Solid Rack & Pinion Bushings - TCCoA Forums
post #1 of 9 (permalink) Old 10-14-2014, 07:19 PM Thread Starter
Rayo's Avatar
SpinningWheelS-sc offers Solid Rack & Pinion Bushings..
Has anyone installed these on their MN12 or FN10?
Share your experience with these if you've installed them on your car..
What would be the pros and cons of having Solid Rack & Pinion Bushings?
Here's the link-->> Solid Rack & Pinion Bushings
1991 Ford Thunderbird Sport
Rayo is offline
post #2 of 9 (permalink) Old 10-14-2014, 07:25 PM
Never driven a MN12 with em but in Mustangs(which are basically the same rack) they don't really make any perceptible difference, maybe some more feedback through the wheel, which isn't a bad thing.
post #3 of 9 (permalink) Old 10-17-2014, 06:54 AM Thread Starter
Rayo's Avatar
Thanks Matt..
I'm not doing it now, but I figure when I do change the rack out these might be worth installing..
Just trying to get a little feedback from you guys first..
Rayo is offline
post #4 of 9 (permalink) Old 10-17-2014, 06:37 PM
tbirdtess's Avatar
Try
I want to try a set in my stock car.
it's a 90, they must be old & soft.
With my big tires & turning with speed & forced braking.
I have melted brakes & bushings.
Plus broke some wheels as well.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #5 of 9 (permalink) Old 10-17-2014, 10:06 PM
I've run them in a SN95. Didn't really notice much difference.
post #6 of 9 (permalink) Old 10-18-2014, 09:24 AM
Well, there's a big difference from shot bushings and new solid - but from how Ruby handles, I bet there's about none between good rubber and solid.
On the Dakota, there was a tremendous difference from almost-completely-missing bushings and new poly *grins*
I'd go for poly or solid if you're replacing anyway. However, I don't think you'll notice much unless you really push it hard into cornering.
Fuelly
RalphP is offline
post #7 of 9 (permalink) Old 10-19-2014, 06:44 AM Thread Starter
Rayo's Avatar
I wonder what temperatures the factory Rack & Pinion bushings actually see??
Chances are there will be a point where something will leak on the Rack & Pinion bushings..So rubber is definitely out of the question..
If the factory bushings don't see any abnormally high temperatures down there poly would be an alright substitute as well..
The properties of the poly that allow it to come in contact with fluids without being damaged is another good attribute..
For the price..I don't see any reason not to go solid bushings at the rack..
Rayo is offline
post #8 of 9 (permalink) Old 10-19-2014, 11:32 AM
It's not the temps, but the fluids from such things as the power steering pump (PS fluid / transmission fluid), the front seal on the motor (engine oil at temp), the water pump, etc.
Fuelly
RalphP is offline
post #9 of 9 (permalink) Old 10-19-2015, 10:24 PM
TwoHaggard's Avatar
Anyone else give these a shot on a bird? Seem worth it for the money.
From what I read sounds like as long as your exhaust isn't In the way just replacing the bushings isn't to bad of a job?
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
