Steering Rack Question - TCCoA Forums
post #1 of 10 (permalink) Old 04-02-2015, 07:00 PM Thread Starter
MaddMartigan's Avatar
Is the high pressure elbow that connects the PS hose to the rack supposed to swivel freely?
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #2 of 10 (permalink) Old 04-02-2015, 07:04 PM
Yup, it's a swivel at the rack; one of the funner parts of replacing the rack.
If you could place both hands on it, it would thread right on, lol.
This is the Gates replacement:
That's from here:
http://www.rockauto.com/catalog/x,ca...,parttype,7320
Grog6 is online now
post #3 of 10 (permalink) Old 04-02-2015, 07:07 PM Thread Starter
Is that part known to fail?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #4 of 10 (permalink) Old 04-02-2015, 07:16 PM
If it fails, it leaks like a sieve; if it's a gushin, that's probably it.
Grog6 is online now
post #5 of 10 (permalink) Old 04-02-2015, 08:09 PM Thread Starter
Thanks. I didn't see the reply with the part number so I asked a stupid question. You guys nailed it.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #6 of 10 (permalink) Old 04-03-2015, 07:33 AM
Rayo's Avatar
High Pressure Fitting
Here's a picture of the High Pressure Fitting elbow end (The one that fits into the Rack & Pinion):
There's a few different reasons these things leak..Let's discuss the most common reason first..
There is an O-Ring underneath the fitting that eventually goes bad due to heat/chemical compatibility/shrinkage/swelling, many things..
When this O-Ring fails..The solution by Ford is to just replace the whole elbow..The O-Ring was never a serviceable part..
Moving on..The next most common reason these things leak are..The Teflon Seal goes bad..
Normally this seal doesn't just go bad on its own unless it's messed with..The Teflon Seal is one time use only..
So if you have to remove this fitting off of the rack..The Teflon Seal must be replaced before reattaching the fitting back onto the rack..
When you install the replacement Teflon Seal..Warming it up in warm water is suggested to make it more pliable to fit just over the threads of the fitting..
Probably the least common way this fitting fails is if it gets cracked in half..Perhaps from a combination of rust, or just being too rough on the part..
All 91-97 Thunderbirds/Cougars used the same fitting..As well as all 93-98 Mark VIII's used this same fitting as well..
IMO..If you can afford to it's best to use a Ford piece here vs Aftermarket..
The Ford Part Number for the High Pressure Fitting is: (F1SZ-3A719-D) or (F1SZ3A719D)
The Ford Part Number for the Teflon Seal is: 388743-S100
The High Pressure Fitting is still available new from your local Ford dealership, or online..
Unfortunately the Ford Teflon Seal has been discontinued..
You can find a replacement Teflon Seal at your local auto parts store..Dorman Help Part#82540
IIRC..You use the smaller of the 2..
The aftermarket Edelman High Pressure Fitting is part #39141
In closing..If anyone has replaced the O-Ring seal in this fitting that commonly fails, and was successful (meaning it didn't leak)
Please post a part number, and or size of seal you used..
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 10 (permalink) Old 04-04-2015, 11:17 AM
I don't believe that piece comes apart to service the o-ring; I believe it's swaged together.
Grog6 is online now
post #8 of 10 (permalink) Old 04-08-2015, 07:19 PM Thread Starter
I have a replacement and the nut that goes into the steering rack is 18mm on the new part. Just to verify, is the stock part 18mm as well?
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
post #9 of 10 (permalink) Old 04-08-2015, 10:13 PM
Yes it is 18 mm. If I have to do this again, I have identified a couple of places to grind away so the fittings can be attached before the rack is placed in the car.
Removing/installing those fittings in the manner you have to is one of those jobs that make you want to slap the engineer that said "Yep, that hole is big enough".
1993 Thunderbird
3.8 engine
weskan is offline
post #10 of 10 (permalink) Old 04-09-2015, 04:06 AM Thread Starter
I'm going to try and replace the fitting without dropping the rack. I'm hoping I can do it with a crow's foot wrench.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
