Suspension bushings - TCCoA Forums
post #1 of 67 (permalink) Old 04-25-2012, 05:18 PM Thread Starter
Suspension bushings
1994 Tbird LX 4.6, 72k city miles.
Had the clunk in the rear last year. Got the stabilizer bar end-links replaced.
Now I got the clunk in the front. Traced it to the front stabilizer bar end-links (with TCCOA help), got it up on a rack and find the bushings for the lo control arm are shredded, partly hanging loose.
I fear the car may need all new suspension bushings (except the rear end-links). Is it practical to replace "the mess of 'em"?
I am old and infirm and can't do much work on it. I've found several threads on non-Ford bushings including the "Front Bushing Picture Thread with part numbers" thread. I know to use Ford strut rod bushings at the frame side: is it safe to assume the Moog parts in http://forums.tccoa.com/showthread.p...ts+list+thread are OK for the rest?
Your expert opions are solicited: how should I proceed with this? If I asked a dealer to estimate parts/labor for full replacement of suspension bushings, what ball-park should the estimate fall into? $500? $1500?? More???
I got the car in '97 with 19k mi. on odometer. The 50+k mi. I've put on it were gently nursed (I've got a 2-wheeler on which I do my rip-and-tear stuff). Retired since 2001, I don't put many miles on the machine. Aside from the MLPS and a couple sets of plug wires, I haven't had to repaiir much of anything. I'd sooner fix it than buy a new (used) auto, as long as it is practical to do.
Help me keep an ancient 'Boid on the road. :-)
TIA,
P
Email - puddingDOTmanATgmailDOTcom
Note - 'Boid has only 73k (mostly city) miles
Pudding_Man is offline
post #2 of 67 (permalink) Old 04-25-2012, 05:41 PM
You definitely want the OE Ford bushings on both sides of the tension struts, but aside from that you're okay to use Moog for the rest of the suspension.
I can't fathom a guess to what it would cost to have the work performed, even if you provided the parts.
post #3 of 67 (permalink) Old 04-25-2012, 05:51 PM
96PRLBRD's Avatar
I would guess the bill will be over $1,000 with labor. I replaced the front strut rod bushings (both ends), outer tie-rod ends, and upper and lower control arms last year. I did it myself though so that saved some $.
It's worth pricing out Ford/Motorcraft parts as they're good obviously. If the price isn't much different, just stick with Ford/Motorcraft IMHO.
--> My most recent pics <--
96PRLBRD is offline
post #4 of 67 (permalink) Old 04-26-2012, 07:04 PM Thread Starter
Thanks go to theterminator93 and Swanny for helpful info.
I walked into the neighborhood (Ford) dealers today and stood around for 20 min., no one even asked if I needed help at the svc. counter. I walked out after getting a quote from the parts guy. All the dealers refuse to install non-Ford parts? If so, I don't need to get a dealer estimate of labor: they won't
do the work without specifying parts I don't need (strut, etc).
I've sorta given up on replacing -all- the bushings. Doesn't look practical.
There's a neighborhood mechanic that sez he'll do front end-links and strut bushings for maybe $120 labor + 40% markup on parts. I can't even find his parts numbers, so I worked up some of my own. Looks like:
'94 Tbird LX V8 (4.6L)
Estimate of parts cost, front suspension bushings:
Rockauto http://www.rockauto.com/catalog/raframecatalog.php
MOOG Part # K8635 End Links 2 @ $40.79 81.58
S/H $8.58
Total $90.16
McMahon Ford
Strut Rod Bushings LCA Side - Front: E9SZ3A140A
Strut Rod Bushings LCA Side - Rear: E9SZ3A140B $94.52
(per Ron @ McMahon)
Total Parts Cost $184.68
+ 40% 73.87
Parts + Markup 258.55
Est. Labor $120.00
Grand Total $378.55
Most important - do all the part #'s and types (Moog, etc) look OK? I haven't run it by the mechanic yet. Apologies for what the forum software does with columns, spacing, etc (dunno how to get around that). :-(
P
post #5 of 67 (permalink) Old 04-26-2012, 07:08 PM
You can order the strut rod bushings at the LCA side for about $40+shipping from various online retailers, e.g. fordpartsgiant.com. They come packaged as a pair - one pack of two rears, one pack of two fronts, about $18 a piece.
post #6 of 67 (permalink) Old 04-26-2012, 11:05 PM Thread Starter
I remember seeing they didn't have the kit (dealer didn't either). They have the bushings (Thanks!).
