lower strut bolt - TCCoA Forums
post #1 of 2 (permalink) Old 04-21-2012, 06:35 PM Thread Starter
lower strut bolt
I'm in the process of changing out my lower control arm and all I can say is WOW... I ended up having to cut the strut bolt to get it out
dpmeeks is offline
post #2 of 2 (permalink) Old 04-21-2012, 06:43 PM
Ah yes, the lower shock mounting bolts. I had to go through the same ordeal with the T-bird. When I did the shocks on the Cougar I was also doing the lower control arms, so I got out of having to fight those bolts that time. Luckily when I did the Mark VIII the bolts were fairly rust free (which is ironic since it's the oldest/highest mileage of the three).
