Groaning/Creaking sound, hard to diagnose - TCCoA Forums
post #1 of 7 (permalink) Old 01-11-2015, 08:16 PM Thread Starter
'93MN12's Avatar
My front passenger side wheel makes a groaning noise when I turn the wheel, its only really noticeable at low speeds and when I'm stopped. Also makes this noise when it goes over bumps, but only on that side. I've replaced every front suspension component except for the shocks. It just makes this loud, embarrassing crunching sound and is very annoying, so far is only a complaint with no visible impact on drive-ability so far. The power steering works fine, but you can feel the resistance in the steering wheel when it makes the sound. Any suggestions?
1993 Thunderbird LX. 3.8L with Underdrive Pulleys, Ford Racing Limited-Slip Differential, Intake & Dual Exhaust, and I like to run advanced timing
'93MN12 is offline
post #2 of 7 (permalink) Old 01-11-2015, 09:38 PM
rushtonracing's Avatar
Thinking it's possibly the lower ball joint.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #3 of 7 (permalink) Old 01-15-2015, 12:18 PM
Yup that's exactly what it is
I had the same noise and came home on a tow truck
Bad-Hoschy is offline
post #4 of 7 (permalink) Old 01-15-2015, 03:26 PM Thread Starter
'93MN12's Avatar
Okay thanks guys, I guess I got a faulty part because I replaced both the driver and passenger side lower control arms but only the passenger side one creaks. Looks like I'll go get a new arm with all of the bushings already installed. That would be simpler than trying to replace just one seized ball joint, right?
'93MN12 is offline
post #5 of 7 (permalink) Old 05-14-2015, 03:23 AM
yes the lower joint is getting ready to fail mine fell out in my driveway luckily for me
Birdman64 is offline
post #6 of 7 (permalink) Old 05-19-2015, 04:48 PM
mine noise was lower ball joint also
DirtyMerc96 is offline
post #7 of 7 (permalink) Old 05-27-2015, 08:00 PM
tbird_boi82's Avatar
Send a message via AIM to tbird_boi82 Send a message via Yahoo to tbird_boi82
Word of advice on this , a lot of the newer replacement balljoints don't have a zirc fitting so to remedy this i bought the 14 gauge needle adapter for my grease gun and just squirt the grease in through the boot greasing these up is important it makes steering soo much smoother.
97 4.6L
tbird_boi82 is offline