>As Rodeo Joe points out, bushing KIT.
>You can buy the bushings separate, but you need good ferrules.
>If you've got one-part units, you may need to torch the old bushings off to get to the ferrules.
>In the mean time, I think I will be raiding the local U-Pull-Its for ferrules (and complete strut rods!)...
>Well, go to your local Ford dealers parts dept. Ask, when they tell you it's discontinued ask them to do a search and see if any other dealers are showing a stock. That's how I got mine last month. $114.30 +shipping (each). They were shipped here from a dealership in Texas.
>There still may be a few kits around but they wont be for long. The next step is get good hardware if yours is bad and buy the bushings separately. Use the diagram at fordpartsgiant to get each individual part number.
I'm showing the bushings separately (no problem with that).
But they don't have the ferrules? Any ideas??
P
post #7 of 67 (permalink) Old 04-26-2012, 11:10 PM
The only option for the frame side, if your hardware is shot, is to get in touch with DLF and ask him about his stainless steel, improved design hardware. There is a thread about them here: http://forums.tccoa.com/showthread.php?t=137104
post #8 of 67 (permalink) Old 04-26-2012, 11:50 PM
96PRLBRD's Avatar
I bought the frame side bushing kits which include the sleeves and bushings last year. I was told the kits were obsolete for some time but the dealer was able to get me two sets of them. So hunt around there still may be factory Ford sets out there if interested.
96PRLBRD is offline
post #9 of 67 (permalink) Old 04-27-2012, 11:32 AM Thread Starter
If the old hardware is salvagable, will it be just a "slip-on, slip-off" thing? Or do ya gotta torch it off? Or ???
P
post #10 of 67 (permalink) Old 04-27-2012, 11:40 AM
Ideally, yes. It ultimately depends what shape the bushings/hardware is on that side and unfortunately, it's practically impossible to tell what you'll find until you start ripping it apart.
post #11 of 67 (permalink) Old 04-27-2012, 03:23 PM Thread Starter
My guess is ... it won't be that bad.
My revised estimates, without shipg/handlg:
MOOG Part # K8635 End Links 2 @ $40.79 $81.58
Total $81.58
www.fordpartsgiant.com
bushing SZ-3A141-B Front of lower arm $18.88
bushing SZ-3A140-A Rear of lower arm $18.70
Total $37.58
Total Parts Cost $119.16
Markup @ 40% 47.66
Parts + Markup 166.82
Est. Labor $120.00
Grand Total $286.82
Near as I can tell, I've got what I need for now. Many, Many Thanks!
I'll let y'all know how it pans out in a week or 2.
Cheers,
P
post #12 of 67 (permalink) Old 04-27-2012, 06:55 PM
CrystalPistol's Avatar
To replace all bushings just because of a worn sway bar end link at 74K miles is a wasteful way to spend hard earned dollars IMHO .... but they are your $$$s. I'ld say replace other rubber parts when needed for sure, but the front sway bar end links are ball and socket type joints, and they are easily replaced when worn.
I spent a few $$$ replacing both front sway bar end links on the '95 as they were clunking a little. Now all is tight and she has a bit over 75K on her. As to the rear, I made new rubber bushings using rubber hose and a vise.
CrystalPistol is offline
post #13 of 67 (permalink) Old 04-27-2012, 11:01 PM Thread Starter
When I took a half-serious look at the undercarriage, I saw more bushings that needed replacement than ones that didn't. That led to consideration of practicality of replacing most/all of 'em.
Obviously wasn't practical, so I'll do what I can, piecemeal. If I could've replaced all bushings for, say, $500 parts/labor, I probably wouldn've done it. Just so I wouldn't hafta worry about it for a long, long time.
