Rear subframe bushings - TCCoA Forums
post #1 of 6 (permalink) Old 05-12-2015, 10:51 PM Thread Starter
I am pretty certain that my rear subframe bushings are shot.
Anytime I shift from reverse to drive, or drive to reverse, the entire subframe moves and I get a loud clunk/clank. It has been a long time since i had someone shift for me while I watched, so I can't remember which side it is, but I believe it to be the passenger side that moves (the tire ends up offcentered in the wheel well.
My car is fairly powerful for just having supporting bolt ons, and I am sure the PI/Jspec combo ruined an old, dry, torn bushing very fast.
I do have a new set of Ford rear subframe bushings to install. Will these hold up to a reasonable amount of power, or will I be shortly replacing them again? What I am really worried about is my True-trac differential that the subframe sloppiness fried - it killed the pinion bearing.
Anyone run the SCP rear subframe bushings? They sure are expensive! I worry that under higher power levels (I am hoping to install a Vortech at some point) that the solid bushings will transmit shock to places that were not designed for it, and result in sheared metal/twisting.
Any comments/experience in this matter?
Thanks!
All Glory to God!
RIP JOHNNY LANGTON
96 LX PI/Jspec Pearl White. She enjoys eating ricers for breakfast
-MODS-
2002 PI 4.6L - Jspec Trans built by Darrin - 04 Marauder converter - Hayden 679 Trans cooler - Engine cooling modification - SCT Xcal2, tuned by Lonnie - 02 GT MAF and 99 GT Intake tube - removed silencer - 255 lph HP fuel pump - Aluminum Driveshaft - 3.73 TL - 245/60/15 BFGoodrich Radial T/A's - PBR front brakes - SCP Rear torsional load brace - SCP Solid rubber motor, transmission mounts - Rear Strut Tower brace and Diff cover brace by Rod
96_LX is offline
post #2 of 6 (permalink) Old 05-13-2015, 06:32 AM
You'll be fine. I still have the original sub frame bushings in place on mine. The new OEM bushings that you have should work great - yes they will hold up to quite a bit of power. I have to wonder if it's another bushing or mount that's failed that's causing the symptoms you describe but it wouldn't hurt to replace the original IRS bushings on yours.
Anyway, If you're looking for something better than OEM I'd recommend getting the UMHW IRS bushings from Jay - see this thread for details. There's a picture of them in post #16.
If you're talking about the aluminum rear subframe bushing kit that SCP sells for $415.99 save your money and get the UMHW kit from Jay for $325 shipped. No one that I know of here runs the aluminum spacers from SCP.
BTW, I don't agree with calling metal spacers "Bushings". You're right about metal spacers being too stiff.
post #3 of 6 (permalink) Old 05-13-2015, 07:02 PM
... save your money and get the UMHW kit from Jay for $325 shipped. No one that I know of here runs the aluminum spacers from SCP.
I totally agree; the ones that Jay sells are really nice.
I just rebuilt the rear of my oldest MN12, Lazarus, with these, and all poly bushings in Mark LCAs; except for these, everything is poly except the upper inner control arm bushing.
The irs to body bushings were put in awhile back; they were stiffer than the wasted stock ones, it was kinda hard to judge.
Adding the poly stuff made me realize how much give is in the stock LCA and knuckle bushings.
It's harsh with poly.
Dude that lined it up after I replaced all this stuff said "I love these cars; it's like cranking a knob to set everything." They're cool with using the numbers from the tech article.
Grog6 is online now
post #4 of 6 (permalink) Old 05-13-2015, 08:35 PM
96beaterbird's Avatar
I haven't tried Jay's bushings, but I did buy the steering u-joint and Mark VIII coolant plug from him and I have to say, he does great work. Everything looked like it came out of a top-notch manufacturing facility.
I received my parts less than two weeks after I paid him, which is pretty impressive, considering it was shipped via regular mail and had to clear Canadian Customs.
PM him to order, you won't be disappointed!
96beaterbird is offline
post #5 of 6 (permalink) Old 05-14-2015, 09:28 AM
I make stuff
Thanks for the kind words guys! I'm always happy to get good feedback!
To the OP, in case you didn't know, I'm the Jay that they're referring to. If you have any questions about my products, feel free to ask, either by PM, or right here in this thread.
98mark8lsc is offline
post #6 of 6 (permalink) Old 05-14-2015, 10:16 AM
No prob!
Now I can change my coolant without needing a torch, ez-out and 2 broken 1/4 ratchets!
