 PM
They're (people who correct everybody) are pretty annoying.....
~Rick
TCCoA Sig
post #14 of 17 (permalink) Old 03-14-2012, 10:18 PM
96tbirdboi's Avatar
agreed
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #15 of 17 (permalink) Old 03-14-2012, 10:37 PM
Everyone corrects everyone's bad tech already, so I guess I can lay off on grammar for a little while...
post #16 of 17 (permalink) Old 03-14-2012, 10:56 PM
pendejo
druggles85's Avatar
http://www.better-english.com/easier/theyre.htm
"Yesterday, upon the stair,
I met a man who wasn't there.
He wasn't there again today,
I wish, I wish he'd go away..."
druggles85 is offline
post #17 of 17 (permalink) Old 03-15-2012, 08:53 AM
sousa632's Avatar
Being that the thread derailed, another pet-peeve of mine is people who say things like "needs replaced" or "needs washed" ..... the correct way is "needs TO BE replaced/needs replaceMENT" or "needs TO BE washed / needs washING".
Just saying.............
Back to the topic....... again it's either strut rod bushings, which are notorious to go bad, or a bad caliper/wheel cyl, or a bad wheel bearing, or air in the brake system. Lots of things to look at so start plugging away.
John
1996 TBird LX 4.6
sousa632 is offline