Just trying to use common sense, here.
P
post #14 of 67 (permalink) Old 05-02-2012, 11:41 PM
FLPNDBRD's Avatar
Send a message via Yahoo to FLPNDBRD
I went to the Ford Dealership in my city and asked how much to replace everything? Uppers, lowers, tie rod ends, and sway bar links and if i bring all the parts. And of course go on and knock out the alignment. he said $606 and they could do it in one day if I drop it off before 10AM. SMH. Geuss im gonna have to get my mechanic to do it. Itll be way cheaper but it would take about three days cuz he works two jobs.
You Gon Learn Today.....
FLPNDBRD is offline
post #15 of 67 (permalink) Old 05-03-2012, 03:43 PM Thread Starter
Everything? You mean everything in the front suspension. Right?
Thanks for the mention. I didn't know if any dealer would do it.
If/when you get a firm quote from your mech. please post it here.
Cheers,
P
post #16 of 67 (permalink) Old 05-03-2012, 03:50 PM Thread Starter
Remove the tension strut ?
Who can tell me exactly how to remove the tension strut (strut rod)?
Is all this necessary (this is from Haynes)?:
1.) Put it up on jack-stands.
2.) Loosen balljoint retaining nut.
3.) Separate LCA from spindle with balljoint-separator tool.
4.) Remove nut that attaches tension strut to LCA.
5.) Remove shock lower mount nut and bolt.
6.) Remove pivot bolt and nut and detach the LCA.
Thx,
P
post #17 of 67 (permalink) Old 05-03-2012, 03:54 PM
Then you need to remove the nut at the front of the strut rod.
Edit: to answer your second question.....yes
post #18 of 67 (permalink) Old 05-03-2012, 04:51 PM Thread Starter
At the frame end, yes. Thanks.
How long do you figure it should take a pro mechanic (for 1 side)?
P
post #19 of 67 (permalink) Old 05-03-2012, 04:57 PM
DLF
DLF's Avatar
Well, that's the book method.
However, if all that you're doing is working on the strut rod bushings, here's a different method.
Jack up the car.
Remove the wheel.
Disconnect the upper sway bar link.
Remove the inner LCA adjusting bolt and nut.
Remove the nuts at both ends of the strut rod.
Disconnect the UCA from the spindle.
Remove the three nuts that hold the upper shock mount to the shock tower.
Swing the LCA, shock and spindle rearward, watching the brake and ABS lines, and remove the strut rod.
Any time I can skip touching the lower ball joint and the lower shock mounting bolt, I will.
If nothing's rusty, I can do it easy in less than a half hour.
My Web Site
DLF is offline
post #20 of 67 (permalink) Old 05-04-2012, 03:56 PM Thread Starter
Lost in bushings-land again
I just went over my '94 with a long-time dealer mechanic who tells me I need (in addition to end-link and strut-rod bushings);
LCA bushings
Upper ball-joint bushings (and/or rubber covers)
The suspension parts list thread shows only:
LEFT - INCL BALL JOINT K80053
RIGHT - INCL BALL JOINT K80055
which are the Moog LCA kits (all parts, I think) and about $53 each.
Is it not possible to get only the applicable bushings (and/or rubber covers) by-they-own-selves?
Did I miss something in the thread?
Thx,
P
post #21 of 67 (permalink) Old 05-04-2012, 04:11 PM
Don't bother trying to replace just the control arm bushings. For no more labor and about $20 extra in parts you can get the whole control arm which also includes new ball joints, which are a common failure point on the vehicle. The part numbers you have listed are the entire control arms, which is what you really should have them replace. They have to take the control arms off anyway to get at the strut rod bushings, so there should be no additional labor involved with installation there; don't let them rip you off an extra $200 on the account of 'replacing control arms'. You will need an alignment after the fact, though.
With new LCAs, new UCAs, new endlinks and new strut rod bushings, you will have effectively rebuilt the entire front end.
Well, except for the shocks and springs...
post #22 of 67 (permalink) Old 05-04-2012, 04:51 PM Thread Starter
I dunno I can follow all that.
