upper shock movement? - TCCoA Forums
post #1 of 7 (permalink) Old 10-12-2014, 10:46 AM Thread Starter
tbirdtess's Avatar
does anyone know how much movement at the upper shock mount, if any?
making an upper mount plate. Need to know if I need a shoulder bearing.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 7 (permalink) Old 10-12-2014, 11:47 AM
It needs to move; the Shock Shaft angle varies inboard to outboard as the suspension moves up and down around the pivot of the inner lca bolt, and it moves front to back with the strut rod bushings flexing on both ends. (hopefully, not as far, lol)
If you're going to make it solid, it needs a spherical bushing or bearing that supports movement; Or it may break the shock or shock seals.
That said, This part is the big thing keeping me from buying Race Konis; the shaft is bigger than stock.
Grog6 is online now
post #3 of 7 (permalink) Old 10-12-2014, 11:47 AM
Not sure how much, but it'll pivot around the shaft some (not circular, angular) as the LCA goes up and down.
Fuelly
RalphP is offline
post #4 of 7 (permalink) Old 10-12-2014, 02:49 PM
It'll pivot forward/back too when the strut rod bushings deflect, as well as when you adjust caster.
post #5 of 7 (permalink) Old 10-12-2014, 07:31 PM
Am I on everyone's ignore list??
Grog6 is online now
post #6 of 7 (permalink) Old 10-12-2014, 08:35 PM
Grog - I bet you were typing yours as I was typing mine. And with mine up there, Matt MAY not have seen yours.
Fuelly
RalphP is offline
post #7 of 7 (permalink) Old 10-12-2014, 08:48 PM Thread Starter
tbirdtess's Avatar
faking it!
You seem to be faking it just fine
that's what i was thinking as well.
351W 2bbl.
C-4 Auto
3.90 open rear
