Balljoint Boot? - TCCoA Forums
post #1 of 12 (permalink) Old 02-06-2015, 06:05 PM Thread Starter
Balljoint Boot?
Question : Does anyone make replacement boots for an upper balljoint? Just replaced the upper control arms a couple years ago, now I find some critter has decided to use the boot for the balljoint for bubblegum. Really hate to replace the whole control arm because of a boot. Thanks Been looking, no luck yet.
xquzzme is offline
post #2 of 12 (permalink) Old 02-06-2015, 06:21 PM
Here you go bottom of page.
Polyureathane boots
post #3 of 12 (permalink) Old 02-06-2015, 06:40 PM Thread Starter
Awesome!! Thanks!
xquzzme is offline
post #4 of 12 (permalink) Old 02-13-2015, 10:58 AM
These work really well for 1/3 the price.
http://www.energysuspensionparts.com...sp?prod=191723
sbcaprice305 is offline
post #5 of 12 (permalink) Old 04-04-2015, 06:30 PM Thread Starter
I got a set of the boots from Rob's. Only just now had the chance to put one on. A hint for anyone changing these : The stock spring-clip retainers will not work. Tried a marine grade fuel zip, no luck. Guessed that just possibly a retainer might not be needed. Seems to be working, will let you know after I put a few miles on it. Not doing the other side until I'm sure it works. If anyone knows a trick on these, do tell. Thanks Thunder Checken
xquzzme is offline
post #6 of 12 (permalink) Old 04-04-2015, 08:42 PM
Yea my boots don't use a clamp as u can grease them
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #7 of 12 (permalink) Old 04-04-2015, 08:43 PM
I've had mine on for a few years with no issues
10.75 @128.38
RobertP is offline
post #8 of 12 (permalink) Old 04-04-2015, 08:58 PM Thread Starter
Thanks RobertP. If I hadn't spent so much time trying to clamp it, it's about the same amount of time as changing the oil. I'll go ahead and put the other one on.
xquzzme is offline
post #9 of 12 (permalink) Old 04-04-2015, 11:57 PM
Lol clamping would be nice the way I figured is every 10-15k u can slide boot down and add fresh grease, in my book they really save slot of money and time
10.75 @128.38
RobertP is offline
post #10 of 12 (permalink) Old 04-11-2015, 03:54 PM Thread Starter
I have a note some of you may or not know already. Today I replaced the other boot that the critters didn't eat. It was still intact, but I like these greaseable boots. When I pulled the factory boot off, there was almost no grease whatsoever in it. It looked as if there was only enough there to help in assembly. If you have replaced your upper control arms, or are going to, I would surely think hard about using these boots now. Dang sure glad I did.
xquzzme is offline
post #11 of 12 (permalink) Old 04-14-2015, 11:51 AM
riffraff999's Avatar
I've had the prothane boots installed for close to 2 yrs with no issues...work good.
riffraff999 is offline
post #12 of 12 (permalink) Old 04-16-2015, 06:17 PM
Yea, that's great 2 years is good cause I'd bet u would be replacing the complete control arm if not for the boots, many on here just don't believe how good they work, it saves a lot of money and time and I've got about 9 sets in stock
Robert
10.75 @128.38
RobertP is offline