All my ball-joints are solid, but the covers are rotting off the uppers. You can see some rust.
To my knowledge, all my control arms are solid, but the bushings on the lowers need replacement.
I'm running out of money. It already looks like $190 for end-links and strut rod bushings + maybe $500 labor. Thats damned near my Soc. Sec. check right there.
When you say "$20 extra", do you mean $20 for each of 4 control arms (LCA's and UCA's)?
P
post #23 of 67 (permalink) Old 05-04-2012, 05:26 PM
DLF
DLF's Avatar
Why do you keep starting new threads? You've now got three threads on this same issue.
My Web Site
DLF is offline
post #24 of 67 (permalink) Old 05-04-2012, 05:35 PM Thread Starter
I suppose because I was ignorant of the accepted protocol. I'll add to the first one in the future. OK?
P
post #25 of 67 (permalink) Old 05-04-2012, 05:46 PM
The cost of the bushings + install (they need to be pressed in/out of the arm) is more than replacing the arms entirely. The labor on the car is exactly the same since the whole arm needs to be removed during both jobs. Plus the BJs will need to replaced eventually. 80-150k is where they tend to go bad anyway and at 73k you're not far off.
If the boots are bad on the uppers they're done. If you see rust inside that means moisture has gotten in and contaminated them already. They're ticking time bombs now.
post #26 of 67 (permalink) Old 05-04-2012, 07:13 PM Thread Starter
As near as I can tell, pieces of this/these threads are falling thru the cracks. One guy sez one thing, another sez something different. This makes po' me PLENTY, PLENTY NERVOUS 'cause it can easily put my skinny, skinny financial arse in a hulluva sling.
Who is the ultimate authority for this stuff?
Howcum 'upper control arm' part #'s etc were omitted from "How about an official suspension parts list thread"?
Howcum, when I run a 'search this thread' for UCA it comes back and sez :
The following errors occurred with your search:
Sorry - no matches. Please try some different terms.
Apologies for my lack of facility with the forum software, 'search' etc. That's part and parcel of what makes me so nervous.
Thx,
P
post #27 of 67 (permalink) Old 05-04-2012, 07:22 PM
Matt and I are more or less saying the same thing, in different terms.
Basically, the cost of having someone replace the components you initially had in mind (the sway bar endlinks and strut rod bushings) will include the labor to remove the lower control arm. In order to replace the strut rod bushings, you have to remove the lower control arm.
Replacing just the bushings in the control arms is a good idea, but you'd be spending more money on having them do the labor to replace the bushings in the original lower control arms which have 75k on them. You could take that extra money and put it towards new lower control arms instead and be ahead not only with new bushings, but with new ball joints.
The upper control arms are more or less the same way. Since your boots are cracked (and appear to have been that way for some time), the ball joints should be replaced. The only way to replace them is to replace the entire arm since they are not serviced separately. Again, the new control arm comes with new bushings.
RockAuto has a TRW (original equipment manufacturer) left upper control arm on closeout for $45, part number 10763E. Otherwise, get Moog part numbers K8596 and K8598 or Motorcraft MCS10763 and MCS10764.
post #28 of 67 (permalink) Old 05-04-2012, 10:38 PM
DLF
DLF's Avatar
DON'T BUY THAT!
I did and returned it, it wasn't TRW.
My Web Site
DLF is offline
post #29 of 67 (permalink) Old 05-04-2012, 10:53 PM Thread Starter
Well, I had kinda took DLF's suggestion to heart:
Jack up the car.
Remove the wheel.
But I can see your point.
I think I'd stick with Moog for consistency.
It still bothers me that replacing the UCA's was ignored in the "Suspension parts list" thread. Any ideas?
P
post #30 of 67 (permalink) Old 05-05-2012, 05:26 PM Thread Starter
Howcum it won't let me search for phrase "Moog R series"?
The search term you specified (R) is under the minimum word length (2) and therefore will not be found. Please make this term longer.
If this term contains a wildcard, please make this term more specific.
And, being as it won' let me search, I hafta ask:
"What's the story on the Moog R series?"
For instance, are they structurally weaker or ??
P
